Hi everyone.
I have been using Manjaro for a year and have always had this problem, I can’t hibernate. First my machine didn’t shut down, but reading the ArchWiki I fixed the problem, now when I turn on my machine shows me hardware errors and doesn’t restore the last image of the system.
Have any solution?
Because of they are hardware errors I won’t be able to hibernate?
These are the hardware errors
sudo dmesg | grep Error
[ 1.010371] mce: [Hardware Error]: Machine check events logged
[ 1.010373] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 4: f600000000070f0f
[ 1.010386] mce: [Hardware Error]: TSC 0 ADDR fed000f0
[ 1.010391] mce: [Hardware Error]: PROCESSOR 2:670f00 TIME 1659805200 SOCKET APIC 0 microcode 6006705
[ 1.018561] RAS: Correctable Errors collector initialized.
System Information
inxi -Fazy
Kernel: 6.0.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=37a244d3-b122-4232-97e3-6ee8575e8abe rw quiet splash apparmor=1
security=apparmor resume=UUID=0d9650c4-d6fa-4cf6-8f9d-78d2ed42dbe0
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: HP Laptop 14-bw0xx v: N/A
Mobo: HP model: 8324 v: 22.27 serial: <superuser required> UEFI: AMI
v: F.31 date: 07/01/2020
Info: model: AMD A6-9220 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1297 high: 1298 min/max: 1300/2500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1297 2: 1298
bogomips: 9985
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
API: OpenGL v: 4.5 Mesa 22.3.1 renderer: AMD Radeon R4 Graphics (stoney
LLVM 14.0.6 DRM 3.48 6.0.15-1-MANJARO) direct render: Yes
dev: /dev/sda3 maj-min: 8:3
I would greatly appreciate your help.
