AlanP
9 November 2020 02:38
1
Hello,
my touchpad is recognized as “ITE Tech. Inc ITE Device(8595)” but it works like a mouse and not a touchpad. In system settings of kde plasma, it is not found as a touchpad (all options are grayed out). The system tell me “touchpad not found”. I searched on the net for a solution but I didn’t find anything. That’s why I posted this message.
Do you know a way to enable this hardware as a touchpad ?
Thanks.
cscs
9 November 2020 04:05
2
You may be missing something or another.
But often my suggestion with things like this is to try xf86-input-synaptics
which is the legacy input handler … it should take precedence over libinput and sometimes works better in some setups.
AlanP
9 November 2020 13:09
3
All xf86-intput packages are installed but despite it my touchpad is not recognized as a touchpad but as a mouse.
pobrn
9 November 2020 15:11
4
Please post the output of timeout 2 libinput debug-events
and ls -lR /dev/input/by-*/
AlanP
10 November 2020 12:14
5
Thanks for your help. I will give you the results later.
I want to tell you that ITE Device(8595) is well recognized under plasma but in the system configuration it is see as a mouse and not as a touchpad.
@pobrn : Here are the results of your two commands:
sudo timeout 2 libinput debug-events
-event10 DEVICE_ADDED Video Bus seat0 default group1 cap:k
-event0 DEVICE_ADDED Lid Switch seat0 default group2 cap:S
-event1 DEVICE_ADDED ITE Tech. Inc. ITE Device(8595) seat0 default group3 cap:kp scroll-nat
-event2 DEVICE_ADDED ITE Tech. Inc. ITE Device(8595) seat0 default group3 cap:p left scroll-nat scroll-button
-event9 DEVICE_ADDED bytcr-rt5640 Headset seat0 default group4 cap:k
-event3 DEVICE_ADDED FTSC1000:00 2808:50C5 seat0 default group5 cap:t size 273x154mm ntouches 10 calib
-event4 DEVICE_ADDED FTSC1000:00 2808:50C5 UNKNOWN seat0 default group5 cap:T size 292x164mm
-event6 DEVICE_ADDED axp20x-pek seat0 default group6 cap:k
-event7 DEVICE_ADDED gpio-keys seat0 default group7 cap:k
-event8 DEVICE_ADDED gpio-keys seat0 default group7 cap:k
/dev/input/by-id/:
total 0
lrwxrwxrwx 1 root root 9 11 nov 00:11 usb-ITE_Tech._Inc.ITE_Device_8595 -event-kbd -> …/event1
lrwxrwxrwx 1 root root 9 11 nov 00:11 usb-ITE_Tech._Inc.ITE_Device_8595 -if01-event-mouse -> …/event2
lrwxrwxrwx 1 root root 9 11 nov 00:11 usb-ITE_Tech._Inc.ITE_Device_8595 -if01-mouse -> …/mouse0
/dev/input/by-path/:
total 0
lrwxrwxrwx 1 root root 10 11 nov 00:11 pci-0000:00:02.0-platform-hdmi-lpe-audio-event -> …/event12
lrwxrwxrwx 1 root root 9 11 nov 00:11 pci-0000:00:14.0-usb-0:2.1:1.0-event-kbd -> …/event1
lrwxrwxrwx 1 root root 9 11 nov 00:11 pci-0000:00:14.0-usb-0:2.1:1.1-event-mouse -> …/event2
lrwxrwxrwx 1 root root 9 11 nov 00:11 pci-0000:00:14.0-usb-0:2.1:1.1-mouse -> …/mouse0
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-80860F41:03-event -> …/event3
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-80860F41:03-event-mouse -> …/event4
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-80860F41:03-mouse -> …/mouse2
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-80860F41:04-platform-axp221-pek-event -> …/event6
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-bytcr_rt5640-event -> …/event9
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-gpio-keys.0.auto-event -> …/event7
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-gpio-keys.1.auto-event -> …/event8
lrwxrwxrwx 1 root root 9 11 nov 00:11 platform-pcspkr-event-spkr -> …/event5
pobrn
14 November 2020 13:00
6
Can you post the output of inxi -Fazy
AlanP
15 November 2020 00:20
7
I will give you the results later because I 'm not in my Manjaro system for now.
Thanks for your reply.
AlanP
15 November 2020 13:12
8
Result of inxi -Fazy
Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=4936d035-5442-4827-8cd6-1f8abbee4cdc rw quiet apparmor=1
security=apparmor udev.log_priority=3 intel_idle.max_cstate=1
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Portable System: MEDION product: Akoya E2212T MD99720 v: N/A
serial: Chassis: type: 8 serial:
Mobo: MEDION model: WCBT112X v: 1.0 serial:
UEFI: American Megatrends v: 1.3 date: 10/26/2015
ID-1: axp288_fuel_gauge charge: 100% condition: N/A volts: 4.3/N/A
model: N/A type: Li-ion serial: N/A status: Full
Info: Quad Core model: Intel Atom Z3735F bits: 64 type: MCP arch: Silvermont
family: 6 model-id: 37 (55) stepping: 8 microcode: 838 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 10671
Speed: 500 MHz min/max: 500/1833 MHz Core speeds (MHz): 1: 1320 2: 649
3: 500 4: 500
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0f31
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 133 size: 260x140mm (10.2x5.5")
diag: 295mm (11.6")
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.2.1
compat-v: 3.0 direct render: Yes
Device-1: bytcr-rt5640 driver: bytcr-rt5640
message: bus/chip ids unavailable
Device-2: Intel HDMI/DP LPE Audio driver: HdmiLpeAudio
Sound Server: ALSA v: k5.9.3-1-MANJARO
Message: No Device data found.
