I have a program whose contributor only supplies it in zip and never packages it, so I want to make the package myself
How can I make a correct PKGBUILD so that the system can install this zip and create a desktop file (so that the visual shell can display the shortcut)
The situation is not optimal because the download is only on telegram; I didn’t find a website either, I don’t know if exist some cli programs that can download from there
I’ve used source_x86_64=("local://linux64.zip") because users need to provide the file and put it alongside the pkgbuild (or in the shared source directory if configured)
This URL suggests some name (vtmsg) - but it leads only to download Telegram Desktop
That’s why I said what I said - there is a PKGBUILD for that.
I’d have thought that they amended the post by now and gave a proper URL for what they wanted - but your assumption of what that is might be correct.
Problem is there are already vk-messenger in AUR but this fork doesn’t have RPM package - only archive with resources and executable. To launch that I only need to unzip and launch the main file. And yes, fork developer only post archives on telegram, there are no website or something
I just wanted to create a repository where the PKGBUILD and the archive with the program will already be, so users can easily install it
Your solution works perfectly, thank you very much
Why did you not use the vk-messenger AUR PKGBUILD as a template and change the source URL?
Please be clear and concise. See How to Post. Provide more information and you’ll receive more detailed and educated answers in your replies. Making us guess wastes the time of volunteers.
Give, and it shall be given to you. A good measure, pressed down and shaken together and running over shall be put into your lap. For with the same measure with which you measure, it shall be measured back to you.
