Kernel: 5.4.163-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cc052236-21f0-4136-a23a-262fdbbc9b5e rw quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: H.00
date: 08/05/2019
Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache:
L1: 768 KiB L2: 4 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 118439
Speed: 4066 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 3989 2: 4075 3: 4073 4: 2038 5: 3225 6: 3200 7: 3047 8: 2040 9: 4074
10: 2039 11: 3117 12: 3694 13: 3505 14: 2042 15: 3800 16: 4078
disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 27:00.0 chip-ID: 10de:2182
class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DP-0 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 27:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457
class-ID: 0403
Device-3: JMTek LLC. Microphone UM350 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:3 chip-ID: 0c76:1476
class-ID: 0300
Sound Server-1: ALSA v: k5.4.163-1-MANJARO running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 436.71 GiB (23.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.38%) used: 436.71 GiB (23.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 57.1 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 51%
Processes: 394 Uptime: 3h 46m wakeups: 0 Memory: 15.64 GiB
used: 8.99 GiB (57.5%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1109 lib: 378 Shell: Bash v: 5.1.12
running-in: xfce4-terminal inxi: 3.3.09
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 495.44
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 495.44
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 495.44
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
[ 81.307]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[ 81.307]
X.Org X Server 1.21.1.1
[ 81.307] Current Operating System: Linux koolkid-2nd-HDD 5.4.163-1-MANJARO #1 SMP PREEMPT Wed Dec 1 14:47:09 UTC 2021 x86_64
[ 81.307] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=cc052236-21f0-4136-a23a-262fdbbc9b5e rw quiet udev.log_priority=3
[ 81.307]
[ 81.307] Current version of pixman: 0.40.0
[ 81.307] Before reporting problems, check http://wiki.x.org
[ 81.307] Markers: (--) probed, (**) from config file, (==) default setting,
[ 81.307] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Dec 12 11:26:55 2021
[ 81.308] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 81.308] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 81.413] (==) ServerLayout "layout"
[ 81.413] (**) |-->Screen "Screen0" (0)
[ 81.413] (**) | |-->Monitor "Monitor0"
[ 81.413] (**) | |-->Device "Device0"
[ 81.413] (==) Automatically adding devices
[ 81.413] (==) Automatically enabling devices
[ 81.413] (==) Automatically adding GPU devices
[ 81.413] (==) Automatically binding GPU devices
[ 81.413] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 81.501] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 81.501] Entry deleted from font path.
[ 81.501] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 81.501] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 81.501] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 81.502] Entry deleted from font path.
[ 81.502] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 81.502] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 81.502] (**) Extension "COMPOSITE" is enabled
[ 81.502] (II) The server relies on udev to provide the list of input devices.
[ 81.502] (II) Module ABI versions:
[ 81.502] X.Org ANSI C Emulation: 0.4
[ 81.502] X.Org Video Driver: 25.2
[ 81.502] X.Org XInput driver : 24.4
[ 81.502] X.Org Server Extension : 10.0
[ 81.502] (++) using VT number 7
[ 81.502] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 81.503] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 81.503] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:27:00.0/drm/card0
[ 81.505] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 81.505] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 81.507] (--) PCI:*(39@0:0:0) 10de:2182:1458:3fbe rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 81.507] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 81.507] (II) LoadModule: "glx"
[ 81.513] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 81.721] (II) Module glx: vendor="X.Org Foundation"
[ 81.721] compiled for 1.21.1.1, module version = 1.0.0
[ 81.721] ABI class: X.Org Server Extension, version 10.0
[ 81.721] (II) LoadModule: "nvidia"
[ 81.722] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 81.914] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 81.914] compiled for 1.6.99.901, module version = 1.0.0
[ 81.914] Module class: X.Org Video Driver
[ 81.914] (II) NVIDIA dlloader X Driver 495.44 Fri Oct 22 06:11:21 UTC 2021
[ 81.914] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 81.916] (II) Loading sub module "fb"
[ 81.916] (II) LoadModule: "fb"
[ 81.916] (II) Module "fb" already built-in
[ 81.916] (II) Loading sub module "wfb"
[ 81.916] (II) LoadModule: "wfb"
[ 81.916] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 81.964] (II) Module wfb: vendor="X.Org Foundation"
[ 81.964] compiled for 1.21.1.1, module version = 1.0.0
[ 81.964] ABI class: X.Org ANSI C Emulation, version 0.4
[ 81.964] (II) Loading sub module "ramdac"
[ 81.964] (II) LoadModule: "ramdac"
[ 81.964] (II) Module "ramdac" already built-in
[ 81.965] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 81.965] (==) NVIDIA(0): RGB weight 888