IF-ID-1: wlan0 state: down mac:
Local Storage: total: 94.36 GiB used: 13.69 GiB (14.5%)
ID-1: /dev/mmcblk1 vendor: SK Hynix model: HCG8e size: 58.25 GiB block size:
physical: 512 B logical: 512 B serial: rev: 0x7 scheme: GPT
SMART Message: Unknown smartctl error. Unable to get data.
ID-2: /dev/sda type: USB model: USB Flash Memory size: 7.47 GiB block size:
physical: 512 B logical: 512 B serial: rev: PMAP scheme: GPT
ID-3: /dev/sdb type: USB vendor: SanDisk model: Ultra size: 28.64 GiB
block size: physical: 512 B logical: 512 B serial: rev: 1.00
scheme: GPT
ID-1: / raw size: 28.14 GiB size: 27.57 GiB (97.99%) used: 13.69 GiB (49.7%)
fs: ext4 dev: /dev/sdb2
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 194 Uptime: 3m Memory: 1.88 GiB used: 666.2 MiB (34.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1327 lib: 374
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
Note: For your information, I don’t have serio folder in /sys/bus/
The touchpad seems to be attached to /sys/bus/usb folder
pobrn
17 November 2020 08:05
9
Could you post the output of lsusb
AlanP
15 January 2021 12:24
10
Hi,
After a long time, I’m come back to you.
Here are the results:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0781:5581 SanDisk Corp. Ultra
Bus 001 Device 005: ID 2109:2812 VIA Labs, Inc. VL812 Hub
Bus 001 Device 004: ID 2109:2812 VIA Labs, Inc. VL812 Hub
Bus 001 Device 003: ID 048d:8595 Integrated Technology Express, Inc. ITE Device(8595)
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
The touchpad is recognized as “Integrated Technology Express, Inc. ITE Device(8595)” through lsusb.
Note: I’m using Manjaro Gnome on Wayland only.
pobrn
15 January 2021 13:07
11
Can you check if there’s anything related to touchpad in the BIOS setup? That USB device seems to be exclusively a mouse device. Can you also post the output of ls -l /sys/bus/acpi/devices/ /sys/bus/i2c/devices/
. When posting the output of a command, please put the output between three backticks (`) like this:
output
and it’ll appear as
output
AlanP
15 January 2021 14:04
12
Nothing for touchpad in the BIOS setup.
First result:
lrwxrwxrwx 1 root root 0 15 jan 14:47 10EC5640:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/10EC5640:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 10TI3100:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/10TI3100:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F09:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F09:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F09:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F09:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F0A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0A:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F0A:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0A:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F0E:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0E:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F14:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F14:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F14:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F14:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F14:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F14:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F28:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F28:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F41:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F41:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F41:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F41:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:03
lrwxrwxrwx 1 root root 0 15 jan 14:47 80860F41:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04
lrwxrwxrwx 1 root root 0 15 jan 14:47 ACPI0003:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0003:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 ACPI000C:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ACPI000C:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 ADMA0F28:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F28:00/ADMA0F28:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 AKM09911:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/AKM09911:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 AMCR0F28:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/AMCR0F28:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 AUTH2750:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0E:00/AUTH2750:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 BCM2E3A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0A:00/BCM2E3A:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 BCM4752:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0A:01/BCM4752:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 BSBA0150:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/BSBA0150:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 BSBG0160:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/BSBG0160:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 BSBG0160:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/BSBG0160:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 BSBM0150:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/BSBM0150:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 BSG1160:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/BSG1160:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 CPAK8963:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/CPAK8963:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:03
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:04
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:05
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:06
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:07
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:08 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:08
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:09 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:09
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:0a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/device:0a
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:0b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:0c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0c
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:0d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0d
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:0e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:0f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:10 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:11 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:11
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:12 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:12
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:13 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:13
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:14 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:14
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:15 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:14/device:15
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:16 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:16
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:17 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:17
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:18 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/device:18
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:19 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:1a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1a
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:1b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1b
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:1c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1c
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:1d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1d
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:1e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:1f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1f
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:20 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:21 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:22 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:23 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:23
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:24 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:24
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:25 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:25
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:26 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:26
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:27 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:27
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:28 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:28
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:29 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:29
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:2a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/device:21/device:22/device:2a
