oof SATA Connection wasn’t connected let’s see if it worked by a reboot
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 1.8T 0 disk
├─sda1 8:1 0 16M 0 part
└─sda2 8:2 0 1.8T 0 part
sdb 8:16 0 931.5G 0 disk
sdc 8:32 0 931.5G 0 disk
├─sdc1 8:33 0 100M 0 part /boot/efi
├─sdc2 8:34 0 16M 0 part
├─sdc3 8:35 0 465.4G 0 part
├─sdc4 8:36 0 522M 0 part
└─sdc5 8:37 0 465.4G 0 part /
OMG
I am so dumb
SDC is now there after I reconnected the SATA Cable
omg I am so dumb
nope… It’s easy to miss a connector when setting up a new system… It’ll remind you to check … next time …
absolutely thanks for all the help even though it ended being a sata cable.
thank you to everyone for your input as it did bring some insight into my system and it’s many flaws.
Cheers,
Kevin M.
Indeed that would be rather strange…but missing drives are not entirely uncommon. ![]()
A loose connection or bad cable can look like a failing or missing drive, and though it’s less likely, the drive or one of the sata controllers could be faulty.
Checking cables and swapping drives around would be the first steps in troubleshooting such issues.