[ 81.965] (==) NVIDIA(0): Default visual is TrueColor
[ 81.965] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 81.966] (**) Option "AllowNVIDIAGpuScreens"
[ 81.966] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 81.966] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 81.966] (**) NVIDIA(0): Enabling 2D acceleration
[ 81.966] (II) Loading sub module "glxserver_nvidia"
[ 81.966] (II) LoadModule: "glxserver_nvidia"
[ 81.966] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 82.570] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 82.570] compiled for 1.6.99.901, module version = 1.0.0
[ 82.570] Module class: X.Org Server Extension
[ 82.570] (II) NVIDIA GLX Module 495.44 Fri Oct 22 06:08:29 UTC 2021
[ 82.586] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 83.291] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:39:0:0
[ 83.291] (--) NVIDIA(0): DFP-0 (boot)
[ 83.291] (--) NVIDIA(0): DFP-1
[ 83.291] (--) NVIDIA(0): DFP-2
[ 83.291] (--) NVIDIA(0): DFP-3
[ 83.291] (--) NVIDIA(0): DFP-4
[ 83.291] (--) NVIDIA(0): DFP-5
[ 83.291] (--) NVIDIA(0): DFP-6
[ 83.291] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1660 Ti (TU116-A) at PCI:39:0:0
[ 83.291] (II) NVIDIA(0): (GPU-0)
[ 83.291] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 83.291] (--) NVIDIA(0): VideoBIOS: 90.16.20.00.89
[ 83.292] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 83.418] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 83.418] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 83.418] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 83.421] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 83.421] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 83.421] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 83.421] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 83.421] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 83.421] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 83.421] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 83.421] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 83.421] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 83.421] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 83.421] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 83.421] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 83.421] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 83.421] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 83.421] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 83.421] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 83.421] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 83.421] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 83.432] (==) NVIDIA(0):
[ 83.432] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 83.432] (==) NVIDIA(0): will be used as the requested mode.
[ 83.433] (II) NVIDIA(0): Validated MetaModes:
[ 83.433] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 83.433] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1440
[ 83.462] (--) NVIDIA(0): DPI set to (108, 107); computed from "UseEdidDpi" X config
[ 83.462] (--) NVIDIA(0): option
[ 83.462] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 83.462] (II) NVIDIA: access.
[ 83.465] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 83.465] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 83.465] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 83.465] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 83.465] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 83.465] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 83.465] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 83.465] (II) NVIDIA(0): Config Options in the README.
[ 83.503] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 83.668] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 83.668] (==) NVIDIA(0): Backing store enabled
[ 83.668] (==) NVIDIA(0): Silken mouse enabled
[ 83.669] (**) NVIDIA(0): DPMS enabled
[ 83.685] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 83.685] (II) Loading sub module "dri2"
[ 83.685] (II) LoadModule: "dri2"
[ 83.685] (II) Module "dri2" already built-in
[ 83.685] (II) NVIDIA(0): [DRI2] Setup complete
[ 83.685] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 83.685] (II) Initializing extension Generic Event Extension
[ 83.686] (II) Initializing extension SHAPE
[ 83.686] (II) Initializing extension MIT-SHM
[ 83.686] (II) Initializing extension XInputExtension
[ 83.686] (II) Initializing extension XTEST
[ 83.686] (II) Initializing extension BIG-REQUESTS
[ 83.686] (II) Initializing extension SYNC
[ 83.686] (II) Initializing extension XKEYBOARD
[ 83.686] (II) Initializing extension XC-MISC
[ 83.686] (II) Initializing extension SECURITY
[ 83.686] (II) Initializing extension XFIXES
[ 83.686] (II) Initializing extension RENDER
[ 83.686] (II) Initializing extension RANDR
[ 83.686] (II) Initializing extension COMPOSITE
[ 83.686] (II) Initializing extension DAMAGE
[ 83.686] (II) Initializing extension MIT-SCREEN-SAVER
[ 83.687] (II) Initializing extension DOUBLE-BUFFER
[ 83.687] (II) Initializing extension RECORD
[ 83.687] (II) Initializing extension DPMS
[ 83.687] (II) Initializing extension Present
[ 83.687] (II) Initializing extension DRI3
[ 83.687] (II) Initializing extension X-Resource
[ 83.687] (II) Initializing extension XVideo
[ 83.687] (II) Initializing extension XVideo-MotionCompensation
[ 83.687] (II) Initializing extension GLX
[ 83.687] (II) Indirect GLX disabled.