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:2b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2b
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:2c -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2c
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:2d -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2d
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:2e -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2e
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:2f -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2f
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:30 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:30
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:31 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F14:00/device:31
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:32 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33BB:00/device:32
lrwxrwxrwx 1 root root 0 15 jan 14:47 device:33 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33BB:00/device:33
lrwxrwxrwx 1 root root 0 15 jan 14:47 DIAL3010:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/DIAL3010:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 DMY0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/DMY0001:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 FTSC1000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:03/FTSC1000:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 FUSI0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/FUSI0001:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 GDIX1001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/GDIX1001:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 GDIX1001:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:03/GDIX1001:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 GODX0911:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/GODX0911:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 HAD0F28:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/HAD0F28:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 HIMX2056:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/HIMX2056:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 ID9001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/ID9001:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 IMPJ0003:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/IMPJ0003:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INBC0000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/INBC0000:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT0002:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT0002:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT0310:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/INT0310:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT0800:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/INT0800:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3396:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3396:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33BB:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33BB:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33BD:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33BD:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33F4:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/INT33F4:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33F5:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/INT33F5:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33F8:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/INT33F8:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33FC:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FC:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33FC:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FC:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33FC:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33FC:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33FD:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/INT33FD:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33FE:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/INT33FE:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT33FE:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/INT33FE:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3400:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3400:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3401:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3401:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3402:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3402:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:03
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:04
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:05
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:06
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:07
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3403:08 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3403:08
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3406:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3406:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3407:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3407:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3407:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3407:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3407:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3407:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT3409:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT3409:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INT5648:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/INT5648:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INTCFD9:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INTCFD9:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INTL9C60:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INTL9C60:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 INTL9C60:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INTL9C60:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 JSA1212:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/JSA1212:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXCPU:00 -> ../../../devices/LNXSYSTM:00/LNXCPU:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXCPU:01 -> ../../../devices/LNXSYSTM:00/LNXCPU:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXCPU:02 -> ../../../devices/LNXSYSTM:00/LNXCPU:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXCPU:03 -> ../../../devices/LNXSYSTM:00/LNXCPU:03
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/device:10/LNXPOWER:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/LNXPOWER:03
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:01/LNXPOWER:04
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:05
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:06
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:07
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:08 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:08
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:09 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:09
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:0a -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:0a
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXPOWER:0b -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/LNXPOWER:0b
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXSYBUS:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXSYBUS:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXSYSTM:00 -> ../../../devices/LNXSYSTM:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXTHERM:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:01/LNXTHERM:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 LNXVIDEO:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 MAX17047:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/MAX17047:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 MCD0001:00 -> ../../../devices/LNXSYSTM:00/MCD0001:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 MSFT0101:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/MSFT0101:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 NXP5442:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/NXP5442:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 OBDA8723:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F0A:00/OBDA8723:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/PNP0000:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0100:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/PNP0100:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0103:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0103:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0303:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/PNP0303:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0501:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/PNP0501:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0A08:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0B00:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0B00:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C02:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/PNP0C02:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C02:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C02:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0A:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/PNP0C0A:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0A:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/PNP0C0A:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0A:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:04/PNP0C0A:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0D:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:01 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:01
