Navicat premium15 error after glib2 update to 2.7
And what are we supposed to do with that information?
You should talk to the developer of that application as it appears to be a paid product - judging from the sentence
The issue was reported on the AUR page and the maintainer says it’s fixed with 15.0.29-1. Have you updated it?
Thank you. I reduced the version of glig2
Why did you downgrade glib2
? Again, all you should need to do is update the AUR package to 15.0.29-1.
FYI, downgrading packages especially one as important as glib2
is neither recommended nor supported. It will leave you in a partial upgrade state which can and will cause breakage.
OK Thank you.
