I need help finding my bearings in order to build and install this driver and it’s GUI which are two separate projects for the USB audio interface called ESI Maya22 USB.
The Driver:
and the GUI:
I’ve downloaded them, and I would like some tips as to how they should be built and or installed.
There’s another one on the net, so I tried to follow the instructions and install the GUI for the soundcard using this project, will keep you updated on the progress: https://sourceforge.net/projects/maya22gui/files/