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:02 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:02
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:03 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:03
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:04 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:04
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:05 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:05
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:06 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:06
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0C0F:07 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0F:07
lrwxrwxrwx 1 root root 0 15 jan 14:47 PNP0F13:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/PNP0F13:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 RTL8723:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/INT33BB:00/RTL8723:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 SASX9500:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/SASX9500:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 SMB0349:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/SMB0349:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 SMO8500:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/SMO8500:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 SMSC3750:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/SMSC3750:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 SPBP0001:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:02/SPBP0001:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 SSPX0000:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F28:00/SSPX0000:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 TBQ24296:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/80860F41:00/TBQ24296:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 TIMC0F28:00 -> ../../../devices/LNXSYSTM:00/LNXSYBUS:00/TIMC0F28:00
Second result:
ls -l /sys/bus/i2c/devices/
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-0 -> ../../../devices/platform/80860F41:00/i2c-0
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-1 -> ../../../devices/platform/80860F41:01/i2c-1
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-10 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-10
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-10EC5640:00 -> ../../../devices/platform/80860F41:00/i2c-0/i2c-10EC5640:00
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-11 -> ../../../devices/pci0000:00/0000:00:02.0/drm/card0/card0-eDP-1/i2c-11
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-12 -> ../../../devices/pci0000:00/0000:00:02.0/drm/card0/card0-DP-1/i2c-12
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-2 -> ../../../devices/platform/80860F41:02/i2c-2
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-3 -> ../../../devices/platform/80860F41:03/i2c-3
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-4 -> ../../../devices/platform/80860F41:04/i2c-4
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-5 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-5
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-6 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-6
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-7 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-7
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-8 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-8
lrwxrwxrwx 1 root root 0 15 jan 14:57 i2c-9 -> ../../../devices/pci0000:00/0000:00:02.0/i2c-9
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-FTSC1000:00 -> ../../../devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-HIMX2056:00 -> ../../../devices/platform/80860F41:01/i2c-1/i2c-HIMX2056:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-INT33F4:00 -> ../../../devices/platform/80860F41:04/i2c-4/i2c-INT33F4:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-INT5648:00 -> ../../../devices/platform/80860F41:01/i2c-1/i2c-INT5648:00
lrwxrwxrwx 1 root root 0 15 jan 14:47 i2c-SMO8500:00 -> ../../../devices/platform/80860F41:02/i2c-2/i2c-SMO8500:00
pobrn
15 January 2021 15:09
13
What’s the output of sudo dmesg | egrep -i '(hid|i2c)'
AlanP
17 January 2021 12:27
14
Ok. Here are the results:
[ 0.307188] ACPI Error: Aborting method \_SB.I2C2.CAM1._STA due to previous error (AE_NOT_EXIST) (20200925/psparse-529)
[ 0.308116] ACPI Error: Aborting method \_SB.I2C2.CAM2._STA due to previous error (AE_NOT_EXIST) (20200925/psparse-529)
[ 0.308692] ACPI Error: Aborting method \_SB.I2C2.CAM3._STA due to previous error (AE_NOT_EXIST) (20200925/psparse-529)
[ 0.309275] ACPI Error: Aborting method \_SB.I2C2.CAM4._STA due to previous error (AE_NOT_EXIST) (20200925/psparse-529)
[ 0.985999] hid: raw HID events driver (C) Jiri Kosina
[ 1.053612] i2c_designware 80860F41:04: I2C bus managed by PUNIT
[ 3.674110] hid-generic 0003:048D:8595.0001: input,hiddev96,hidraw0: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8595)] on usb-0000:00:14.0-2.1/input0
[ 3.678954] hid-generic 0003:048D:8595.0002: input,hidraw1: USB HID v1.10 Mouse [ITE Tech. Inc. ITE Device(8595)] on usb-0000:00:14.0-2.1/input1
[ 3.679270] usbcore: registered new interface driver usbhid
[ 3.679280] usbhid: USB HID core driver
[ 4.069119] itetech 0003:048D:8595.0001: input,hiddev96,hidraw0: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8595)] on usb-0000:00:14.0-2.1/input0
[ 4.119703] itetech 0003:048D:8595.0002: input,hidraw1: USB HID v1.10 Mouse [ITE Tech. Inc. ITE Device(8595)] on usb-0000:00:14.0-2.1/input1
[ 10.646769] axp20x-i2c i2c-INT33F4:00: AXP20x variant AXP288 found
[ 10.664694] i2c_hid i2c-FTSC1000:00: supply vdd not found, using dummy regulator
[ 10.664785] i2c_hid i2c-FTSC1000:00: supply vddl not found, using dummy regulator
[ 10.694526] axp20x-i2c i2c-INT33F4:00: AXP20X driver loaded
[ 10.834526] kxcjk1013 i2c-SMO8500:00: mounting matrix not found: using identity...
[ 10.989405] input: FTSC1000:00 2808:50C5 Touchscreen as /devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00/0018:2808:50C5.0003/input/input8
[ 10.989642] input: FTSC1000:00 2808:50C5 as /devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00/0018:2808:50C5.0003/input/input10
[ 10.989835] hid-generic 0018:2808:50C5.0003: input,hidraw2: I2C HID v1.00 Device [FTSC1000:00 2808:50C5] on i2c-FTSC1000:00
[ 12.045557] input: axp20x-pek as /devices/platform/80860F41:04/i2c-4/i2c-INT33F4:00/axp221-pek/input/input14
[ 12.400806] input: FTSC1000:00 2808:50C5 as /devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00/0018:2808:50C5.0003/input/input15
[ 12.401049] input: FTSC1000:00 2808:50C5 UNKNOWN as /devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00/0018:2808:50C5.0003/input/input17
[ 12.401212] hid-multitouch 0018:2808:50C5.0003: input,hidraw2: I2C HID v1.00 Device [FTSC1000:00 2808:50C5] on i2c-FTSC1000:00
[ 12.911355] Modules linked in: snd_hdmi_lpe_audio(+) i915 joydev mousedev iTCO_wdt mei_hdcp mac_hid intel_pmc_bxt iTCO_vendor_support snd_soc_sst_bytcr_rt5640 hid_multitouch r8723bs(C) intel_rapl_msr intel_soc_dts_thermal intel_powerclamp coretemp kvm_intel extcon_axp288 axp288_fuel_gauge axp288_charger roles axp20x_pek axp288_adc gpio_keys kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel cfg80211 aesni_intel i2c_algo_bit crypto_simd cryptd glue_helper drm_kms_helper intel_cstate cec pcspkr intel_gtt snd_soc_rt5670 syscopyarea mei_txe snd_soc_rt5651 sysfillrect mei sysimgblt fb_sys_fops snd_soc_rt5645 lpc_ich snd_intel_sst_acpi hci_uart snd_soc_acpi_intel_match snd_soc_rt5640 snd_soc_acpi snd_intel_sst_core btqca snd_soc_rl6231 tpm_crb btrtl btbcm snd_soc_sst_atom_hifi2_platform btintel snd_soc_core tpm_tis tpm_tis_core bluetooth tpm snd_compress rng_core ac97_bus dw_dmac snd_pcm_dmaengine dptf_power snd_pcm int3406_thermal processor_thermal_device video ecdh_generic
[ 12.911532] kxcjk_1013 intel_rapl_common int3403_thermal rfkill int3400_thermal industrialio_triggered_buffer int340x_thermal_zone intel_soc_dts_iosf kfifo_buf acpi_thermal_rel ecc soc_button_array snd_timer acpi_pad i2c_hid intel_int0002_vgpio axp20x_i2c industrialio snd axp20x intel_cht_int33fe soundcore 8250_dw pwm_lpss_platform pwm_lpss drm crypto_user fuse agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 uas usb_storage hid_ite usbhid mmc_block crc32c_intel xhci_pci sdhci_acpi sdhci mmc_core
Note: Now, I switched to Manjaro Gnome with Wayland by default for my hardware. So, I don’t use it under Kde plasma. I can’t modify the title of this subject.
