What’s the output of pidof pacman
Nothing. Doesn’t output anything.
What’s the output of sudo fuser /var/lib/pacman/db.lck
Specified filename doesn’t exist.
Should I reinstall pacman?
This is the entire output?
I don’t think you should, at least not yet.
Yes that’s the entire output. I checked again.
Does sudo pacman -Syyu
do anything different?
:: Synchronizing package databases... error: failed retrieving file 'core.db' from [mirror.chmuri.net](http://mirror.chmuri.net/) : The requested URL returned error: 502 core 171.4 KiB 736 KiB/s 00:00 [###################################] 100% error: failed retrieving file 'extra.db' from [mirror.chmuri.net](http://mirror.chmuri.net/) : The requested URL returned error: 502 extra 2007.3 KiB 2.87 MiB/s 00:01 [###################################] 100% error: failed retrieving file 'community.db' from [mirror.chmuri.net](http://mirror.chmuri.net/) : The requested URL returned error: 502 community 6.1 MiB 1213 KiB/s 00:05 [###################################] 100% error: failed retrieving file 'multilib.db' from [mirror.chmuri.net](http://mirror.chmuri.net/) : The requested URL returned error: 502 multilib 195.2 KiB 1276 KiB/s 00:00 [###################################] 100% :: Starting full system upgrade... warning: accountsservice: local (0.6.55-3) is newer than extra (0.6.55-2) warning: amd-ucode: local (20201005.r1732.58d41d0-1) is newer than core (20200716.r1675.1d1c80b-1) warning: apache: local (2.4.46-2) is newer than extra (2.4.43-1) warning: appstream-glib: local (0.7.18-1) is newer than extra (0.7.17-1) warning: apr-util: local (1.6.1-8) is newer than extra (1.6.1-7) warning: archlinux-appstream-data: local (20200720-1.1) is newer than extra (20200612-1.1) warning: archlinux-keyring: local (20200820-1) is newer than core (20200622-1) warning: at-spi2-core: local (2.36.1-1) is newer than extra (2.36.0-1) warning: bluez: local (5.55-1) is newer than extra (5.54-2) warning: bluez-libs: local (5.55-1) is newer than extra (5.54-2) warning: bmenu: local (0.14-1) is newer than community (0.13-1) warning: brotli: local (1.0.9-2) is newer than community (1.0.7-3) warning: ca-certificates: local (20181109-4) is newer than core (20181109-3) warning: ca-certificates-mozilla: local (3.57-1) is newer than core (3.54-1) warning: ca-certificates-utils: local (20181109-4) is newer than core (20181109-3) warning: chromaprint: local (1.5.0-2) is newer than extra (1.5.0-1) warning: cifs-utils: local (6.11-1) is newer than extra (6.10-1) warning: cmus: local (2.8.0-5) is newer than community (2.8.0-4) warning: cryptsetup: local (2.3.4-1) is newer than core (2.3.3-1) warning: cups: local (2.3.3-3) is newer than extra (2.3.3-1) warning: cups-filters: local (1.28.3-1) is newer than extra (1.27.5-1) warning: curl: local (7.72.0-2) is newer than core (7.71.1-1) warning: dash: local (0.5.11.2-1) is newer than core (0.5.11-1) warning: dconf: local (0.38.0-1) is newer than extra (0.36.0-1) warning: dhcpcd: local (9.2.0-1) is newer than core (9.1.4-2) warning: dnsmasq: local (2.82-2) is newer than extra (2.81-4) warning: duplicity: local (0.8.15-1) is newer than community (0.8.12-1) warning: e2fsprogs: local (1.45.6-3) is newer than core (1.45.6-2) warning: efibootmgr: local (17-2) is newer than core (17-1) warning: enchant: local (2.2.10-1) is newer than extra (2.2.8-3) warning: evolution-data-server: local (3.36.5-1) is newer than extra (3.36.4-1) warning: exiv2: local (0.27.3-1) is newer than extra (0.27.2-2) warning: f2fs-tools: local (1.14.0-1) is newer than extra (1.13.0-2) warning: ffmpeg: local (2:4.3.1-2) is newer than extra (2:4.2.4-1) warning: file-roller: local (3.36.3-1) is newer than extra (3.36.2-1) warning: filesystem: local (2020.09-2) is newer than core (2020.05-1) warning: firefox: local (81.0.2-1) is newer than extra (78.0.2-1) warning: firefox-gnome-theme-maia: local (20200804-1) is newer than community (20200211-2) warning: fluidsynth: local (2.1.5-2) is newer than extra (2.1.4-1) warning: foomatic-db: local (3:20200822-1) is newer than extra (3:20200529-1) warning: fuse-common: local (3.9.3-1) is newer than extra (3.9.2-1) warning: fuse3: local (3.9.3-1) is newer than extra (3.9.2-1) warning: fzf: local (0.22.0-1) is newer than community (0.21.1-2) warning: gamemode: local (1.6-4) is newer than community (1.5.1-1) warning: gdm: local (3.36.3-7) is newer than extra (3.36.3-1) warning: geary: local (1:3.36.3.1-1) is newer than community (1:3.36.2-1) warning: gettext: local (0.21-1) is newer than core (0.20.2-1) warning: ghostscript: local (9.53.2-1) is newer than extra (9.52-1) warning: git: local (2.28.0-1) is newer than extra (2.27.0-1) warning: glib-networking: local (2.66.0-1) is newer than extra (2.64.3-2) warning: glib2: local (2.66.0-1) is newer than core (2.64.4-1) warning: glibc: local (2.32-4) is newer than core (2.31-5) warning: gnome-desktop: local (1:3.36.6-1) is newer than extra (1:3.36.4-1) warning: gnome-disk-utility: local (3.36.3-1) is newer than extra (3.36.1-2) warning: gnome-layout-switcher: local (0.8.11-1) is newer than community (0.8.9-1) warning: gnome-shell: local (1:3.36.6-1) is newer than extra (1:3.36.4-1) warning: gnome-shell-extension-appindicator: local (34-1) is newer than community (33-1) warning: gnome-shell-extension-arc-menu: local (1:48+Stable-1) is newer than community (1:47+Stable-1) warning: gnome-shell-extension-dash-to-dock: local (68-1) is newer than community (67-7) warning: gnome-shell-extension-dash-to-panel: local (39.r3.g23d22bd-1) is newer than community (v37+70+geff0322-1) warning: gnome-shell-extension-desktop-icons-ng: local (0.13.0-1) is newer than community (0.11.0-1) warning: gnome-shell-extension-gsconnect: local (42-1) is newer than community (38-1) warning: gnome-shell-extension-nightthemeswitcher: local (37.r0.g10c329c-1) is newer than community (31.r1.g0d32907-1) warning: gnome-shell-extension-unite: local (42.r1.gb72f464-1) is newer than community (41.r5.gd523b3d-1) warning: gnome-shell-extensions: local (3.36.5-1) is newer than extra (3.36.2-1) warning: gnome-user-docs: local (3.36.6-1) is newer than extra (3.36.2-1) warning: gnupg: local (2.2.23-1) is newer than core (2.2.21-1) warning: gnutls: local (3.6.15-1) is newer than core (3.6.14-2) warning: gobject-introspection-runtime: local (1.66.0-1) is newer than extra (1.64.1-2) warning: gpgme: local (1.14.0-1) is newer than core (1.13.1-7) warning: gpm: local (1.20.7.r38.ge82d1a6-2) is