Hi Everyone,
I just installed the latest update and my terminal app won’t launch. I tried going into a TTY and running sudo pacmain-mirrors -f5 && sudo pacman -Syu but ended up getting the message that there was nothing to do.
i downloaded xterm, and in place of the characters that would normally be there I see _p9k_init_params:72: character not in range.
manjaro%
The terminal in VSCode says the same thing. i can get by for now. Can anyone assist in how I might solve this issue?
Thank you Ben. I just found this in another thread and got myself running. However, you put it all in one comment so maybe future users will have an easier time than I did. Thank you so much Ben for the quick response, it’s greatly appreciated.
