In neofetch, the gpu and cpu stats are different than if you visit about in the settings app. Why? I’m seriously confused. I don’t know whether I should trust neofetch, or the about in my settings. Manjaro version 21.1, GNOME version (here, again it changes whether it’s neofetch or about) 40.5 (neofetch), 40.4.0 (about). And I’m on Xorg.
Could you post the result of inxi --admin --verbosity=7 --filter --no-host --width
neofetch finds the versions of gnome reading the output of gnome-shell --version
I would trust the output of neofetch
Edit: The about page in settings has some code that I do not understand well enough to find and display the version of Gnome.
It reads it from /usr/share/gnome/gnome-version.xml
Ah typo in the find file
$ cat /usr/share/gnome/gnome-version.xml
<?xml version="1.0"?>
<gnome-version>
<platform>40</platform>
<minor>4</minor>
<micro>0</micro>
<distributor>Arch Linux</distributor>
<!--<date></date>-->
</gnome-version>%
$ gnome-shell --version
GNOME Shell 40.5
@anon30931146 problably has the same results?
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fc10b8ed-08e3-49d5-852b-e91ea769a8a6 rw quiet udev.log_priority=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: HP product: HP Laptop 15s-du2xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 85F3 v: 40.33 serial: <filter> UEFI: Insyde v: F.43
date: 03/31/2021
ID-1: BAT1 charge: 32.3 Wh (82.4%) condition: 39.2/41.0 Wh (95.5%)
volts: 12.0 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
RAM: total: 3.62 GiB used: 1.34 GiB (36.9%)
Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 4 MiB bogomips: 9524
Speed: 900 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 900 2: 898 3: 970
4: 1001
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 13d3:56c9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:5 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Local Storage: total: 931.51 GiB used: 7.32 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RTM2 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 7.32 GiB (0.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: fc10b8ed-08e3-49d5-852b-e91ea769a8a6
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 2C7C-48A8
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Logitech Wireless Receiver type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 046d:c542 class-ID: 0301
Device-2: 1-5:3 info: IMC Networks HP TrueVision HD Camera type: Video
Device-3: 1-6:4 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c00 class-ID: 0000
Device-4: 1-10:5 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b00c
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.8 C mobo: 10.0 C
Processes: 235 Uptime: 1d 3h 35m wakeups: 26 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 975 lib: 279
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Yes. It says it’s 40.5.
