Need help figuring out a command with awk
I am doing sudo lsmod | awk {"print $1"} and I am getting the full output instead of the first line of just the modules without dependencies. I am doing this to add to the mkinitcpio list. Maybe I am recalling the command wrong, and don’t mind if this doesn’t add any benefit, I am mostly learning. :stuck_out_tongue: and fiddling
/etc/mkinitcpio.conf
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(usbhid xhci_hcd)
This is not the correct syntax.
If you want to print all of the first column then use
lsmod | awk '{print $1}'
You likely dont want to put all loaded modules on the MODULES line.