@Hanzel : Thanks to have modify the tile of this subject.
pobrn
17 January 2021 13:11
15
Can you post the output of cat /proc/bus/input/devices
AlanP
17 January 2021 13:24
16
I: Bus=0019 Vendor=0000 Product=0005 Version=0000
N: Name="Lid Switch"
P: Phys=PNP0C0D/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
U: Uniq=
H: Handlers=event0
B: PROP=0
B: EV=21
B: SW=1
I: Bus=0003 Vendor=048d Product=8595 Version=0110
N: Name="ITE Tech. Inc. ITE Device(8595)"
P: Phys=usb-0000:00:14.0-2.1/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.1/1-2.1:1.0/0003:048D:8595.0001/input/input6
U: Uniq=
H: Handlers=sysrq kbd leds event1 rfkill
B: PROP=0
B: EV=12001f
B: KEY=300ff 0 0 483ffff17aff32d bfd4444600000000 1 930c730b17c007 ffbf7bfad941dfff febeffdfffefffff fffffffffffffffe
B: REL=1040
B: ABS=100000000
B: MSC=10
B: LED=1f
P: Phys=usb-0000:00:14.0-2.1/input1
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.1/1-2.1:1.1/0003:048D:8595.0002/input/input7
U: Uniq=
H: Handlers=event2 mouse0
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0
B: REL=1943
B: MSC=10
I: Bus=0010 Vendor=001f Product=0001 Version=0100
N: Name="PC Speaker"
P: Phys=isa0061/input0
S: Sysfs=/devices/platform/pcspkr/input/input11
U: Uniq=
H: Handlers=kbd event5
B: PROP=0
B: EV=40001
B: SND=6
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="axp20x-pek"
P: Phys=m1kbd/input2
S: Sysfs=/devices/platform/80860F41:04/i2c-4/i2c-INT33F4:00/axp221-pek/input/input12
U: Uniq=
H: Handlers=kbd event6
B: PROP=0
B: EV=3
B: KEY=10000000000000 0
I: Bus=0018 Vendor=2808 Product=50c5 Version=0100
N: Name="FTSC1000:00 2808:50C5"
P: Phys=i2c-FTSC1000:00
S: Sysfs=/devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00/0018:2808:50C5.0003/input/input13
U: Uniq=
H: Handlers=event3 mouse1
B: PROP=2
B: EV=1b
B: KEY=400 0 0 0 0 0
B: ABS=3273800000000003
B: MSC=20
N: Name="FTSC1000:00 2808:50C5 UNKNOWN"
S: Sysfs=/devices/platform/80860F41:03/i2c-3/i2c-FTSC1000:00/0018:2808:50C5.0003/input/input15
U: Uniq=
H: Handlers=event4 mouse2
B: PROP=0
B: EV=1b
B: KEY=c01 0 0 0 0 0
B: ABS=1000003
B: MSC=10
I: Bus=0019 Vendor=0001 Product=0001 Version=0100
N: Name="gpio-keys"
P: Phys=gpio-keys/input0
S: Sysfs=/devices/platform/INTCFD9:00/gpio-keys.1.auto/input/input16
U: Uniq=
H: Handlers=kbd event7
B: PROP=0
B: EV=100003
B: KEY=c000000000000 0
N: Name="gpio-keys"
S: Sysfs=/devices/platform/INTCFD9:00/gpio-keys.2.auto/input/input17
U: Uniq=
H: Handlers=kbd event8
B: PROP=0
B: EV=3
B: KEY=2000000000000000 0
N: Name="bytcr-rt5640 Headset"
P: Phys=ALSA
S: Sysfs=/devices/platform/80860F28:00/bytcr_rt5640/sound/card0/input18
U: Uniq=
H: Handlers=kbd event9
B: PROP=0
B: EV=23
B: KEY=1000000000 0 0
B: SW=14
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input19
U: Uniq=
H: Handlers=kbd event10
B: PROP=0
B: EV=3
B: KEY=3e000b00000000 0 0 0
N: Name="Intel HDMI/DP LPE Audio HDMI/DP,pcm=0"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input20
U: Uniq=
H: Handlers=event11
B: PROP=0
B: EV=21
B: SW=140
N: Name="Intel HDMI/DP LPE Audio HDMI/DP,pcm=1"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card1/input21
U: Uniq=
H: Handlers=event12
B: PROP=0
B: EV=21
B: SW=140
pobrn
17 January 2021 18:28
17
Can you post the output of libinput list-devices
AlanP
19 January 2021 10:36
18
Hi,
sudo libinput list-devices
Device: Video Bus
Kernel: /dev/input/event10
