Nautilus (Files) 43 not loading after the upgrade of python-nautilus to 4.0-1.
I had to downgrade it to an older version to get it working again.
I have no other issues with Gnome 43.
That’s because you have an incompatible Nautilus extension. Remove it. Downgrading is not a solution here.
Which one?
You tell us. Probably all of them. Not many have been ported to the new version yet.
Close all Nautilus windows and completely quit:
nautilus -q
Then run it from the terminal and provide the output here:
nautilus
I found out that it is required by nautilus-admin and nautilus-folder-icons. I can’t delete any of them though because one depends on the other
I moved our posts to a new topic, FYI.
nautilus-admin
is compatible, nautilus-folder-icons
is not. Remove the latter, make sure you have no ignored packages then do a full update.
I’m the AUR maintainer of nautilus-folder-icons
and I made this change on purpose.
Tip: If you miss the functionality of old Nautilus plugins / extensions, use Nemo. Most are available for it.
You 're right. I removed nautilus-folder-icons
and nautilus works now!
Thanks a lot!
