I’m new to Manjaro, i use it for front-end development and my system is really slow. If i open vscode, a few web browsers and discord i already start lagging. The mouse has a high delay, switching between desktops takes like 1.5-2 seconds, and even the audio keeps cutting.
These are my specs
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=3cb5013d-fe39-453a-bffc-6828b7240a41 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=da2e74f9-44b1-4d99-933e-f82b1c813183 udev.log_priority=3
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Gigabyte product: B550M DS3H v: -CF serial: N/A
Mobo: Gigabyte model: B550M DS3H v: x.x serial: N/A UEFI: American
Megatrends LLC. v: F15 date: 07/29/2022
System RAM: total: 32 GiB available: 31.25 GiB used: 6.76 GiB (21.6%)
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF3200C16D4/16GX serial: <filter>
Device-2: DIMM 1 type: no module installed
Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM 1 type: no module installed
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP arch: Zen 3+
gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/4850 boost: enabled
base/boost: 3800/4850 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200 13: 2200
14: 2200 15: 2200 16: 2200 bogomips: 121420
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GT218 [GeForce 210] driver: nouveau v: kernel non-free:
series: 340.xx status: legacy (EOL) last: release: 340.108 kernel: 5.4
xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-13 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DVI-I-1,VGA-1
bus-ID: 05:00.0 chip-ID: 10de:0a65 class-ID: 0300 temp: 41.0 C
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Dell SE2216H serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 3.3 Mesa 23.0.4 renderer: NVA8 direct-render: Yes
Device-1: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 10de:0be3
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-400bd5cb9b36 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: br-a4245c59a6ab state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: veth1605388 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth505ba9a state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: veth8a79c97 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: veth982a794 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: veth9da14cf state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-9: vethb9e5d2d state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0bda:8771
Local Storage: total: 465.76 GiB used: 32.93 GiB (7.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SBI02102 temp: 39.9 C
scheme: GPT
ID-1: / raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
used: 32.92 GiB (7.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 3cb5013d-fe39-453a-bffc-6828b7240a41
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 45BA-84FA
ID-3: /home raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
ID-4: /var/cache raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
ID-5: /var/log raw-size: 431.09 GiB size: 431.09 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: da2e74f9-44b1-4d99-933e-f82b1c813183
Device-1: 1-10:2 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-1: 3-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 045e:0745 class-ID: 0300
Device-2: 3-2:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
System Temperatures: cpu: 52.8 C mobo: 30.0 C gpu: nouveau temp: 42.0 C
Processes: 496 Uptime: 18h 36m wakeups: 1 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1213 libs: 320 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Sudo (sudo) v: 1.9.14p1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.28
These are the commands i ran to setup everything, if it has something to do with the problem
sudo pacman-mirrors -f && sudo pacman -Syyuu
sudo pacman -S --needed base-devel fish git timeshift yay discord spotify-launcher starship dbeaver flameshot peek ttf-fira-code github-cli
yay -S google-chrome asdf-vm visual-studio-code-bin postman-bin postgresql-libs
...setup fish shell commands...
asdf plugin add nodejs
asdf install nodejs latest && asdf install nodejs 16.14.2 && asdf global nodejs latest && asdf reshim
corepack enable && asdf reshim && yarn -v
npm install --global hasura-cli serverless
sudo pacman -S docker docker-compose python-docker python-pip ansible libxcrypt-compat python-setuptools
sudo systemctl enable docker.service
sudo usermod -aG docker $USER
