It looks to me like your computer screen goes into Standby mode and stays black while the GRUB menu comes up, and then selects the default (or last) choice after the timer runs out.
The monitor doesn’t recognize the signal quickly enough during that process. I have the exact same problem with my ASUS TUF Monitor when dual booting.
Try turning off the timer entirely, and make it wait for a selection. A way of testing this, is after the “No Signal”, when the screen goes black (standby mode), try tapping the up and down arrows a couple of times… that disables the timer on the GRUB selection by selecting a different option.
yeah, but there is no POST screen and GRUB menu on first reboot. so i cannot choose windows from GRUB menu or even enter BIOS setup, it’s appear on second boot.
i understand. enabling or disabling Fast Startup (hibernation) on windows should in no way affect how Linux reboots. It’s disabled anyway.
i think i started in the wrong way. forget GRUB , let’s focus on POST (power-on self test)
Before I finally give up I will write it again in a different way.
The computer is off → I boot the computer → POST screen appears with ASUS ROG logo (I can then go into bios settings) → linux loads. then I reboot and there is no POST screen anymore but linux starts right away, I give another reboot and I have a POST screen and then a menu appears with system selection (GRUB). I shut down the computer.
The computer is shut down → I start the computer → POST screen (power-on self test) screen appears with ASUS ROG logo (I can then enter bios settings), from GRUB menu I select WIndows - windows loads. I give restart and POST screen appears and then GRUB menu appears and I can choose which system I want to boot. and so every time unlike Linux where I have to reboot twice.
question - why i don’t have POST screen on linux after every reboot and on windows i do?
i can also live with it. it is not terribly inconvenient.
Clearly, you still don’t understand. Still, it’s good that it’s disabled (not every Windows ships with it enabled, which is why we have to ask).
You might find the following link useful (parts of it, at least, as you’re already installed); a guide for those wishing to multiboot Linux and Windows; and avoid some of the pitfalls;
after i noticed that on reset there is the same symptom i tried alt+ctrl+del a couple of times as the systems selection menu is displayed and one time it doesn’t show POST and the menu, as i tried press the keys then i have interrupted the GRUB menu countdown and after enter it goes on. for some reason the graphics or the monitor has a problem on startup. unfortunately i don’t have DP cable to check on another output from the graphics card…
which means i am almost sure now that it is not a Manjaro/Linux issue.
