After carefully following the instructions I think I almost got,
I installed the right Header
I downloaded the dependencies (I think thats what they are called)
And Almost everything goes according to plan but as previously I previously said Im still getting the Kernel modules tree error. I dont know if this is of any help but here is what ive done,
Preparing...
Checking rtl8821au-dkms-git dependencies...
Resolving dependencies...
Checking inter-conflicts...
To install (11):
m4 1.4.19-1 core 264.5 kB
autoconf 2.71-1 core 660.7 kB
pkgconf 1.8.0-1 core 59.0 kB
flex 2.6.4-3 core 304.4 kB
gc 8.2.0-2 (Required By: make) extra 238.6 kB
guile 2.2.7-2 (Required By: make) extra 6.6 MB
make 4.3-3 core 493.2 kB
bison 3.8.2-1 core 803.5 kB
patch 2.7.6-8 core 94.7 kB
automake 1.16.5-1 core 627.5 kB
dkms 3.0.3-1 (Required By: rtl8821au-dkms-git) extra 37.1 kB
To build (1):
rtl8821au-dkms-git 5.12.5.2.r95.ge4ad4ba-1 AUR
Total download size: 10.2 MB
Total installed size: 57.3 MB
Edit build files : [e]
Apply transaction ? [e/y/N] y
Download of m4 (1.4.19-1) started
Download of flex (2.6.4-3) started
Download of m4 (1.4.19-1) finished
Download of gc (8.2.0-2) started
Download of flex (2.6.4-3) finished
Download of pkgconf (1.8.0-1) started
Download of pkgconf (1.8.0-1) finished
Download of autoconf (2.71-1) started
Download of gc (8.2.0-2) finished
Download of bison (3.8.2-1) started
Download of autoconf (2.71-1) finished
Download of make (4.3-3) started
Download of bison (3.8.2-1) finished
Download of guile (2.2.7-2) started
Download of make (4.3-3) finished
Download of dkms (3.0.3-1) started
Download of dkms (3.0.3-1) finished
Download of patch (2.7.6-8) started
Download of patch (2.7.6-8) finished
Download of automake (1.16.5-1) started
Download of automake (1.16.5-1) finished
Download of guile (2.2.7-2) finished
Checking keyring... [11/11]
Checking integrity... [11/11]
Loading packages files... [11/11]
Checking file conflicts... [11/11]
Checking available disk space... [11/11]
Installing m4 (1.4.19-1)... [1/11]
Installing flex (2.6.4-3)... [2/11]
Installing pkgconf (1.8.0-1)... [3/11]
Installing gc (8.2.0-2)... [4/11]
Installing autoconf (2.71-1)... [5/11]
Installing guile (2.2.7-2)... [6/11]
Installing bison (3.8.2-1)... [7/11]
Installing make (4.3-3)... [8/11]
Installing patch (2.7.6-8)... [9/11]
Installing dkms (3.0.3-1)... [10/11]
Installing automake (1.16.5-1)... [11/11]
Arming ConditionNeedsUpdate... [1/3]
Refreshing PackageKit... [2/3]
Updating the info directory file... [3/3]
Cloning rtl8821au-dkms-git build files...
Generating rtl8821au-dkms-git information...
Building rtl8821au-dkms-git...
==> Making package: rtl8821au-dkms-git 5.12.5.2.r95.ge4ad4ba-1 (Sat 05 Mar 2022 04:32:32 PM EST)
==> Retrieving sources...
-> Cloning 8821au-20210708 git repo...
Cloning into bare repository '/var/tmp/pamac-build-kevinp/rtl8821au-dkms-git/8821au-20210708'...
remote: Enumerating objects: 1294, done.
remote: Counting objects: 100% (1294/1294), done.
remote: Compressing objects: 100% (841/841), done.
remote: Total 1294 (delta 647), reused 1078 (delta 449), pack-reused 0
Receiving objects: 100% (1294/1294), 3.12 MiB | 87.00 KiB/s, done.
Resolving deltas: 100% (647/647), done.
-> Found dkms.conf
8821au-20210708 ... Skipped
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of 8821au-20210708 git repo...
Cloning into '8821au-20210708'...
done.
==> Starting pkgver()...
==> Updated version: rtl8821au-dkms-git 5.12.5.2.r125.g377d3ca-1
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl8821au-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl8821au-dkms-git 5.12.5.2.r125.g377d3ca-1 (Sat 05 Mar 2022 04:33:21 PM EST)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing rtl8821au-dkms-git (5.12.5.2.r125.g377d3ca-1)... [1/1]
Install DKMS modules [2/3]
==> ERROR: Missing 5.15.24-1-rt31-MANJARO kernel modules tree for module 8821au/5.12.5.2.r125.g377d3ca.
Refreshing PackageKit... [3/3]
I removed my HDD where Manjaro was installed and made a fresh install on my SSD, I don’t know if this helps any but after doing that I’m behind on over 2.2 gigabytes of updates. And also I had to install the RT version of the header because the normal wouldn’t work.
And a huge thanks to everyone who has helped me so far!