[ 83.687] (II) GLX: Another vendor is already registered for screen 0
[ 83.687] (II) Initializing extension XFree86-VidModeExtension
[ 83.687] (II) Initializing extension XFree86-DGA
[ 83.687] (II) Initializing extension XFree86-DRI
[ 83.687] (II) Initializing extension DRI2
[ 83.687] (II) Initializing extension NV-GLX
[ 83.687] (II) Initializing extension NV-CONTROL
[ 83.687] (II) Initializing extension XINERAMA
[ 83.983] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 83.983] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 83.983] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 83.983] (**) Power Button: Applying InputClass "system-keyboard"
[ 83.983] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 83.983] (II) LoadModule: "libinput"
[ 83.983] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 84.014] (II) Module libinput: vendor="X.Org Foundation"
[ 84.014] compiled for 1.21.1, module version = 1.2.0
[ 84.014] Module class: X.Org XInput Driver
[ 84.014] ABI class: X.Org XInput driver, version 24.4
[ 84.014] (II) Using input driver 'libinput' for 'Power Button'
[ 84.014] (**) Power Button: always reports core events
[ 84.014] (**) Option "Device" "/dev/input/event1"
[ 84.014] (**) Option "_source" "server/udev"
[ 84.034] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 84.035] (II) event1 - Power Button: device is a keyboard
[ 84.035] (II) event1 - Power Button: device removed
[ 84.076] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 84.076] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 84.076] (**) Option "xkb_model" "pc105"
[ 84.076] (**) Option "xkb_layout" "au"
[ 84.076] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.114] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 84.114] (II) event1 - Power Button: device is a keyboard
[ 84.115] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 84.115] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 84.115] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 84.115] (**) Power Button: Applying InputClass "system-keyboard"
[ 84.115] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 84.115] (II) Using input driver 'libinput' for 'Power Button'
[ 84.115] (**) Power Button: always reports core events
[ 84.115] (**) Option "Device" "/dev/input/event0"
[ 84.115] (**) Option "_source" "server/udev"
[ 84.116] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 84.116] (II) event0 - Power Button: device is a keyboard
[ 84.116] (II) event0 - Power Button: device removed
[ 84.143] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 84.143] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 84.143] (**) Option "xkb_model" "pc105"
[ 84.143] (**) Option "xkb_layout" "au"
[ 84.143] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.144] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 84.144] (II) event0 - Power Button: device is a keyboard
[ 84.144] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control (/dev/input/event2)
[ 84.144] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "evdev keyboard catchall"
[ 84.145] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "libinput keyboard catchall"
[ 84.145] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "system-keyboard"
[ 84.145] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: Applying InputClass "Keyboard Defaults"
[ 84.145] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control'
[ 84.145] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control: always reports core events
[ 84.145] (**) Option "Device" "/dev/input/event2"
[ 84.145] (**) Option "_source" "server/udev"
[ 84.146] (II) event2 - Cooler Master Technology Inc. AMD SR4 lamplight Control: is tagged by udev as: Keyboard
[ 84.146] (II) event2 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device is a keyboard
[ 84.146] (II) event2 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device removed
[ 84.183] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-11/1-11:1.0/0003:2516:0051.0001/input/input2/event2"
[ 84.183] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control" (type: KEYBOARD, id 8)
[ 84.183] (**) Option "xkb_model" "pc105"
[ 84.183] (**) Option "xkb_layout" "au"
[ 84.183] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.184] (II) event2 - Cooler Master Technology Inc. AMD SR4 lamplight Control: is tagged by udev as: Keyboard
[ 84.185] (II) event2 - Cooler Master Technology Inc. AMD SR4 lamplight Control: device is a keyboard
[ 84.186] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control System Control (/dev/input/event3)
[ 84.186] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "evdev keyboard catchall"
[ 84.186] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "libinput keyboard catchall"
[ 84.186] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "system-keyboard"
[ 84.186] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: Applying InputClass "Keyboard Defaults"
[ 84.186] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control System Control'
[ 84.186] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: always reports core events
[ 84.186] (**) Option "Device" "/dev/input/event3"
[ 84.186] (**) Option "_source" "server/udev"
[ 84.187] (II) event3 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: is tagged by udev as: Keyboard
[ 84.187] (II) event3 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device is a keyboard
[ 84.188] (II) event3 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device removed
[ 84.223] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-11/1-11:1.2/0003:2516:0051.0003/input/input3/event3"
[ 84.223] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control System Control" (type: KEYBOARD, id 9)
[ 84.223] (**) Option "xkb_model" "pc105"
[ 84.223] (**) Option "xkb_layout" "au"
[ 84.223] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.224] (II) event3 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: is tagged by udev as: Keyboard
[ 84.224] (II) event3 - Cooler Master Technology Inc. AMD SR4 lamplight Control System Control: device is a keyboard
[ 84.225] (II) config/udev: Adding input device Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control (/dev/input/event4)
[ 84.225] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 84.226] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 84.226] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "system-keyboard"
[ 84.226] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: Applying InputClass "Keyboard Defaults"
[ 84.226] (II) Using input driver 'libinput' for 'Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control'
[ 84.226] (**) Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: always reports core events
[ 84.226] (**) Option "Device" "/dev/input/event4"
[ 84.226] (**) Option "_source" "server/udev"
[ 84.227] (II) event4 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: is tagged by udev as: Keyboard
[ 84.227] (II) event4 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device is a keyboard
[ 84.227] (II) event4 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device removed
[ 84.303] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-11/1-11:1.2/0003:2516:0051.0003/input/input4/event4"
[ 84.303] (II) XINPUT: Adding extended input device "Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control" (type: KEYBOARD, id 10)
[ 84.303] (**) Option "xkb_model" "pc105"
[ 84.303] (**) Option "xkb_layout" "au"
[ 84.303] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.304] (II) event4 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: is tagged by udev as: Keyboard
[ 84.304] (II) event4 - Cooler Master Technology Inc. AMD SR4 lamplight Control Consumer Control: device is a keyboard
[ 84.304] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event22)
[ 84.304] (II) No input driver specified, ignoring this device.
