my system has become slow like when i open the application menu or the krunner. even at startup it slow.
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e33d7951-41d6-4429-ac3e-00ce19bbd9f5 rw quiet apparmor=1 security=apparmor
resume=UUID=a1d120e4-f6b6-47c2-aa5e-f96cf5292a96 udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: LightDM 1.30.0, SDDM
Type: Laptop System: HP product: HP ProBook 450 G6 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: HP model: 8538 v: KBC Version 51.2E.00 serial: <filter> UEFI: HP
v: R71 Ver. 01.16.00 date: 05/19/2021
ID-1: BAT0 charge: 12.5 Wh (44.6%) condition: 28.0/45.2 Wh (62.0%) volts: 11.0
min: 11.6 model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging cycles: 842
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: B (11) microcode: DE cache:
L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:174d
class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Integrated Webcam
type: USB driver: uvcvideo bus-ID: 1-2:2 chip-ID: 05c8:03cb class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb
v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Local Storage: total: 1.14 TiB used: 44.54 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 1B4QFXO7 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
ID-1: / raw-size: 34.18 GiB size: 33.35 GiB (97.56%) used: 16.18 GiB (48.5%) fs: ext4
dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 62.7 MiB (65.3%)
fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 523.76 GiB size: 514.47 GiB (98.23%) used: 28.3 GiB (5.5%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 7.85 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 41.0 C mobo: 38.0 C
Processes: 252 Uptime: 8m wakeups: 1 Memory: 7.65 GiB used: 2.53 GiB (33.1%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1257
pacman: 1253 lib: 351 flatpak: 0 snap: 4 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.04
