I have a Bluetooth speaker, when I connect the first time with my computer (Manjaro gnome) It works perfectly, but sometimes I need to change my audio device to a headphone and it disconects and I try to reconnect it stop to do it, the only way I can do is by removing the device, restarting the speaker and restarting my computer (not even systemclt restart bluetooth.service is working).
Those are my inxi fazy
data:
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=82643114-845a-4bb3-865e-908ebdb9dd39 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: Inspiron 5402 v: N/A
Mobo: Dell model: 0FJYHK v: A00 serial: <superuser required> UEFI: Dell
v: 1.8.0 date: 10/01/2021
ID-1: BAT0 charge: 47.4 Wh (100.0%) condition: 47.4/53.0 Wh (89.5%)
volts: 16.5 min: 15.0 model: BYD DELL TXD0316 type: Unknown serial: <filter>
status: full
Device-1: hid-dc:2c:26:07:76:d1-battery model: Keychron K1 serial: N/A
charge: N/A status: discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
status: discharging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 860 high: 1700 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 821 2: 400 3: 531 4: 868
5: 1062 6: 430 7: 1700 8: 1071 bogomips: 27040
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Dell driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-03) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 bus-ID: 0000:2b:00.0
chip-ID: 10de:1d16 class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris,nouveau gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: AOC 27G2G5
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x082e built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-3: PipeWire v: 0.3.68 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: cdc_ncm
bus-ID: 2-1:3 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: enp0s13f0u1c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
IF-ID-1: br-02877dc784b1 state: down mac: <filter>
IF-ID-2: br-88f022fe5141 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 213.86 GiB (44.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3A NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 92103061 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 41.54 GiB (34.6%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:4
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 348.44 GiB size: 348.44 GiB (100.00%)
used: 172.32 GiB (49.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:3
ID-4: /var/log raw-size: 120 GiB size: 120 GiB (100.00%)
used: 41.54 GiB (34.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:4
ID-1: swap-1 type: partition size: 8 GiB used: 512 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 56.0 C mobo: 52.0 C gpu: nouveau temp: 52.0 C
Fan Speeds (RPM): cpu: 2922
Processes: 386 Uptime: 3h 35m wakeups: 10 Memory: 15.36 GiB
used: 8.19 GiB (53.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1549
pm: pacman pkgs: 1542 libs: 336 tools: gnome-software,pamac pm: flatpak
pkgs: 7 Shell: Zsh v: 5.9 running-in: terminator inxi: 3.3.26
And this is my systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Tue 2023-04-18 17:53:52 -03; 15min ago
Docs: man:bluetoothd(8)
Main PID: 21671 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18836)
Memory: 2.3M
CPU: 96ms
CGroup: /system.slice/bluetooth.service
└─21671 /usr/lib/bluetooth/bluetoothd
abr 18 17:53:52 anderson-inspiron5402 bluetoothd[21671]: Endpoint registered: sender=:1.115 path=/MediaEndpoint/A2DPSource/sbc_xq_512
abr 18 17:53:52 anderson-inspiron5402 bluetoothd[21671]: Endpoint registered: sender=:1.115 path=/MediaEndpoint/A2DPSink/sbc_xq_552
abr 18 17:53:52 anderson-inspiron5402 bluetoothd[21671]: Endpoint registered: sender=:1.115 path=/MediaEndpoint/A2DPSource/sbc_xq_552
abr 18 17:54:07 anderson-inspiron5402 bluetoothd[21671]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 98:52:3D:1D:88:50: Permission denied (13)
abr 18 17:54:12 anderson-inspiron5402 bluetoothd[21671]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 98:52:3D:1D:88:50: Permission denied (13)
abr 18 17:54:20 anderson-inspiron5402 bluetoothd[21671]: Wrong size of start discovery return parameters
abr 18 17:55:24 anderson-inspiron5402 bluetoothd[21671]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 98:52:3D:1D:88:50: Permission denied (13)
abr 18 17:55:28 anderson-inspiron5402 bluetoothd[21671]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 98:52:3D:1D:88:50: Permission denied (13)
abr 18 18:06:03 anderson-inspiron5402 bluetoothd[21671]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 98:52:3D:1D:88:50: Permission denied (13)
abr 18 18:06:07 anderson-inspiron5402 bluetoothd[21671]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 98:52:3D:1D:88:50: Permission denied (13)
Looks like this permission I tried to navigate in the archwiki to debug but I could not advance more to fix this issue. Other Bluetooth sources keep working perfectly (keyboard)
Could someone help me?
