I can’t speak to all the community editions, but I’ve been using the i3 one for months and it’s great. I’ve had no trouble with updates, etc., so long as I kept up with the release notes. As for old packages, to the best of my knowledge the ISOs are totally up to date with those of the official editions, and in any case you should update soon after installing regardless of which edition you use.
The difference between official editions and community editions is that the latter are usually put together by a single developer on the team, as an additional offer alongside of the four official editions ─ i.e. KDE Plasma, GNOME, XFCE and Architect.
Yet, other than the chosen graphical interface, there’s no difference once you’ve installed the system. The underlying operating system is still the same, and the updates are issued through the same mechanism, and at the same time. There is no distinction at that level, because it’s all just software from the repositories.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
