Need help Please burning Windows iso to USB
#1
Ok I have searched and found many different ways to do this
But for my Luck Every thing runs good BUT I cant boot
so i need help please
Found a few here on the forum and i fallowed there steps
I can format burn it but cant boot
thank you
#2
This is more suited to a Windows forum....
No I am stuck i need to boot into windows from usb
windows forum has nothing to do with this
so you are saying u will send me to windows forum and not help me?
#4
https://aur.archlinux.org/packages/woeusb-git/
Or
https://aur.archlinux.org/packages/etcher-bin/
This is a Linux forum.
To get Windows USB to boot is an issue for a Windows forum.
Why do you think that a Linux forum can help you boot a Windows USB?
If you have a running Windows installation, use the official MS tool to copy the Windows ISO to the drive.
U need to check this out
https://forum.manjaro.org/search?q=burn%20iso
#8
Those are all in the context of getting Linux to boot. Not Windows.
#9
Thank you so much for ur help but i did that
the problem is i cant boot into the new windows usb
#10
No they are exactly what i am searching for
becaus ei read them
#11
Do you have a running Windows installation?
If yes, again, use the MS media creation tool.
#12
will it run on manjaro ?
#13
No (might run in a virtual machine though), that's why I asked two times whether you have a running windows installation...
#14
Your taking away support time from actual Linux support cases on the forum. Nobody who is a hardcore Linux user gives a rats ass about Windows. Your barking up the wrong tree.
#15
no i have a cd and an iso
i burned the cd and mad an iso burned it to usb did not boot
then i have a different copy of windows on an iso
also burned it and cant boot
so i have
1 iso
2 usb
3 cd with wondows on it
#16
it looks like u are wasting my time every time i post u pop up with this Child stupidity behavior that i can not understand nor do i want to
if u have a problem
just leave me alone
@tbg
dont come up with nonsense and trolling please leave the topic if u dont like it
dont answer or reply or do anything
if u cant do good dont do harm
#18
Guys. Please keep the conversation civilized. Else I will have to close the thread.
#19
I personally think you should close this thread. It is inappropriate for a Linux forum.
#20
If applications fail then you can use the manual approach.
Remove your USB stick from your system.
Open a terminal and list available devices
lsblk -la
Insert your usb stick and list devices again. Locate the new device by comparing the outputs and make a note of it - /dev/sdx
Then use fdisk to create a new partition and set the file system type, boot flag, save the change and format the new partition. Replace sdx with the device you made a note of.
sudo fdisk /dev/sdx
While in the fdisk application
  1. press o to create a new DOS partition table
  2. press n to create a new partition
  3. press Enter four (4) times to accept the defaults.
  4. press t to change the partition type
  5. press 7 to select NTFS
  6. press a to toogle the boot flag
  7. press w to write changes to disk and exit
Format the new partition to NTFS
sudo mkfs.ntfs /dev/sdxY
Next step is to mount your USB stick and your Windows ISO file. Then use a file manager or the terminal to copy all files and folders from your mounted ISO to your mounted USB.
This is going to take a while - depending on your system - it can take hours to complete.
When the copy is complete - do not remove your USB stick. Execute the sync command to ensure all memory data is flushed to disk.
When the sync command returns to the prompt you can safely remove the stick - or use the eject function of your filemanager.
closed #21
