MySQL (mariadb) and Apache cannot start now, and it seems to be because they can’t create their own directories in /run. If I create the directories myself and change the owners, I can start them manually. It breaks immediately the next boot though. I’m not sure what other info is relevant here.
mariadbd[6188]: 2022-04-17 19:36:50 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mariadbd[6188]: 2022-04-17 19:36:50 0 [Note] Server socket created on IP: '0.0.0.0'.
mariadbd[6188]: 2022-04-17 19:36:50 0 [Note] Server socket created on IP: '::'.
mariadbd[6188]: 2022-04-17 19:36:50 0 [ERROR] Can't start server : Bind on unix socket: No such file or directory
mariadbd[6188]: 2022-04-17 19:36:50 0 [ERROR] Do you already have another server running on socket: /run/mysqld/mysqld.sock ?
mariadbd[6188]: 2022-04-17 19:36:50 0 [ERROR] Aborting
[Sun Apr 17 19:26:16.435270 2022] [core:error] [pid 673] (2)No such file or directory: AH00099: could not create /run/httpd/httpd.pid.yOWYIN
[Sun Apr 17 19:26:16.435293 2022] [core:error] [pid 673] AH00100: httpd: could not log pid to file /run/httpd/httpd.pid
No, for me it looks like that apache and mysql crashed and the pid file stayed. Now you want to start it again and it is blocked because there is already a pid file. If a pid file is there, then one assumes that the progam is running.
Btw… /run dir does not survive a reboot and will be recreated on every boot.
At boot and manually starting I get this issue. As stated, if I set up the directories manually they start fine, but it only works for that time. I would have to do it manually every time if I want to use them now.
It shows the outputs in the first post, with a failed state. Do you want all the details from both?
@megavolt It is kinda crashing (fails to start with an error) but it mostly just seems like it can’t start at all. I thought it might be an issue with the permissions of the /run directory (since I can start it manually after making the directories myself), but I don’t really know what it should be anyway to check.
I run a mariadb service and it creates the pid file without problems as /run/mysqld/mysqld.sock
The webservice in my case is nginx - that pid is /run/ngins.pid - at some point I have played with apache as well - no issues - other than my lack of knowledge.
The /run tree is a volatile tmpfs tree which exist only on memory
$ mount
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
Both were set up a few months ago, and were both working correctly until now when they stopped. I’m not sure what I’m supposed to do with that code block (if anything)
It is just to show that the /run tree is a tmpfs and thus recreated on every boot.
There must be something else - but I have no idea what.
It is not a general issue - otherwise I would have faced it too - I run a web service on Manjaro using mariadb as backend - and the server was updated and restarted this morning.
I just took out some stats on it - the only thing you can use this for is to verify if it is not a general issue.
$ uname -a
Linux web 5.10.111-1-MANJARO #1 SMP PREEMPT Thu Apr 14 00:00:28 UTC 2022 x86_64 GNU/Linux
$ lsb_release -a
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 21.2.6
Codename: Qonos
$ ls /run/mysqld -l
total 0
srwxrwxrwx 1 mysql mysql 0 Apr 18 08:37 mysqld.sock
$ systemctl status mysql
● mariadb.service - MariaDB 10.7.3 database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2022-04-18 08:37:59 CEST; 10h ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Process: 871 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 891 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_>
Process: 950 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Main PID: 924 (mariadbd)
Status: "Taking your SQL requests now..."
Tasks: 8 (limit: 38113)
Memory: 112.6M
CPU: 7.972s
CGroup: /system.slice/mariadb.service
└─924 /usr/bin/mariadbd
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] InnoDB: 10.7.3 started; log sequence number 945574969; transaction id 6159
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] Server socket created on IP: '0.0.0.0'.
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] Server socket created on IP: '::'.
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] InnoDB: Buffer pool(s) load completed at 220418 8:37:59
Apr 18 08:37:59 web mariadbd[924]: 2022-04-18 8:37:59 0 [Note] /usr/bin/mariadbd: ready for connections.
Apr 18 08:37:59 web mariadbd[924]: Version: '10.7.3-MariaDB' socket: '/run/mysqld/mysqld.sock' port: 3306 Arch Linux
Apr 18 08:37:59 web systemd[1]: Started MariaDB 10.7.3 database server.
Randomly noticed my / directory was owned by my user, not root as it usually is. I tried to find out why this could have happened, but haven’t found a single thing, even in my command history. Changing the owner back to root (and double-checking the other root directories) fixed both of these services, as well as snapd which I had also been having issues with. Maybe someone else can find this useful too.