newer than core (1.20.7.r27.g1fd1941-2) warning: grilo: local (0.3.13-1) is newer than extra (0.3.12-1) warning: grilo-plugins: local (1:0.3.12-1) is newer than extra (0.3.11+4+g11cc1f8-1) warning: grub: local (2.04-11.1) is newer than core (2.04-10) warning: gsettings-desktop-schemas: local (3.38.0-1) is newer than extra (3.36.1-1) warning: gst-libav: local (1.18.0-1) is newer than extra (1.16.2-2) warning: gst-plugin-gtk: local (1.18.0-1) is newer than extra (1.16.2-3) warning: gst-plugins-bad: local (1.18.0-2) is newer than extra (1.16.2-13) warning: gst-plugins-bad-libs: local (1.18.0-2) is newer than extra (1.16.2-13) warning: gst-plugins-base: local (1.18.0-1) is newer than extra (1.16.2-2) warning: gst-plugins-base-libs: local (1.18.0-1) is newer than extra (1.16.2-2) warning: gst-plugins-good: local (1.18.0-1) is newer than extra (1.16.2-3) warning: gst-plugins-ugly: local (1.18.0-1) is newer than extra (1.16.2-3) warning: gst-python: local (1.18.0-1) is newer than extra (1.16.2-2) warning: gstreamer: local (1.18.0-1) is newer than extra (1.16.2-2) warning: gthumb: local (3.10.0-2) is newer than extra (3.10.0-1) warning: gtk-update-icon-cache: local (1:3.24.23-1) is newer than extra (1:3.24.21-1) warning: gtk3: local (1:3.24.23-1) is newer than extra (1:3.24.21-1) warning: gtkhash: local (1.4-4) is newer than community (1.4-2) warning: gtkhash-nautilus: local (1.4-4) is newer than community (1.4-2) warning: gufw: local (20.04.1-2) is newer than community (20.04.1-1.1) warning: gupnp: local (1.2.4-1) is newer than extra (1.2.3-1) warning: gupnp-av: local (0.12.11+3+g2123c81-1) is newer than extra (0.12.11+2+gb5ca07c-2) warning: gupnp-igd: local (1.2.0-1) is newer than extra (0.2.5+3+gedd78a6-3) warning: harfbuzz: local (2.7.2-1) is newer than extra (2.6.8-2) warning: harfbuzz-icu: local (2.7.2-1) is newer than extra (2.6.8-2) warning: highlight: local (3.58-1) is newer than community (3.57-1) warning: hplip: local (1:3.20.6-3) is newer than extra (1:3.20.6-2) warning: hwids: local (20200813.1-1) is newer than core (20200306-1) warning: iana-etc: local (20200905-1) is newer than core (20200707-1) warning: imagemagick: local (7.0.10.30-1) is newer than extra (7.0.10.23-1) warning: imlib2: local (1.7.0-1) is newer than extra (1.6.1-2) warning: inxi: local (3.1.05+2-1) is newer than community (3.0.37-1) warning: iproute2: local (5.8.0-1) is newer than core (5.7.0-1) warning: iputils: local (20200821-1) is newer than core (20190709-2) warning: iw: local (5.8-1) is newer than core (5.4-1) warning: jbig2dec: local (0.19-1) is newer than extra (0.18-1) warning: js68: local (68.12.0-1) is newer than extra (68.10.0-1) warning: json-c: local (0.15-1) is newer than core (0.14-4) warning: json-glib: local (1.6.0-1) is newer than extra (1.4.4-2) warning: kauth: local (5.74.0-1) is newer than extra (5.72.0-1) warning: kbd: local (2.3.0-2) is newer than core (2.2.0-5) warning: kcoreaddons: local (5.74.0-1) is newer than extra (5.72.0-1) warning: kitemmodels: local (5.74.0-1) is newer than extra (5.72.0-1) warning: kmod: local (27-2) is newer than core (27-1) warning: kvantum-qt5: local (0.16.1-1) is newer than community (0.15.3-1) warning: kwindowsystem: local (5.74.0-1) is newer than extra (5.72.0-1) warning: ldb: local (1:2.1.4-1) is newer than extra (1:2.1.3-1) warning: lib32-fluidsynth: local (2.1.5-1) is newer than multilib (2.1.4-1) warning: lib32-gcc-libs: local (10.2.0-2) is newer than core (10.1.0-2) warning: lib32-glib2: local (2.66.0-1) is newer than multilib (2.64.4-1) warning: lib32-glibc: local (2.32-4) is newer than core (2.31-5) warning: lib32-libcap: local (2.43-1) is newer than multilib (2.37-1) warning: lib32-libx11: local (1.6.12-1) is newer than multilib (1.6.9-1) warning: lib32-llvm-libs: local (10.0.1-1) is newer than multilib (10.0.0-1) warning: lib32-mesa: local (20.1.8-1) is newer than multilib (20.1.3-1) warning: lib32-mesa-vdpau: local (20.1.8-1) is newer than multilib (20.1.3-1) warning: lib32-systemd: local (246.6-1) is newer than multilib (245.6-0.1) warning: lib32-util-linux: local (2.36-1) is newer than multilib (2.35.2-1) warning: lib32-vulkan-intel: local (20.1.8-1) is newer than multilib (20.1.3-1) warning: lib32-vulkan-radeon: local (20.1.8-1) is newer than multilib (20.1.3-1) warning: lib32-zstd: local (1.4.5-1) is newer than multilib (1.4.4-2) warning: libbytesize: local (2.4-1) is newer than extra (2.3-1) warning: libcap: local (2.43-1) is newer than core (2.37-1) warning: libcap-ng: local (0.7.11-2) is newer than core (0.7.10-1) warning: libcups: local (2.3.3-3) is newer than extra (2.3.3-1) warning: libdazzle: local (3.38.0-1) is newer than extra (3.36.0-1) warning: libde265: local (1.0.7-1) is newer than extra (1.0.5-2) warning: libedit: local (20191231_3.1-2) is newer than core (20191231_3.1-1) warning: libevdev: local (1.9.1-1) is newer than extra (1.9.0-1) warning: libevent: local (2.1.12-1) is newer than core (2.1.11-5) warning: libfprint: local (1.90.3-1) is newer than extra (1.90.2-1) warning: libgdm: local (3.36.3-7) is newer than extra (3.36.3-1) warning: libgpg-error: local (1.39-1) is newer than core (1.38-1) warning: libgudev: local (234-1) is newer than extra (233-2) warning: libgusb: local (0.3.5-1) is newer than extra (0.3.4-1) warning: libidn: local (1.36-1) is newer than extra (1.35-3) warning: libinput: local (1.16.1-1) is newer than extra (1.15.6-1) warning: libjpeg-turbo: local (2.0.5-2) is newer than extra (2.0.5-1) warning: libksba: local (1.4.0-2) is newer than core (1.4.0-1) warning: libldap: local (2.4.53-1) is newer than core (2.4.50-2) warning: liblouis: local (3.15.0-1) is newer than extra (3.14.0-1) warning: libmediainfo: local (20.08-1) is newer than community (20.03-1) warning: libmfx: local (20.2.1-1) is newer than community (20.2.0-1) warning: libmicrodns: local (0.2.0-1) is newer than extra (0.1.2-1) warning: libmm-glib: local (1.14.2-1) is newer than extra (1.14.0-1) warning: libmwaw: local (0.3.17-1) is newer than extra (0.3.16-1) warning: libnm: local (1.26.2-1) is newer than extra (1.24.2-1) warning: libnsl: local (1.3.0-1) is newer than core (1.2.0-2) warning: libp11-kit: local (0.23.21-1) is newer than core (0.23.20-5) warning: libpgm: local (5.3.128-1) is newer than community (5.2.122-5) warning: libphonenumber: local (8.12.7-1) is newer than extra (8.12.3-1) warning: libpipeline: local (1.5.3-1) is newer than core (1.5.2-1) warning: libpsl: local (0.21.1-1) is newer than core (0.21.0-2) warning: libqmi: local (1.26.4-1) is newer than extra (1.26.0-1) warning: libreoffice-still: local (6.4.6-2) is newer than extra (6.3.6-2) warning: libspectre: local (0.2.9-2) is newer than extra (0.2.9-1) warning: libssh: local (0.9.5-1) is newer than extra (0.9.4-1) warning: libsynctex: local (2020.54586-5) is newer than extra (2020.54586-4) warning: libteam: local (1.31-1) is newer than extra (1.30-1) warning: libtool: local (2.4.6+42+gb88cebd5-14) is newer than core (2.4.6+42+gb88cebd5-13) warning: libva: local (2.9.0-1) is newer than extra (2.8.0-1) warning: libva-mesa-driver: local (20.1.8-1) is newer than extra (20.1.3-1) warning: libvpx: local (1.9.0-1) is newer than extra (1.8.2-2) warning: libwacom: local (1.5-1) is newer than extra (1.4.1-1) warning: libwpe: local (1.8.0-1) is newer than extra (1.6.0-1) warning: libwps: local (0.4.12-1) is newer than extra (0.4.11-1) warning: libx11: local (1.6.12-1) is newer than extra (1.6.9-7) warning: libxkbcommon: local (1.0.1-1) is newer than extra (0.10.0-1) warning: libxkbcommon-x11: local (1.0.1-1) is newer than extra (0.10.0-1) warning: linux-api-headers: local (5.8-1) is newer than core (5.6.11-1) warning: linux-firmware: local (20201005.r1732.58d41d0-1) is newer than core (20200716.r1675.1d1c80b-1) warning: linux58: local (5.8.16-2) is newer than core (5.8rc5.d0712.g11ba468-1) warning: llvm-libs: local (10.0.1-3) is newer than extra (10.0.0-2) warning: lmdb: local (0.9.26-1) is newer than extra (0.9.25-1) warning: logrotate: local (3.17.0-1) is newer than core (3.16.0-1) warning: lollypop: local (1.3.6-1) is newer than community (1.3.2-1) warning: lua: local (5.4.0-2) is newer than extra (5.3.5-3) warning: lua52-expat: local (1.3.0-5) is newer than community (1.3.0-4) warning: lua52-lpeg: local (1.0.2-3) is newer than extra (1.0.2-2) warning: lua52-socket: local (20200329-1) is newer than community (20190219-1) warning: man-pages: local (5.08-1) is newer than core (5.07-1) warning: manjaro-gdm-branding: local (20200803-1) is newer than community (20200425-1) warning: manjaro-gnome-extension-settings: local (20200803-1) is newer than community (20200426-1) warning: manjaro-gnome-settings: local (20200929-2) is newer than community (20200512-1) warning: manjaro-hello: local (0.6.5-15) is newer than extra (0.6.5-11) warning: manjaro-keyring: local (20200929-1) is newer than core (20200603-1) warning: manjaro-release: local (20.1.2-1) is newer than core (20.0.3-1) warning: manjaro-system: local (20200906-1) is newer than core (20200427-1) warning: manjaro-zsh-config: local (0.15-1) is newer than community (0.11-1) warning: matcha-gtk-theme: local (20200928-1) is newer than community (20200618-1) warning: md4c: local (0.4.5-1) is newer than extra (0.4.4-1) warning: mediainfo: local (20.08-1) is newer than community (20.03-1) warning: mesa: local (20.1.8-1) is newer than extra (20.1.3-1) warning: mesa-vdpau: local (20.1.8-1) is newer than extra (20.1.3-1) warning: mhwd: local (0.6.5-2) is newer than core (0.6.4-2) warning: mhwd-db: local (0.6.5-4) is newer than core (0.6.4-11) warning: mkinitcpio: local (28-1.0) is newer than core (27-3) warning: mkinitcpio-busybox: local (1.31.1-2) is newer than core (1.31.1-1) warning: mntray: local (1.1.2-1) is newer than community (1.1.1-2) warning: modemmanager: local (1.14.2-1) is newer than extra (1.14.0-1) warning: mpfr: local (4.1.0-1) is newer than core (4.0.2-2) warning: mpg123: local (1.26.3-2) is newer than extra (1.26.1-1) warning: mutter: local (3.36.6-1) is newer than extra (3.36.4-1) warning: nano: local (5.2-1) is newer than core (4.9.3-1) warning: ncdu: local (1.15.1-2) is newer than community (1.15.1-1) warning: ndctl: local (69-1) is newer than extra (68-2) warning: networkmanager: local (1.26.2-1) is newer than extra (1.24.2-1) warning: nspr: local (4.29-1) is newer than core (4.26-1) warning: nss: local (3.57-1) is newer than core (3.54-1) warning: ntfs-3g: local (2017.3.23-5) is newer than extra (2017.3.23-4) warning: openexr: local (2.5.3-1) is newer than extra (2.5.2-1) warning: openmpi: local (4.0.5-1) is newer than extra (4.0.4-1) warning: openresolv: local (3.11.0-1) is newer than core (3.10.0-1) warning: openssh: local (8.3p1-4) is newer than core (8.3p1-1) warning: openssl: local (1.1.1.h-1) is newer than core (1.1.1.g-2) warning: orc: local (0.4.32-1) is newer than extra (0.4.31-2) warning: p11-kit: local (0.23.21-1) is newer than core (0.23.20-5) warning: pacman: local (5.2.2-2) is newer than core (5.2.2-1) warning: pam: local (1.4.0-3) is newer than core (1.3.1-2) warning: pamac-cli: local (9.5.12-1) is newer than extra (9.5.6-2) warning: pamac-common: local (9.5.12-1) is newer than extra (9.5.6-2) warning: pamac-flatpak-plugin: local (9.5.12-1) is newer than extra (9.5.6-2) warning: pamac-gnome-integration: local (9.5.12-1) is newer than extra (9.5.6-2) warning: pamac-gtk: local (9.5.12-1) is newer than extra (9.5.6-2) warning: pamac-snap-plugin: local (9.5.12-1) is newer than extra (9.5.6-2) warning: pambase: local (20200721.1-2) is newer than core (20190105.1-2) warning: pango: local (1:1.46.2-1) is newer than extra (1:1.44.7+11+g73b46b04-1) warning: papirus-icon-theme: local (20200901-1) is newer than community (20200702-1) warning: perl: local (5.32.0-3) is newer than core (5.32.0-1) warning: perl-alien-build: local (2.33-1) is newer than extra (2.26-3) warning: perl-html-parser: local (3.74-1) is newer than extra (3.72-10) warning: perl-http-message: local (6.26-1) is newer than extra (6.25-1) warning: perl-libwww: local (6.49-1) is newer than extra (6.46-1) warning: perl-path-tiny: local (0.114-1) is newer than community (0.112-2) warning: perl-xml-libxml: local (2.0206-1) is newer than extra (2.0205-2) warning: pipewire: local (0.3.12-1) is newer than extra (0.3.6-1) warning: pkcs11-helper: local (1.26.0-2) is newer than extra (1.26.0-1) warning: polkit: local (0.117-1) is newer than extra (0.116-5.1) warning: poppler: local (20.09.0-1) is newer than extra (0.90.1-1) warning: poppler-glib: local (20.09.0-1) is newer than extra (0.90.1-1) warning: protobuf: local (3.12.4-1) is newer than extra (3.12.3-1) warning: python: local (3.8.5-2) is newer than extra (3.8.3-1) warning: python-asn1crypto: local (1.4.0-1) is newer than extra (1.3.0-1) warning: python-attrs: local (20.2.0-1) is newer than extra (19.3.0-4) warning: python-bcrypt: local (3.2.0-1) is newer than