I bought today a usb wireless device but I’m unable to locate it’s driver.
When I bought it I asked the vendor will it compatible with Linux he said “Yes” but there is no driver for linux in the little CD
Hi, @megavolt Thanks for this but what’s this code here ? Just so you know I don’t have any programming background , If this is the solution , could you please instruct me how to do it? Thank you so much for your post.
UPDATE:
I just reboot the system and now it’s working but now I’m just little confuse Do I have to remove the internal wireless driver so that they both don’t clash ? If so how can I do it? Because it’s not showing anymore by giving the same command
