lsusb -tv
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/14p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 9: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
ID 8087:0aa7 Intel Corp. Wireless-AC 3168 Bluetooth
|__ Port 9: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
usb_modeswitch -R -v 8087 -p 0aa7
Look for default devices ...
Found devices in default mode (1)
Access device 002 on bus 001
Error opening the device. Abort
I have to add, I am not doing this as root, as I don’t think this would help, how should he know to give it to me in that case and my user is not a sudoer, so I can also not do sudo x
Sorry, I do not get what you want to tell me. Your statement is correct, but how does it apply/help in my situation? The device is already paird, I simply connect to it. But if my wife is logged into a session in background, her account is the only one to see it. If I log her out, my account will get to see it.
One additional information: I have another bluetooth headset that supports 2 profiles HPF and A2DP. In that case one account gets access to one profile and the other to the other, but no account can use the one the other is currently using.