community (3.1.7-3) warning: python-cffi: local (1.14.3-1) is newer than extra (1.14.0-3) warning: python-cryptography: local (3.1.1-1) is newer than extra (2.9.2-1) warning: python-google-api-core: local (1.22.0-1) is newer than community (1.20.0-1) warning: python-google-api-python-client: local (1.10.0-1) is newer than community (1.9.3-1) warning: python-google-auth: local (1.21.3-1) is newer than community (1.18.0-1) warning: python-ordered-set: local (4.0.2-1) is newer than extra (3.1.1-2) warning: python-paramiko: local (2.7.2-1) is newer than community (2.7.1-2) warning: python-protobuf: local (3.12.4-1) is newer than extra (3.12.3-1) warning: python-psutil: local (5.7.2-1) is newer than community (5.7.0-1) warning: python-pynacl: local (1.4.0-1) is newer than community (1.3.0-4) warning: python-pyqt5: local (5.15.1-2) is newer than extra (5.15.0-3) warning: python-pyqt5-sip: local (12.8.1-1) is newer than extra (12.8.0-1) warning: python-pytz: local (2020.1-2) is newer than community (2020.1-1) warning: python-reportlab: local (3.5.50-1) is newer than community (3.5.42-2) warning: python-requests-file: local (1.5.1-1) is newer than community (1.4.3-5) warning: python-setuptools: local (1:50.3.0-1) is newer than extra (1:49.2.0-1) warning: python-sip: local (4.19.24-2) is newer than extra (4.19.23-1) warning: python-soupsieve: local (2.0.1-1) is newer than community (1.9.6-1) warning: python-tldextract: local (2.2.3-1) is newer than community (2.2.2-1) warning: python-toml: local (0.10.1-2) is newer than community (0.10.1-1) warning: python-urllib3: local (1.25.10-1) is newer than extra (1.25.9-1) warning: python-wheel: local (0.35.1-2) is newer than community (0.34.2-3) warning: python-yaml: local (5.3.1-2) is newer than community (5.3.1-1) warning: python2: local (2.7.18-2) is newer than extra (2.7.18-1) warning: qgnomeplatform: local (0.6.90-1) is newer than community (0.6.1+5+gc835c9e-1) warning: qt5-base: local (5.15.1-1) is newer than extra (5.15.0-4) warning: qt5-declarative: local (5.15.1-1) is newer than extra (5.15.0-1) warning: qt5-svg: local (5.15.1-1) is newer than extra (5.15.0-1) warning: qt5-wayland: local (5.15.1-1) is newer than extra (5.15.0-1) warning: qt5-x11extras: local (5.15.1-1) is newer than extra (5.15.0-1) warning: rav1e: local (0.3.4-1) is newer than extra (0.3.3-1) warning: rsync: local (3.2.3-1) is newer than extra (3.2.2-2) warning: s-nail: local (14.9.19-2) is newer than core (14.9.19-1) warning: sane: local (1.0.31-1) is newer than extra (1.0.30-1) warning: shadow: local (4.8.1-4) is newer than core (4.8.1-2) warning: simple-scan: local (3.36.6-1) is newer than community (3.36.4-1) warning: smbclient: local (4.12.6-1) is newer than extra (4.12.3-2) warning: snapd: local (2.46-1) is newer than extra (2.45.2-1) warning: sqlite: local (3.33.0-2) is newer than core (3.32.3-1) warning: srt: local (1.4.2-1) is newer than extra (1.4.1-2) warning: sudo: local (1.9.3.p1-1) is newer than core (1.9.1-1) warning: svt-hevc: local (1.5.0-1) is newer than community (1.4.3-1) warning: systemd: local (246.6-1) is newer than core (245.6-8) warning: systemd-libs: local (246.6-1) is newer than core (245.6-8) warning: systemd-sysvcompat: local (246.6-1) is newer than core (245.6-8) warning: talloc: local (2.3.1-3) is newer than extra (2.3.1-2) warning: thin-provisioning-tools: local (0.9.0-1) is newer than core (0.8.5-3) warning: tracker: local (2.3.6-1) is newer than extra (2.3.4-2) warning: tracker-miners: local (2.3.5-1) is newer than extra (2.3.3-2) warning: transmission-gtk: local (3.00-2) is newer than extra (3.00-1) warning: ttf-droid: local (20121017-8) is newer than community (20121017-7.2) warning: udisks2: local (2.9.1-1) is newer than extra (2.9.0-1) warning: usb_modeswitch: local (2.6.1-1) is newer than community (2.6.0-2) warning: util-linux: local (2.36-4) is newer than core (2.35.2-1.1) warning: vmaf: local (1.5.3-1) is newer than community (1.5.2-1) warning: vte-common: local (0.62.0-1) is newer than extra (0.60.3-1) warning: vte3: local (0.62.0-1) is newer than extra (0.60.3-1) warning: vulkan-icd-loader: local (1.2.153-2) is newer than extra (1.2.147-1) warning: vulkan-intel: local (20.1.8-1) is newer than extra (20.1.3-1) warning: vulkan-radeon: local (20.1.8-1) is newer than extra (20.1.3-1) warning: webkit2gtk: local (2.30.1-1) is newer than extra (2.28.3-1) warning: wildmidi: local (0.4.3-3) is newer than extra (0.4.3-2) warning: wpebackend-fdo: local (1.8.0-1) is newer than extra (1.6.1-1) warning: x264: local (3:0.160.r3011.cde9a93-1) is newer than extra (3:0.159.r2999.296494a-1) warning: xdg-desktop-portal: local (1.8.0-1) is newer than extra (1.7.2-1) warning: xdg-desktop-portal-gtk: local (1.8.0-1) is newer than extra (1.7.1-1) warning: xfsprogs: local (5.8.0-1) is newer than core (5.6.0-2) warning: xorg-server: local (1.20.9-2) is newer than extra (1.20.8-3) warning: xorg-server-common: local (1.20.9-2) is newer than extra (1.20.8-3) warning: xorg-server-xwayland: local (1.20.9-2) is newer than extra (1.20.8-3) warning: xxhash: local (0.8.0-1) is newer than community (0.7.4-1) warning: yad: local (7.2-1) is newer than community (6.0-1) warning: yelp-xsl: local (3.38.0-1) is newer than extra (3.36.0-1) warning: zenity: local (3.32.0+50+gc229637-1) is newer than extra (3.32.0+17+gfb0938f-2) warning: zeromq: local (4.3.3-2) is newer than community (4.3.2-2) warning: zxing-cpp: local (1.1.1-1) is newer than extra (1.0.8-1) there is nothing to do
That’s interesting. Please run sudo pacman-mirrors -f 5
, and then sudo pacman -Syyu
(mod note - edited for correctness so we can mark the solution)
Now sudo pacman -Syu outputs this:
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade…
Okay, can you now run sudo pacman -Fy
It all worked fine after running the sudo pacman-mirrors -f
I rebuilt the adapter file from AUR and it worked fine and now I have wi-fi. Thank you so much for the help.
You need to always use 2 y
s after touching mirrors, ex:
sudo pacman-mirrors -f && sudo pacman -Syyu
You dont need to do these separately. I also like including x
for regex.
sudo pacman -Fyx /usr/lib/modules/5.8.0-1-MANJARO/build/
Please see above, as well as keep in mind that you should keep yourself up to date … and always ensure you are before installing/updating AUR packages. Also AUR packages will often need to be rebuilt against newer libs … though DKMS ones should be taken care of by pacman hooks.