[ 84.304] (II) This device may have been added with another device file.
[ 84.305] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event23)
[ 84.305] (II) No input driver specified, ignoring this device.
[ 84.305] (II) This device may have been added with another device file.
[ 84.305] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event24)
[ 84.305] (II) config/udev: Adding input device Razer Razer BlackWidow Elite (/dev/input/event5)
[ 84.305] (**) Razer Razer BlackWidow Elite: Applying InputClass "evdev keyboard catchall"
[ 84.305] (**) Razer Razer BlackWidow Elite: Applying InputClass "libinput keyboard catchall"
[ 84.305] (**) Razer Razer BlackWidow Elite: Applying InputClass "system-keyboard"
[ 84.305] (**) Razer Razer BlackWidow Elite: Applying InputClass "Keyboard Defaults"
[ 84.305] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow Elite'
[ 84.305] (**) Razer Razer BlackWidow Elite: always reports core events
[ 84.305] (**) Option "Device" "/dev/input/event5"
[ 84.305] (**) Option "_source" "server/udev"
[ 84.306] (II) event5 - Razer Razer BlackWidow Elite: is tagged by udev as: Keyboard
[ 84.306] (II) event5 - Razer Razer BlackWidow Elite: device is a keyboard
[ 84.306] (II) event5 - Razer Razer BlackWidow Elite: device removed
[ 84.356] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.1/7-3.1:1.0/0003:1532:0228.0004/input/input5/event5"
[ 84.356] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow Elite" (type: KEYBOARD, id 11)
[ 84.356] (**) Option "xkb_model" "pc105"
[ 84.356] (**) Option "xkb_layout" "au"
[ 84.356] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.358] (II) event5 - Razer Razer BlackWidow Elite: is tagged by udev as: Keyboard
[ 84.358] (II) event5 - Razer Razer BlackWidow Elite: device is a keyboard
[ 84.359] (II) config/udev: Adding input device Razer Razer BlackWidow Elite Keyboard (/dev/input/event6)
[ 84.359] (**) Razer Razer BlackWidow Elite Keyboard: Applying InputClass "evdev keyboard catchall"
[ 84.359] (**) Razer Razer BlackWidow Elite Keyboard: Applying InputClass "libinput keyboard catchall"
[ 84.359] (**) Razer Razer BlackWidow Elite Keyboard: Applying InputClass "system-keyboard"
[ 84.359] (**) Razer Razer BlackWidow Elite Keyboard: Applying InputClass "Keyboard Defaults"
[ 84.359] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow Elite Keyboard'
[ 84.359] (**) Razer Razer BlackWidow Elite Keyboard: always reports core events
[ 84.359] (**) Option "Device" "/dev/input/event6"
[ 84.359] (**) Option "_source" "server/udev"
[ 84.360] (II) event6 - Razer Razer BlackWidow Elite Keyboard: is tagged by udev as: Keyboard
[ 84.360] (II) event6 - Razer Razer BlackWidow Elite Keyboard: device is a keyboard
[ 84.360] (II) event6 - Razer Razer BlackWidow Elite Keyboard: device removed
[ 84.382] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.1/7-3.1:1.1/0003:1532:0228.0005/input/input6/event6"
[ 84.382] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow Elite Keyboard" (type: KEYBOARD, id 12)
[ 84.382] (**) Option "xkb_model" "pc105"
[ 84.382] (**) Option "xkb_layout" "au"
[ 84.382] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.384] (II) event6 - Razer Razer BlackWidow Elite Keyboard: is tagged by udev as: Keyboard
[ 84.384] (II) event6 - Razer Razer BlackWidow Elite Keyboard: device is a keyboard
[ 84.385] (II) config/udev: Adding input device Razer Razer BlackWidow Elite Consumer Control (/dev/input/event7)
[ 84.385] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 84.385] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 84.385] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "system-keyboard"
[ 84.385] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "Keyboard Defaults"
[ 84.385] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow Elite Consumer Control'
[ 84.385] (**) Razer Razer BlackWidow Elite Consumer Control: always reports core events
[ 84.385] (**) Option "Device" "/dev/input/event7"
[ 84.385] (**) Option "_source" "server/udev"
[ 84.386] (II) event7 - Razer Razer BlackWidow Elite Consumer Control: is tagged by udev as: Keyboard
[ 84.387] (II) event7 - Razer Razer BlackWidow Elite Consumer Control: device is a keyboard
[ 84.387] (II) event7 - Razer Razer BlackWidow Elite Consumer Control: device removed
