Hi. ZFS is dropped. Now there is a task to replace it. My NAS is running Manjaro on SSD and also has two ZFS mirrored HDD for data. Can you, please, advise the way to overcome this mankind-eliminating event? In particular, what to use for HDDs mirroring?
And I am ready to replace HDDs with another HDD pair on occasion. So, to migrate, 2 + 2 HDDs can be mounted simultaneously, I guess.
btrfs has mostly the same features as zfs, and it’s part of the kernel, so you don’t need any special drivers. It supports mirroring and striping, albeit not RAID 5 or 6.
I’m currently working on pre-compiled ZFS modules for all major kernel series we support. There was a problem on how to compile the modules. So lets see how that goes.
A motherboard has got four SATA socket only. So, the first one is used for boot/system SSD, 2d and 3d ones for ZFS mirror, and I need two to configure btrfs raid1. The question: is it safe for data to disconnect one of ZFS drives to free SATA slot?
That’s not quite accurate. My current board has 6 SATA ports, for example, and the board previous to that had 8 SATA ports. There was a time when 4 SATA ports were more or less standard, but that was many years ago.
That said, it’s not unheard of to find the occasional low budget board with only 4 SATA ports, but they seem few, and far between.
Sorry, I’m sure you know my hardware much better than I do. But with the motherboard… Well, you can be sure yourself, it is MSI H110M Pro-D. It isn’t too dated (6G SATA) and is sufficient for NAS.