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Accel profiles: n/a
Rotation: n/a
Device: Lid Switch
Kernel: /dev/input/event0
Group: 2
Capabilities: switch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: ITE Tech. Inc. ITE Device(8595)
Group: 3
Capabilities: keyboard pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: disabled
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Kernel: /dev/input/event2
Group: 3
Capabilities: pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: button
Click methods: none
Accel profiles: flat *adaptive
Rotation: n/a
Device: bytcr-rt5640 Headset
Kernel: /dev/input/event9
Group: 4
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: FTSC1000:00 2808:50C5
Kernel: /dev/input/event7
Group: 5
Capabilities: touch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: identity matrix
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: FTSC1000:00 2808:50C5 UNKNOWN
Kernel: /dev/input/event8
Group: 5
Capabilities: tablet
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: none
Rotation: n/a
Device: axp20x-pek
Kernel: /dev/input/event6
Group: 6
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: gpio-keys
Kernel: /dev/input/event3
Group: 7
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: gpio-keys
Kernel: /dev/input/event4
Group: 7
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
pobrn
19 January 2021 12:42
19
Please post the output of grep . /sys/bus/acpi/devices/*/status
and ls -l /sys/bus/i2c/devices/*/
AlanP
19 January 2021 13:28
20
/sys/bus/acpi/devices/10EC5640:00/status:15
/sys/bus/acpi/devices/10TI3100:00/status:0
/sys/bus/acpi/devices/80860F0A:00/status:15
/sys/bus/acpi/devices/80860F0A:01/status:15
/sys/bus/acpi/devices/80860F0E:00/status:0
/sys/bus/acpi/devices/80860F09:00/status:0
/sys/bus/acpi/devices/80860F09:01/status:0
/sys/bus/acpi/devices/80860F14:00/status:15
/sys/bus/acpi/devices/80860F14:01/status:0
/sys/bus/acpi/devices/80860F14:02/status:15
/sys/bus/acpi/devices/80860F28:00/status:15
/sys/bus/acpi/devices/80860F41:00/status:15
/sys/bus/acpi/devices/80860F41:01/status:15
/sys/bus/acpi/devices/80860F41:02/status:15
/sys/bus/acpi/devices/80860F41:03/status:15
/sys/bus/acpi/devices/80860F41:04/status:15
/sys/bus/acpi/devices/ADMA0F28:00/status:0
/sys/bus/acpi/devices/AKM09911:00/status:0
/sys/bus/acpi/devices/AMCR0F28:00/status:0
/sys/bus/acpi/devices/AUTH2750:00/status:0
/sys/bus/acpi/devices/BCM2E3A:00/status:0
/sys/bus/acpi/devices/BCM4752:00/status:0
/sys/bus/acpi/devices/BSBA0150:00/status:0
/sys/bus/acpi/devices/BSBG0160:00/status:0
/sys/bus/acpi/devices/BSBG0160:01/status:0
/sys/bus/acpi/devices/BSBM0150:00/status:0
/sys/bus/acpi/devices/BSG1160:00/status:0
/sys/bus/acpi/devices/CPAK8963:00/status:0
/sys/bus/acpi/devices/device:0a/status:15
/sys/bus/acpi/devices/device:0f/status:15
/sys/bus/acpi/devices/device:2f/status:0
/sys/bus/acpi/devices/device:20/status:0
/sys/bus/acpi/devices/device:32/status:15
/sys/bus/acpi/devices/device:33/status:15
/sys/bus/acpi/devices/DIAL3010:00/status:0
/sys/bus/acpi/devices/DMY0001:00/status:0
/sys/bus/acpi/devices/FTSC1000:00/status:15
/sys/bus/acpi/devices/FUSI0001:00/status:0
/sys/bus/acpi/devices/GDIX1001:00/status:0
/sys/bus/acpi/devices/GDIX1001:01/status:0
/sys/bus/acpi/devices/GODX0911:00/status:0
/sys/bus/acpi/devices/HAD0F28:00/status:0
/sys/bus/acpi/devices/HIMX2056:00/status:15
/sys/bus/acpi/devices/IMPJ0003:00/status:0