[ 84.436] (II) libinput: Razer Razer BlackWidow Elite Consumer Control: needs a virtual subdevice
[ 84.436] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.1/7-3.1:1.1/0003:1532:0228.0005/input/input7/event7"
[ 84.436] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow Elite Consumer Control" (type: MOUSE, id 13)
[ 84.436] (**) Option "AccelerationScheme" "none"
[ 84.436] (**) Razer Razer BlackWidow Elite Consumer Control: (accel) selected scheme none/0
[ 84.436] (**) Razer Razer BlackWidow Elite Consumer Control: (accel) acceleration factor: 2.000
[ 84.436] (**) Razer Razer BlackWidow Elite Consumer Control: (accel) acceleration threshold: 4
[ 84.438] (II) event7 - Razer Razer BlackWidow Elite Consumer Control: is tagged by udev as: Keyboard
[ 84.438] (II) event7 - Razer Razer BlackWidow Elite Consumer Control: device is a keyboard
[ 84.439] (II) config/udev: Adding input device Razer Razer BlackWidow Elite System Control (/dev/input/event8)
[ 84.439] (**) Razer Razer BlackWidow Elite System Control: Applying InputClass "evdev keyboard catchall"
[ 84.439] (**) Razer Razer BlackWidow Elite System Control: Applying InputClass "libinput keyboard catchall"
[ 84.439] (**) Razer Razer BlackWidow Elite System Control: Applying InputClass "system-keyboard"
[ 84.439] (**) Razer Razer BlackWidow Elite System Control: Applying InputClass "Keyboard Defaults"
[ 84.439] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow Elite System Control'
[ 84.439] (**) Razer Razer BlackWidow Elite System Control: always reports core events
[ 84.439] (**) Option "Device" "/dev/input/event8"
[ 84.439] (**) Option "_source" "server/udev"
[ 84.441] (II) event8 - Razer Razer BlackWidow Elite System Control: is tagged by udev as: Keyboard
[ 84.441] (II) event8 - Razer Razer BlackWidow Elite System Control: device is a keyboard
[ 84.441] (II) event8 - Razer Razer BlackWidow Elite System Control: device removed
[ 84.476] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.1/7-3.1:1.1/0003:1532:0228.0005/input/input8/event8"
[ 84.476] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow Elite System Control" (type: KEYBOARD, id 14)
[ 84.476] (**) Option "xkb_model" "pc105"
[ 84.476] (**) Option "xkb_layout" "au"
[ 84.476] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.478] (II) event8 - Razer Razer BlackWidow Elite System Control: is tagged by udev as: Keyboard
[ 84.478] (II) event8 - Razer Razer BlackWidow Elite System Control: device is a keyboard
[ 84.479] (II) config/udev: Adding input device Razer Razer BlackWidow Elite (/dev/input/event9)
[ 84.479] (II) No input driver specified, ignoring this device.
[ 84.479] (II) This device may have been added with another device file.
[ 84.480] (II) config/udev: Adding input device Razer Razer BlackWidow Elite (/dev/input/event10)
[ 84.480] (**) Razer Razer BlackWidow Elite: Applying InputClass "evdev pointer catchall"
[ 84.480] (**) Razer Razer BlackWidow Elite: Applying InputClass "libinput pointer catchall"
[ 84.480] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow Elite'
[ 84.480] (**) Razer Razer BlackWidow Elite: always reports core events
[ 84.480] (**) Option "Device" "/dev/input/event10"
[ 84.480] (**) Option "_source" "server/udev"
[ 84.537] (II) event10 - Razer Razer BlackWidow Elite: is tagged by udev as: Mouse
[ 84.538] (II) event10 - Razer Razer BlackWidow Elite: device is a pointer
[ 84.538] (II) event10 - Razer Razer BlackWidow Elite: device removed
[ 84.623] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.1/7-3.1:1.2/0003:1532:0228.0006/input/input10/event10"
[ 84.623] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow Elite" (type: MOUSE, id 15)
[ 84.623] (**) Option "AccelerationScheme" "none"
[ 84.623] (**) Razer Razer BlackWidow Elite: (accel) selected scheme none/0
[ 84.623] (**) Razer Razer BlackWidow Elite: (accel) acceleration factor: 2.000
[ 84.623] (**) Razer Razer BlackWidow Elite: (accel) acceleration threshold: 4
[ 84.681] (II) event10 - Razer Razer BlackWidow Elite: is tagged by udev as: Mouse
[ 84.681] (II) event10 - Razer Razer BlackWidow Elite: device is a pointer
[ 84.682] (II) config/udev: Adding input device Razer Razer BlackWidow Elite (/dev/input/mouse0)
[ 84.682] (II) No input driver specified, ignoring this device.
