I use Manjaro XFCE on my laptop. When I install it, the bluetooth icon in system tray is grayed out and bluetooth is turned off, as it should be. This didn’t change when I would reboot the system. However, a few weeks ago I wanted to use bluetooth and turned it on via sys tray. It said that bluetooth was turned on and that the device was discoverable, but I couldn’t find it with my mobile phones.
Since it didn’t work, I decided to turn it off, just in case. I did that, but after the system reboot bluetooth always turns itself on again. It is as if it doesn’t remember the setting that it was turned off before the reboot.
So, I have two issues with bluetooth: 1) It doesn’t work (isn’t discoverable) when I turn it on, and 2) when I turn it on, and then off, it will turn itself on again after every reboot.
Could somebody please help me with this? It would be great to make it actually work, but if it’s impossible at least to turn it off permanently.
Here’s my inxi information:
inxi --admin --verbosity=7 --filter --no-host
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=cb49953e-eae1-4982-9570-d02268d3470e rw
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Portable System: Dell product: Inspiron 3521 v: A05 serial: <filter>
Chassis: type: 8 v: A05 serial: <filter>
Mobo: Dell model: 06X37M v: A00 serial: <filter> UEFI [Legacy]: Dell
v: A05 date: 01/03/2013
ID-1: BAT1 charge: N/A condition: N/A volts: 1.7/11.1
model: Simplo DELL 4DMNG31N type: Unknown serial: <filter> status: Unknown
RAM: total: 3.72 GiB used: 2.39 GiB (64.3%)
RAM Report:
Info: Dual Core model: Intel Core i5-3337U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB bogomips: 14373
Speed: 1373 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 959 2: 1369
3: 837 4: 815
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: AMD Mars [Radeon HD 8730M] vendor: Dell driver: radeon v: kernel
alternate: amdgpu bus ID: 01:00.0 chip ID: 1002:6601
Device-3: Suyin Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-1.4:5 chip ID: 064e:812e
Display: x11 server: X.Org 1.20.10 driver: ati,intel,radeon
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 2000 bus ID: 07:00.0 chip ID: 10ec:8136
IF: enp7s0 state: down mac: <filter>
Device-2: Broadcom and subsidiaries BCM43142 802.11b/g/n
vendor: Dell Wireless 1704 802.11n + BT 4.0 driver: wl v: kernel
modules: bcma port: 2000 bus ID: 08:00.0 chip ID: 14e4:4365
IF: wlp8s0 state: up mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Local Storage: total: 931.51 GiB used: 143.78 GiB (15.4%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0004 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU70N rev: A103
dev-links: cdrom
ID-1: / raw size: 287.11 GiB size: 281.60 GiB (98.08%)
used: 143.73 GiB (51.0%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: cb49953e-eae1-4982-9570-d02268d3470e
ID-1: swap-1 type: partition size: 19.53 GiB used: 53.8 MiB (0.3%)
priority: -2 dev: /dev/sda3 label: N/A
uuid: 6a765991-9350-4e72-86d4-cbbc3dd95a50
ID-1: /dev/sda1 size: 361.43 GiB fs: ntfs label: N/A
uuid: 0AD8440D3038FA7B
ID-2: /dev/sda4 size: 263.44 GiB fs: ext4 label: N/A
uuid: ea8832ac-fae7-4539-9556-41ead3ad4f2b
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:0024
Device-1: 1-1.1:3 info: Broadcom BCM43142 Bluetooth 4.0
type: <vendor specific> driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 0a5c:21d7 serial: <filter>
Device-2: 1-1.3:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-3: 1-1.4:5 info: Suyin Laptop_Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 064e:812e
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 47.0 C mobo: N/A gpu: radeon temp: 43.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 217 Uptime: 25m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1382 lib: 393 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.08