/sys/bus/acpi/devices/INBC0000:00/status:0
/sys/bus/acpi/devices/INT0002:00/status:15
/sys/bus/acpi/devices/INT33BB:00/status:15
/sys/bus/acpi/devices/INT33F4:00/status:15
/sys/bus/acpi/devices/INT33F5:00/status:0
/sys/bus/acpi/devices/INT33F8:00/status:0
/sys/bus/acpi/devices/INT33FC:00/status:15
/sys/bus/acpi/devices/INT33FC:01/status:15
/sys/bus/acpi/devices/INT33FC:02/status:15
/sys/bus/acpi/devices/INT33FD:00/status:0
/sys/bus/acpi/devices/INT33FE:00/status:15
/sys/bus/acpi/devices/INT33FE:01/status:0
/sys/bus/acpi/devices/INT0310:00/status:0
/sys/bus/acpi/devices/INT3396:00/status:15
/sys/bus/acpi/devices/INT3400:00/status:15
/sys/bus/acpi/devices/INT3401:00/status:15
/sys/bus/acpi/devices/INT3402:00/status:0
/sys/bus/acpi/devices/INT3403:00/status:0
/sys/bus/acpi/devices/INT3403:01/status:0
/sys/bus/acpi/devices/INT3403:02/status:15
/sys/bus/acpi/devices/INT3403:03/status:15
/sys/bus/acpi/devices/INT3403:04/status:15
/sys/bus/acpi/devices/INT3403:05/status:0
/sys/bus/acpi/devices/INT3403:06/status:15
/sys/bus/acpi/devices/INT3403:07/status:15
/sys/bus/acpi/devices/INT3403:08/status:15
/sys/bus/acpi/devices/INT3406:00/status:15
/sys/bus/acpi/devices/INT3407:00/status:15
/sys/bus/acpi/devices/INT3407:01/status:15
/sys/bus/acpi/devices/INT3407:02/status:15
/sys/bus/acpi/devices/INT3409:00/status:15
/sys/bus/acpi/devices/INT5648:00/status:15
/sys/bus/acpi/devices/INTCFD9:00/status:15
/sys/bus/acpi/devices/INTL9C60:00/status:15
/sys/bus/acpi/devices/INTL9C60:01/status:15
/sys/bus/acpi/devices/JSA1212:00/status:0
/sys/bus/acpi/devices/LNXPOWER:00/status:15
/sys/bus/acpi/devices/LNXPOWER:0a/status:0
/sys/bus/acpi/devices/LNXPOWER:0b/status:0
/sys/bus/acpi/devices/LNXPOWER:01/status:0
/sys/bus/acpi/devices/LNXPOWER:02/status:1
/sys/bus/acpi/devices/LNXPOWER:03/status:3
/sys/bus/acpi/devices/LNXPOWER:04/status:3
/sys/bus/acpi/devices/LNXPOWER:05/status:1
/sys/bus/acpi/devices/LNXPOWER:06/status:1
/sys/bus/acpi/devices/LNXPOWER:07/status:0
/sys/bus/acpi/devices/LNXPOWER:08/status:0
/sys/bus/acpi/devices/LNXPOWER:09/status:0
/sys/bus/acpi/devices/MAX17047:00/status:0
/sys/bus/acpi/devices/MCD0001:00/status:0
/sys/bus/acpi/devices/MSFT0101:00/status:15
/sys/bus/acpi/devices/NXP5442:00/status:0
/sys/bus/acpi/devices/OBDA8723:00/status:15
/sys/bus/acpi/devices/PNP0C0A:00/status:0
/sys/bus/acpi/devices/PNP0C0A:01/status:31
/sys/bus/acpi/devices/PNP0C0A:02/status:0
/sys/bus/acpi/devices/PNP0C0D:00/status:15
/sys/bus/acpi/devices/PNP0C0F:00/status:9
/sys/bus/acpi/devices/PNP0C0F:01/status:9
/sys/bus/acpi/devices/PNP0C0F:02/status:9
/sys/bus/acpi/devices/PNP0C0F:03/status:9
/sys/bus/acpi/devices/PNP0C0F:04/status:9
/sys/bus/acpi/devices/PNP0C0F:05/status:9
/sys/bus/acpi/devices/PNP0C0F:06/status:9
/sys/bus/acpi/devices/PNP0C0F:07/status:9
/sys/bus/acpi/devices/PNP0F13:00/status:0
/sys/bus/acpi/devices/PNP0103:00/status:15
/sys/bus/acpi/devices/PNP0303:00/status:0
/sys/bus/acpi/devices/PNP0501:00/status:0
/sys/bus/acpi/devices/RTL8723:00/status:0
/sys/bus/acpi/devices/SASX9500:00/status:0
/sys/bus/acpi/devices/SMB0349:00/status:0
/sys/bus/acpi/devices/SMO8500:00/status:15
/sys/bus/acpi/devices/SMSC3750:00/status:0
/sys/bus/acpi/devices/SPBP0001:00/status:0
/sys/bus/acpi/devices/SSPX0000:00/status:0
/sys/bus/acpi/devices/TBQ24296:00/status:0
/sys/bus/acpi/devices/TIMC0F28:00/status:0
ls -l /sys/bus/i2c/devices/*/.
