I added neofetch in the .bashrc file and when I open gnome-terminal it does not launch. I tried adding “ls” to test if that works and it doesn’t either.
Hi @wsamh,
Do you know what shell you’re running? If it’s zsh then putting it in .bashrc
won’t do any good. In that case you have to put it in ~/.zshrc
To find out which shell you’re running execute the following in a terminal:
echo $SHELL
Hope this helps!
oh ok. It is zsh. thanks
You’re welcome!
