rc270
October 18, 2021, 7:03am
1
So there is some answers about this topic but they dont seem to work and something that concerns me is the output of systemd-analyze here is the output:
Startup finished in 3min 5.160s (kernel) + 10min 32.036s (userspace) = 13min 37.197s
graphical.target reached after 8min 53.531s in userspace
edit by moderator - changed topic title
This an issue with your hardware and system configuration - not Manjaro as operating system.
My workstation
➜ ~ systemd-analyze
Startup finished in 21.337s (firmware) + 5.644s (loader) + 7.305s (kernel) + 7.383s (userspace) = 41.670s
graphical.target reached after 6.245s in userspace
I3 is a window manager so you are correct - there is something off.
A viable and the most likely cause is a failing disk.
Please post the outputs of the following commands.
systemd-analyze blame
systemd-analyze critical-chain
inxi -Fazy
Also check in GNOME disks if you have a failing HDD (Run SMART Data and Self-Tests)
We can only hypothesize until you provide the requested information.
From the suspicious 10 minutes delay, I suspect that you mounted a network drive or something where the wait time is 10 minutes (600 seconds).