/sys/bus/i2c/devices/i2c-0/.:
total 0
--w------- 1 root root 4096 19 jan 14:17 delete_device
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../80860F41:00
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:00
drwxr-xr-x 3 root root 0 19 jan 14:14 i2c-10EC5640:00
-r--r--r-- 1 root root 4096 19 jan 14:14 name
--w------- 1 root root 4096 19 jan 14:17 new_device
drwxr-xr-x 2 root root 0 19 jan 14:17 power
lrwxrwxrwx 1 root root 0 19 jan 14:14 subsystem -> ../../../../bus/i2c
-rw-r--r-- 1 root root 4096 19 jan 14:14 uevent
/sys/bus/i2c/devices/i2c-1/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../80860F41:01
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:01
drwxr-xr-x 3 root root 0 19 jan 14:14 i2c-HIMX2056:00
drwxr-xr-x 3 root root 0 19 jan 14:14 i2c-INT5648:00
/sys/bus/i2c/devices/i2c-10/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../0000:00:02.0
lrwxrwxrwx 1 root root 0 19 jan 14:17 subsystem -> ../../../../bus/i2c
'/sys/bus/i2c/devices/i2c-10EC5640:00/.':
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 driver -> ../../../../../bus/i2c/drivers/rt5640
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:00/10EC5640:00
-r--r--r-- 1 root root 4096 19 jan 14:17 modalias
lrwxrwxrwx 1 root root 0 19 jan 14:14 subsystem -> ../../../../../bus/i2c
/sys/bus/i2c/devices/i2c-11/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../card0-eDP-1
lrwxrwxrwx 1 root root 0 19 jan 14:17 subsystem -> ../../../../../../../bus/i2c
/sys/bus/i2c/devices/i2c-12/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../card0-DP-1
/sys/bus/i2c/devices/i2c-2/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../80860F41:02
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:02
drwxr-xr-x 4 root root 0 19 jan 14:14 i2c-SMO8500:00
/sys/bus/i2c/devices/i2c-3/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../80860F41:03
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:03
drwxr-xr-x 4 root root 0 19 jan 14:14 i2c-FTSC1000:00
/sys/bus/i2c/devices/i2c-4/.:
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 device -> ../../80860F41:04
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:04
drwxr-xr-x 9 root root 0 19 jan 14:14 i2c-INT33F4:00
/sys/bus/i2c/devices/i2c-5/.:
total 0
/sys/bus/i2c/devices/i2c-6/.:
total 0
/sys/bus/i2c/devices/i2c-7/.:
total 0
/sys/bus/i2c/devices/i2c-8/.:
total 0
/sys/bus/i2c/devices/i2c-9/.:
total 0
'/sys/bus/i2c/devices/i2c-FTSC1000:00/.':
total 0
drwxr-xr-x 5 root root 0 19 jan 14:14 0018:2808:50C5.0003
lrwxrwxrwx 1 root root 0 19 jan 14:14 driver -> ../../../../../bus/i2c/drivers/i2c_hid
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:03/FTSC1000:00
lrwxrwxrwx 1 root root 0 19 jan 14:17 supplier:regulator.0 -> ../../../../virtual/devlink/regulator.0--i2c-FTSC1000:00
'/sys/bus/i2c/devices/i2c-HIMX2056:00/.':
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:01/HIMX2056:00
'/sys/bus/i2c/devices/i2c-INT33F4:00/.':
total 0
drwxr-xr-x 5 root root 0 19 jan 14:14 axp221-pek
drwxr-xr-x 4 root root 0 19 jan 14:14 axp288_adc
drwxr-xr-x 4 root root 0 19 jan 14:14 axp288_charger
drwxr-xr-x 5 root root 0 19 jan 14:14 axp288_extcon
drwxr-xr-x 4 root root 0 19 jan 14:14 axp288_fuel_gauge
drwxr-xr-x 3 root root 0 19 jan 14:14 axp288_pmic_acpi
lrwxrwxrwx 1 root root 0 19 jan 14:14 driver -> ../../../../../bus/i2c/drivers/axp20x-i2c
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:04/INT33F4:00
'/sys/bus/i2c/devices/i2c-INT5648:00/.':
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:01/INT5648:00
'/sys/bus/i2c/devices/i2c-SMO8500:00/.':
total 0
lrwxrwxrwx 1 root root 0 19 jan 14:14 driver -> ../../../../../bus/i2c/drivers/kxcjk1013
lrwxrwxrwx 1 root root 0 19 jan 14:17 firmware_node -> ../../../../LNXSYSTM:00/LNXSYBUS:00/80860F41:02/SMO8500:00
drwxr-xr-x 7 root root 0 19 jan 14:14 iio:device0
-r--r--r-- 1 root root 4096 19 jan 14:14 modalias
