[chris@chris-laptop 20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202]$ sudo make install INTERFACE=usb
make -C 8761BU
make[1]: Entering directory '/home/yochanan/tmp/Linux_BT_USB_v3.10_20200302_8761BU_BTCOEX_20190327-0202/8761BU'
Copy 8761BUV firmware to /lib/firmware/rtl8761bu_
[sudo] password for chris:
mkdir -p /lib/modules/5.14.2-1-MANJARO/kernel/drivers/bluetooth
Start Realtek Bluetooth USB driver installation
mkdir -p /lib/firmware
Copy rtkbt-firmware/lib/firmware/rtl*_fw to /lib/firmware
cp -a rtkbt-firmware/lib/firmware/rtl*_fw /lib/firmware
Copy rtkbt-firmware/lib/firmware/rtl*_config /lib/firmware
cp -a rtkbt-firmware/lib/firmware/rtl*_config /lib/firmware
make -C usb install
make[1]: Entering directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb'
rmmod btusb
rmmod: ERROR: Module btusb is not currently loaded
make[1]: [Makefile:7: install] Error 1 (ignored)
mv /lib/modules/5.14.2-1-MANJARO/kernel/drivers/bluetooth/btusb.ko /lib/modules/5.14.2-1-MANJARO/kernel/drivers/bluetooth/btusb_bak
mv: cannot stat '/lib/modules/5.14.2-1-MANJARO/kernel/drivers/bluetooth/btusb.ko': No such file or directory
make[1]: [Makefile:8: install] Error 1 (ignored)
rmmod rtk_btusb
rmmod: ERROR: Module rtk_btusb is not currently loaded
make[1]: [Makefile:9: install] Error 1 (ignored)
make -C ./bluetooth_usb_driver
make[2]: Entering directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'
make -C /lib/modules/5.14.2-1-MANJARO/build M=/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver modules
make[3]: Entering directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'
make[3]: *** /lib/modules/5.14.2-1-MANJARO/build: No such file or directory. Stop.
make[3]: Leaving directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'
make[2]: *** [Makefile:10: all] Error 2
make[2]: Leaving directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'
make[1]: *** [Makefile:10: install] Error 2
make[1]: Leaving directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb'
make: *** [Makefile:28: install] Error 2
make: *** 8761BU: No such file or directory. Stop.
bash: make[1]:: command not
Do you or do you not now have the base-devel
group and appropriate linux-headers
package(s) installed? It does not appear the latter are installed.
I am not sure honestly. I do not think so for either.
Okay, I’m running the 5.14 .2-1 kernal
Well, you know what commands to run to make sure.
sudo pacman -Syu linux-headers
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: There are 10 providers available for linux-headers:
:: Repository core
1) linux414-headers 2) linux419-headers 3) linux44-headers
4) linux49-headers 5) linux510-headers 6) linux512-headers
7) linux513-headers 8) linux514-headers 9) linux54-headers
:: Repository community
10) linux510-rt-headers
Enter a number (default=1): 8
warning: manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-9)
resolving dependencies...
Packages (2) pahole-1.22-1 linux514-headers-5.14.2-1
Total Download Size: 29.84 MiB
Total Installed Size: 127.40 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
linux514-headers... 29.6 MiB 6.02 MiB/s 00:05 [######################] 100%
pahole-1.22-1-x86_64 248.5 KiB 1814 KiB/s 00:00 [######################] 100%
Total (2/2) 29.8 MiB 5.67 MiB/s 00:05 [######################] 100%
(2/2) checking keys in keyring [######################] 100%
(2/2) checking package integrity [######################] 100%
(2/2) loading package files [######################] 100%
(2/2) checking for file conflicts [######################] 100%
(2/2) checking available disk space [######################] 100%
(1/2) installing pahole [######################] 100%
(2/2) installing linux514-headers [######################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating module dependencies...
sudo pacman -Syu --needed base-devel
core is up to date
extra is up to date
warning: autoconf-2.71-1 is up to date -- skipping
warning: automake-1.16.4-1 is up to date -- skipping
warning: binutils-2.36.1-3 is up to date -- skipping
warning: bison-3.7.6-1 is up to date -- skipping
warning: fakeroot-1.25.3-2 is up to date -- skipping
warning: file-5.40-5 is up to date -- skipping
warning: findutils-4.8.0-1 is up to date -- skipping
warning: flex-2.6.4-3 is up to date -- skipping
warning: gawk-5.1.0-1 is up to date -- skipping
warning: gcc-11.1.0-1 is up to date -- skipping
warning: gettext-0.21-1 is up to date -- skipping
warning: grep-3.6-1 is up to date -- skipping
warning: groff-1.22.4-6 is up to date -- skipping
warning: gzip-1.11-1 is up to date -- skipping
warning: libtool-2.4.6+42+gb88cebd5-16 is up to date -- skipping
warning: m4-1.4.19-1 is up to date -- skipping
warning: make-4.3-3 is up to date -- skipping
warning: pacman-6.0.1-1 is up to date -- skipping
warning: patch-2.7.6-8 is up to date -- skipping
warning: pkgconf-1.7.3-1 is up to date -- skipping
warning: sed-4.8-1 is up to date -- skipping
warning: sudo-1.9.7.p2-1 is up to date -- skipping
warning: texinfo-6.8-2 is up to date -- skipping
warning: which-2.21-5 is up to date -- skipping
there is nothing to do
Now you do. Try building the driver again. If it’s successful, reboot and see if it works.