[ 84.682] (II) This device may have been added with another device file.
[ 84.683] (II) config/udev: Adding input device SteelSeries SteelSeries Rival 3 (/dev/input/event11)
[ 84.683] (**) SteelSeries SteelSeries Rival 3: Applying InputClass "evdev pointer catchall"
[ 84.683] (**) SteelSeries SteelSeries Rival 3: Applying InputClass "libinput pointer catchall"
[ 84.683] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Rival 3'
[ 84.683] (**) SteelSeries SteelSeries Rival 3: always reports core events
[ 84.683] (**) Option "Device" "/dev/input/event11"
[ 84.683] (**) Option "_source" "server/udev"
[ 84.741] (II) event11 - SteelSeries SteelSeries Rival 3: is tagged by udev as: Mouse
[ 84.741] (II) event11 - SteelSeries SteelSeries Rival 3: device is a pointer
[ 84.742] (II) event11 - SteelSeries SteelSeries Rival 3: device removed
[ 84.810] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.2/7-3.2:1.0/0003:1038:1824.0007/input/input11/event11"
[ 84.810] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Rival 3" (type: MOUSE, id 16)
[ 84.810] (**) Option "AccelerationScheme" "none"
[ 84.810] (**) SteelSeries SteelSeries Rival 3: (accel) selected scheme none/0
[ 84.810] (**) SteelSeries SteelSeries Rival 3: (accel) acceleration factor: 2.000
[ 84.810] (**) SteelSeries SteelSeries Rival 3: (accel) acceleration threshold: 4
[ 84.867] (II) event11 - SteelSeries SteelSeries Rival 3: is tagged by udev as: Mouse
[ 84.867] (II) event11 - SteelSeries SteelSeries Rival 3: device is a pointer
[ 84.868] (II) config/udev: Adding input device SteelSeries SteelSeries Rival 3 (/dev/input/mouse1)
[ 84.868] (II) No input driver specified, ignoring this device.
[ 84.868] (II) This device may have been added with another device file.
[ 84.869] (II) config/udev: Adding input device SteelSeries SteelSeries Rival 3 Keyboard (/dev/input/event12)
[ 84.869] (**) SteelSeries SteelSeries Rival 3 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 84.869] (**) SteelSeries SteelSeries Rival 3 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 84.869] (**) SteelSeries SteelSeries Rival 3 Keyboard: Applying InputClass "system-keyboard"
[ 84.869] (**) SteelSeries SteelSeries Rival 3 Keyboard: Applying InputClass "Keyboard Defaults"
[ 84.869] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Rival 3 Keyboard'
[ 84.869] (**) SteelSeries SteelSeries Rival 3 Keyboard: always reports core events
[ 84.869] (**) Option "Device" "/dev/input/event12"
[ 84.869] (**) Option "_source" "server/udev"
[ 84.870] (II) event12 - SteelSeries SteelSeries Rival 3 Keyboard: is tagged by udev as: Keyboard
[ 84.870] (II) event12 - SteelSeries SteelSeries Rival 3 Keyboard: device is a keyboard
[ 84.870] (II) event12 - SteelSeries SteelSeries Rival 3 Keyboard: device removed
[ 84.916] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.2/7-3.2:1.1/0003:1038:1824.0008/input/input12/event12"
[ 84.916] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Rival 3 Keyboard" (type: KEYBOARD, id 17)
[ 84.916] (**) Option "xkb_model" "pc105"
[ 84.916] (**) Option "xkb_layout" "au"
[ 84.916] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.918] (II) event12 - SteelSeries SteelSeries Rival 3 Keyboard: is tagged by udev as: Keyboard
[ 84.918] (II) event12 - SteelSeries SteelSeries Rival 3 Keyboard: device is a keyboard
[ 84.919] (II) config/udev: Adding input device SteelSeries SteelSeries Rival 3 Consumer Control (/dev/input/event13)
[ 84.919] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 84.919] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 84.919] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "system-keyboard"
[ 84.919] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "Keyboard Defaults"
[ 84.919] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Rival 3 Consumer Control'
[ 84.919] (**) SteelSeries SteelSeries Rival 3 Consumer Control: always reports core events
[ 84.919] (**) Option "Device" "/dev/input/event13"
[ 84.919] (**) Option "_source" "server/udev"
[ 84.921] (II) event13 - SteelSeries SteelSeries Rival 3 Consumer Control: is tagged by udev as: Keyboard
[ 84.921] (II) event13 - SteelSeries SteelSeries Rival 3 Consumer Control: device is a keyboard
[ 84.921] (II) event13 - SteelSeries SteelSeries Rival 3 Consumer Control: device removed
[ 84.970] (II) libinput: SteelSeries SteelSeries Rival 3 Consumer Control: needs a virtual subdevice
[ 84.970] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.2/7-3.2:1.1/0003:1038:1824.0008/input/input13/event13"
[ 84.970] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Rival 3 Consumer Control" (type: MOUSE, id 18)
[ 84.970] (**) Option "AccelerationScheme" "none"
[ 84.970] (**) SteelSeries SteelSeries Rival 3 Consumer Control: (accel) selected scheme none/0
[ 84.970] (**) SteelSeries SteelSeries Rival 3 Consumer Control: (accel) acceleration factor: 2.000
[ 84.970] (**) SteelSeries SteelSeries Rival 3 Consumer Control: (accel) acceleration threshold: 4
[ 84.971] (II) event13 - SteelSeries SteelSeries Rival 3 Consumer Control: is tagged by udev as: Keyboard
[ 84.971] (II) event13 - SteelSeries SteelSeries Rival 3 Consumer Control: device is a keyboard
[ 84.971] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event15)
[ 84.971] (II) No input driver specified, ignoring this device.
[ 84.971] (II) This device may have been added with another device file.
[ 84.971] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event16)
[ 84.972] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event17)
[ 84.972] (II) No input driver specified, ignoring this device.
[ 84.972] (II) This device may have been added with another device file.
[ 84.972] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event18)
[ 84.972] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event19)
[ 84.972] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event20)
[ 84.972] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event21)
[ 84.973] (II) config/udev: Adding input device PC Speaker (/dev/input/event14)
[ 84.973] (II) No input driver specified, ignoring this device.
[ 84.973] (II) This device may have been added with another device file.
[ 84.975] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 84.975] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 84.975] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "system-keyboard"
[ 84.975] (**) Razer Razer BlackWidow Elite Consumer Control: Applying InputClass "Keyboard Defaults"
[ 84.975] (II) Using input driver 'libinput' for 'Razer Razer BlackWidow Elite Consumer Control'
[ 84.975] (**) Razer Razer BlackWidow Elite Consumer Control: always reports core events
[ 84.975] (**) Option "Device" "/dev/input/event7"
[ 84.975] (**) Option "_source" "_driver/libinput"
[ 84.975] (II) libinput: Razer Razer BlackWidow Elite Consumer Control: is a virtual subdevice
[ 84.975] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.1/7-3.1:1.1/0003:1532:0228.0005/input/input7/event7"
[ 84.975] (II) XINPUT: Adding extended input device "Razer Razer BlackWidow Elite Consumer Control" (type: KEYBOARD, id 19)
[ 84.975] (**) Option "xkb_model" "pc105"
[ 84.975] (**) Option "xkb_layout" "au"
