Hi,
I tried to build a x86 iso image, something go wrong during the iso build.
sudo buildiso -f -p kde -b stable -k linux66 2023.12.12
error: target not found: kgamma5
::Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::Austria : https://mirror.alwyzon.net/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
(17/17) Updating the info directory file...
--> Using build locales ...
mv: cannot stat '/var/lib/manjaro-tools/buildiso/kde/x86_64/rootfs/etc/locale.conf': No such file or directory
--> Setting mirrorlist branch: stable
Generating locales...
en_US.UTF-8... done
Generation complete.
--> Restoring [/var/lib/manjaro-tools/buildiso/kde/x86_64/rootfs/etc/pacman.conf] ...
-> Configuring lsb-release
-> Cleaning [rootfs]
==> Done [Base installation] (rootfs)
--> Loading Packages: [Packages-Desktop] ...
==> Prepare [Desktop installation] (desktopfs)
--> overlayfs mount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs]
--> mirror: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
==> Creating install root at /var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs
-> Installing packages to /var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs
core 145,0 KiB 853 KiB/s 00:00 [#####################] 100%
extra 8,6 MiB 49,8 MiB/s 00:00 [######################] 100%
community 29,0 B 1450 B/s 00:00 [##################] 100%
multilib 143,5 KiB 6,09 MiB/s 00:00 [###################] 100%
warning: wayland-1.22.0-1 is up to date -- reinstalling
warning: exfatprogs-1.2.2-1 is up to date -- reinstalling
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
==> ERROR: A failure occurred in make_image_desktop().
Aborting...
--> overlayfs umount: [/var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs]
--> umount overlayfs: [/var/lib/manjaro-tools/buildiso/kde/x86_64/desktopfs]
[nls@lap ~]$
No issue during the stable update with kgamma
==> Appending keys from archlinux.gpg...
==> Updating trust database...
gpg: next trustdb check due at 2023-12-31
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
:: Replace kgamma5 with extra/kgamma? [Y/n] y
resolving dependencies...
warning: dependency cycle detected:
kgamma-5.27.10-2-x86_64 167,4 KiB 16,3 MiB/s 00:00 [######] 100%
(1/1) removing kgamma5
( 69/158) installing kgamma [##################] 100%
Thanks in advance for your help.
