nautilus-admin and admin:// - without permission to delete, rename and edit
same error
by command
admin:///etc
or
nautilus admin:///etc
I can't edit, rename, and delete files or folders. But I can create file and folders
What error?
That issue was closed well over a year ago and fixed. I can't reproduce it. Are you running nautilus-admin 1.1.9-1 from the community repo?
I can't edit, rename, and delete files or folders using this nautilus-admin. But I can create file and folders
by command I can edit, rename and delete
pkexec nautilus folder
~ # pacman -Qs nautilus-admin
local/nautilus-admin 1.1.9-1
Ex
I'm not certain this is needed any more because of the new admin:/// location.
@Ste74 can you confirm whether we need nautilus-admin any more? Or does this just need a rebuild? (Sorry for the ping but you were last packager. :kissing_heart: )
@jonathon :stuck_out_tongue_winking_eye:
@swatquest sorry but you seem to request a new function for nautilus-admin..
according with this:
Nautilus Admin is a simple Python extension for the Nautilus file manager that adds some administrative actions to the right-click menu:
  • Open as Administrator : opens a folder in a new Nautilus window running with administrator (root) privileges.
  • Edit as Administrator : opens a file in a Gedit window running with administrator (root) privileges.
this is what do nautilus-admin and for instance i assume you use xorg session with gnome because with wayland your command ( pkexec nautilus folder ) not work: no polkit rules for nautilus by default and for design
jonathon
by command
admin:///etc
or
Ste74
pkexec to work has to create an action in polkit
https://wiki.archlinux.org/index.php/Polkit
Yep i know :blush: but i think you don't see this
so is discouraged and not designed by upstream
Yeah, admin:// works on Wayland and Xorg
pkexec works on Xorg
but admin://
Try to move the files and folders to trash folder with drag and drop.
drag and drop, delete files or folders.
I can't rename.
I'll mark it as solved
It seems to be the default (gvfsd-admin).
