OS: Manjaro 5.22.4
DE: i3wm
Kernel Version: 5.13.12 (64 bit)
CPU: i3 7100U (2.4 GHz quad core)
GPU: Mesa Intel HD Graphics 620 (KBL GT2)
Device: Dell 5378
RAM: 4GB DDR4 (Expandable up to 16 GB)
I am currently using i3wm window manager for some time. I used KDE before. In KDE, the screen can be instantly locked by mod+L .
But, in i3wm I can’t do it. I went to the i3 config file but didn’t understand how to add this. How can I enable this keyboard shortcut or any other shortcut I like in i3.
When I connect my mtp devices to my computer, I occasionally can’t access them with ranger file manager. It sometimes shows in: run/user/1000/gvfs but not always. I have gvfs-mtp installed and android-udev installed. How can I fix this issue ?
I am not sure what RandomGuy has in mind but as I use pcmanfm let me remind you of one tip
On most androids, they default to usb charging when cable connected. So if you are as old me
don’t forget to pull down phone notifications and change from charge to file transfer.
What does the end of dmesg show?
I would expect the min to show your usb detection of internal storage and if you have sdcard, the sdcard storage.
slightly biased…if you are using ranger as a terminal filemanager have you dismissed mc?
