So, i restarted my PC because Minecraft put linux in a whole new resolution and when I restarted it fixed it… and it also added a whole new menu bar and a rat logo in the left corner
Also, I created a virtual machine, then deleted and half of my storage is gone, where are virtual drives stored?
Sounds like you managed to revert to default XFCE settings … meaning you did something that added/removed packages or reset your configurations or something …
Propably, is there any way to change it?
We dont know what you did.
You can probably find out though by looking in /var/log/pacman.log
Can I just change the logo back?
sure. if thats what you want. I guess that means theres no issue then.
How do I do that? Also where are virtual drives stored? Thanks
I dont remember for XFCE … but I think you just Rt-Click on the menu and set properties there.