[ 84.975] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 84.975] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 84.975] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 84.975] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "system-keyboard"
[ 84.975] (**) SteelSeries SteelSeries Rival 3 Consumer Control: Applying InputClass "Keyboard Defaults"
[ 84.975] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Rival 3 Consumer Control'
[ 84.975] (**) SteelSeries SteelSeries Rival 3 Consumer Control: always reports core events
[ 84.975] (**) Option "Device" "/dev/input/event13"
[ 84.975] (II) libinput: SteelSeries SteelSeries Rival 3 Consumer Control: is a virtual subdevice
[ 84.975] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb7/7-3/7-3.2/7-3.2:1.1/0003:1038:1824.0008/input/input13/event13"
[ 84.975] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Rival 3 Consumer Control" (type: KEYBOARD, id 20)
[ 90.041] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 90.041] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 90.041] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 90.044] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 90.044] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 90.044] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 90.044] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 90.044] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 90.044] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 90.044] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 90.044] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 90.044] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 90.044] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 90.044] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 90.044] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 90.044] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 90.044] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 90.044] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 90.045] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 90.045] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 90.045] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 90.114] (II) NVIDIA(0): Setting mode "DP-0: 2560x1440_144 @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 94.535] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 94.535] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 94.535] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 94.537] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 94.537] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 94.537] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 94.538] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 94.538] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 94.538] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 94.538] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 94.538] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 94.538] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 94.538] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 94.538] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 94.538] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 94.538] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 94.538] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 94.538] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 94.538] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 94.538] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 94.538] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 97.314] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 97.314] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 97.314] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 97.317] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 97.317] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 97.317] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 97.317] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 97.317] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 97.317] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 97.317] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 97.317] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 97.317] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 97.317] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 97.317] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 97.317] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 97.317] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 97.317] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 97.317] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 97.317] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 97.317] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 97.317] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 112.332] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 112.332] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 112.332] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 112.334] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 112.334] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 112.334] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 112.335] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 112.335] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 112.335] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 112.335] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 112.335] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 112.335] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 112.335] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 112.335] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 112.335] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 112.335] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 112.335] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 112.335] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 112.335] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 112.335] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 112.335] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 137.358] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 137.358] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 137.358] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 137.361] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 137.361] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 137.361] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 137.361] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 137.361] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 137.361] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 137.361] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 137.361] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 137.361] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 137.361] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 137.361] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 137.361] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 137.361] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 137.362] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 137.362] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 137.362] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 