Hello, i need help, a folder named '~" linking to my home recently appears IN my home diretory…
I’m looking for a way to remove it, cause i think this is not normal. I already had this issue with a ‘/’ directory and i can tell that a sudo rm is not a good idea…
~ points to your home directory. Are you sure it is actually “within” your home directory?
You can check that using “ls /home/$(whoami)”. Does “~” show up when typing this command?
If not, then it is completely normal. Just a way for you to type less when cd’ing into your home directory.
Quick question. My roommatyes machine with Manjaro KDE has a folder in his Downloads partition on a ext4 drive that no matter what I do will not delete. It’s been there through 3 different OS’s. Will this remove the folder finally? Thanks
