Need some help with ttf-unifont when upgrading package from ttf-unifont 15.0.06-1 to ttf-unifont 15.1.02-1
I’m upgrading ttf-unifont using yay but I’m getting an error while compiling. Can anyone help me with this issue?
==> ERROR: A failure occurred in build().
    Aborting...
 -> error making: ttf-unifont-exit status 4
 -> Failed to install the following packages. Manual intervention is required:
ttf-unifont - exit status 4
Do you already have ttf-unifont.otf?
The TTF equivilents of OTF fonts can be built manually:
cd /usr/share/fonts
make truetype
That seems to be all that’s needed.
This information came from ttf-unifont 15.1.02-1 (AUR), which is where you could direct some queries.
I have both TTF and OTF installed on my system.
Isn’t OTF simply a better, more extended format that came after TTF?
OTF is always the better of the two… so I’d keep that and remove the TTF.
Generally, yes.
However, I’d sometimes question the O in OTF, considering the major players involved.
OpenType also flaunts its cross-platform support … (Win and Mac).
Notice anything missing? :thinking:
Stuck in the '90s there, you either have a PC or a Mac… and if you are lucky, you can afford a nice Nokia to go with them.
I knew someone in the 90’s who had both a PC and a Mac …
– oh, and a lovely pair of Nokia’s.