137.362] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 137.362] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 221.239] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 221.239] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 221.239] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 221.242] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 221.242] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 221.242] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 221.242] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 221.242] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 221.242] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 221.242] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 221.242] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 221.242] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 221.243] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 221.243] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 221.243] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 221.243] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 221.243] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 221.243] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 221.243] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 221.243] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 221.243] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 279.132] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 279.132] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 279.132] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 279.135] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 279.135] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 279.135] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 279.135] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 279.135] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 279.135] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 279.135] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 279.135] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 279.135] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 279.135] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 279.135] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 279.135] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 279.135] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 279.135] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 279.135] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 279.135] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 279.135] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 279.136] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 836.537] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 17ms, your system is too slow
[ 865.974] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 21ms, your system is too slow
[ 885.543] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 37ms, your system is too slow
[ 1222.084] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 24ms, your system is too slow
[ 1332.649] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 19ms, your system is too slow
[ 1332.649] (EE) event5 - Razer Razer BlackWidow Elite: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 4518.223] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 16ms, your system is too slow
[ 4550.079] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 19ms, your system is too slow
[ 5038.481] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 21ms, your system is too slow
[ 5139.402] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 26ms, your system is too slow
[ 5169.517] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 34ms, your system is too slow
[ 5169.517] (EE) event5 - Razer Razer BlackWidow Elite: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 9553.571] (II) config/udev: Adding input device Microphone UM350 (/dev/input/event25)
[ 9553.571] (**) Microphone UM350: Applying InputClass "evdev keyboard catchall"
[ 9553.571] (**) Microphone UM350: Applying InputClass "libinput keyboard catchall"
[ 9553.571] (**) Microphone UM350: Applying InputClass "system-keyboard"
[ 9553.571] (**) Microphone UM350: Applying InputClass "Keyboard Defaults"
[ 9553.571] (II) Using input driver 'libinput' for 'Microphone UM350'
[ 9553.571] (**) Microphone UM350: always reports core events
[ 9553.571] (**) Option "Device" "/dev/input/event25"
[ 9553.571] (**) Option "_source" "server/udev"
[ 9553.572] (II) event25 - Microphone UM350: is tagged by udev as: Keyboard
[ 9553.572] (II) event25 - Microphone UM350: device is a keyboard
[ 9553.573] (II) event25 - Microphone UM350: device removed
[ 9553.629] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-3/1-3:1.2/0003:0C76:1476.000B/input/input25/event25"
[ 9553.629] (II) XINPUT: Adding extended input device "Microphone UM350" (type: KEYBOARD, id 21)
[ 9553.629] (**) Option "xkb_model" "pc105"
[ 9553.629] (**) Option "xkb_layout" "au"
[ 9553.629] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9553.631] (II) event25 - Microphone UM350: is tagged by udev as: Keyboard
[ 9553.631] (II) event25 - Microphone UM350: device is a keyboard
[ 10114.012] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 16ms, your system is too slow
[ 10139.500] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 21ms, your system is too slow
[ 10222.844] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 22ms, your system is too slow
[ 10243.126] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 34ms, your system is too slow
[ 10350.938] (EE) event5 - Razer Razer BlackWidow Elite: client bug: event processing lagging behind by 29ms, your system is too slow
[ 10350.938] (EE) event5 - Razer Razer BlackWidow Elite: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 13576.124] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): connected
[ 13576.124] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): Internal DisplayPort
[ 13576.124] (--) NVIDIA(GPU-0): AUS PG279QE (DFP-0): 2660.0 MHz maximum pixel clock
[ 13576.126] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 13576.126] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 13576.126] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 13576.126] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 13576.126] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 13576.126] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 13576.127] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 13576.127] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 13576.127] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 13576.127] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 13576.127] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 13576.127] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 13576.127] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 13576.127] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 13576.127] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 13576.127] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 13576.127] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 13576.127] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