[chris@chris-laptop 20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202]$ make install INTERFACE=usb
make -C 8761BU
Copy 8761BUV firmware to /lib/firmware/rtl8761bu_fw
make -C usb install
rmmod btusb
rmmod rtk_btusb
make[3]: Entering directory '/usr/lib/modules/5.14.2-1-MANJARO/build'
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6208’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6210’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6212’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6214’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6216’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6218’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6221’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6223’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6225’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6227’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6229’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6231’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6233’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6235’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6237’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6239’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6241’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6243’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6245’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6247’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6249’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6251’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6253’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6255’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6257’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6259’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6261’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6263’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6265’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6267’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6269’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6271’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6273’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6275’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6278’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6281’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6283’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6285’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6287’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6289’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6291’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6293’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6295’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6297’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6299’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6301’: Permission denied
mkdir: cannot create directory ‘/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS/.tmp_6303’: Permission denied
make[3]: *** No rule to make target 'BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'. Stop.
make[3]: Leaving directory '/usr/lib/modules/5.14.2-1-MANJARO/build'
make[1]: Leaving directory '/mnt/7b856f58-c348-46e4-9c42-721a37df37d8/ASUS BT-500/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb'
bash: make[1]:: command not found
bash: Copy: command not found
I don’t believe this was successful.
I replaced your name with mine (because, of course, my system can’t run off of your system) and tried it again.
[chris@chris-laptop 20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202]$ make install INTERFACE=usb make -C 8761BU make[1]: Entering directory '/home/chris/tmp/Linux_BT_USB_v3.10_20200302_8761BU_BTCOEX_20190327-0202/8761BU' Copy 8761BUV firmware to /lib/firmware/rtl8761bu_fw
I’m thinking that, if it is possible, taking remote access of my computer would be the easiest way.
Turns out there’s a newer driver version than in that Reddit post. Try the following:
wget https://dlcdnets.asus.com/pub/ASUS/wireless/USB-BT500/20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip
bsdtar -xzf 20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip
cd 20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202
Driver Package
Version v0202
2020/12/08 4.9 MBytes
ASUS USB-BT500 Driver 1.0.0.8 for Linux
Support kernel 2.6.32 - 5.7.1
DOWNLOAD
This is the version I have downloaded on my system.
Yochanan, my sincerest apologies if this is taking forever. I am very green (as you can tell) and I really do appreciate your patience with me.
[chris@chris-laptop 20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202]$ wget https://dlcdnets.asus.com/pub/ASUS/wireless/USB-BT500/20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip
--2021-09-18 11:06:29-- https://dlcdnets.asus.com/pub/ASUS/wireless/USB-BT500/20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip
SSL_INIT
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving dlcdnets.asus.com (dlcdnets.asus.com)... 152.199.55.114
Connecting to dlcdnets.asus.com (dlcdnets.asus.com)|152.199.55.114|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5140685 (4.9M) [application/zip]
Saving to: ‘20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip’
20200909_LINUX_BT_D 100%[===================>] 4.90M 9.52MB/s in 0.5s
2021-09-18 11:06:30 (9.52 MB/s) - ‘20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip’ saved [5140685/5140685]
make -C usb install
make[1]: Entering directory '/home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb'
rmmod btusb
rmmod: **ERROR: Module btusb is not currently loaded**
make[1]: **[Makefile:8: install] Error 1 (ignored)**
rmmod rtk_btusb
rmmod: **ERROR: Module rtk_btusb is not currently loaded**
make[1]: [**Makefile:9: install] Error 1 (ignored)**
make[2]: Entering directory '/home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'
make -C /lib/modules/5.14.2-1-MANJARO/build M=/home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver modules
CC [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_coex.o
CC [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_misc.o
CC [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_bt.o
LD [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_btusb.o
MODPOST /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/Module.symvers
CC [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_btusb.mod.o
LD [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_btusb.ko
BTF [M] /home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver/rtk_btusb.ko
make[2]: Leaving directory '/home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb/bluetooth_usb_driver'
cp -f ./bluetooth_usb_driver/rtk_btusb.ko /lib/modules/5.14.2-1-MANJARO/kernel/drivers/bluetooth/rtk_btusb.ko
depmod -a 5.14.2-1-MANJARO
make -C ./bluetooth_usb_driver clean
rm -rf *.o *.mod.c *.mod.o *.ko *.symvers *.order *.a
echo **"install rtk_btusb success!"**
**install rtk_btusb success!**
make[1]: Leaving directory '/home/chris/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/usb'
Here is the results of the new info you gave me to input into the terminal.
I’m not sure if this was suppose to happen, but I removed the dongle from the USB port in my laptop and plugged it back in. The bluetooth symbol appeared on my screen, which did not happen previously. Did my system recognize the dongle?
The installation was successful this time. Reboot and test it out.
Post the output of the following to only show the Bluetooth section of your system info.
inxi -Eazy
[chris@chris-laptop ~]$ inxi -Eazy
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: rtk_btusb
v: 3.1.244af65.20200806-165553 bus-ID: 1-1:2 chip-ID: 0b05:190e
Device-2: Intel Bluetooth wireless interface type: USB driver: N/A
bus-ID: 1-7:8 chip-ID: 8087:0a2a class-ID: e001
Reboot done. Here are the results you requested.
Well? Is it working?
When I disconnect the dongle from the laptop, the bluetooth icon grays out. When I reconnect it, the bluetooth icon goes back to online status. I think this means that it’s working. I’m going to make a test call with my wireless earbuds to see if this setup works properly now.
I just called my friend in the States and they say that they can hear me more clearly now but it sounds as if I’m in a very empty room or in a bathroom.
I think that may be due to distance and other factors.
I believe it may also be due to the type of sound card I have in my laptop. Possibly the generic type from HP.
Yochanan, I must say thank you again for your time and patience. I do sincerely appreciate it. Please let me know where to send your check.
If I ever find someone who needs assistance with anything on Linux, I know who and where to send them.
