My system doesn´t wake up after suspension
Hi guys!!! when i put my Asus ExpertBook B1500 into suspension then it doesn´t wake up. My system info
  Kernel: 6.3.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
    root=UUID=034cce20-46f0-4762-a989-90f4125f7af9 rw quiet splash apparmor=1
    security=apparmor resume=UUID=35dedb6e-40ca-4832-b4a1-6fa39675484b
    udev.log_priority=3 noapic module_blacklist=intel_lpss_pci
  Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
  Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CEAEY_B1500CEAE
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: B1500CEAEY v: 1.0 serial: <superuser required>
    UEFI: ASUSTeK v: B1500CEAEY.312 date: 03/14/2022
  ID-1: BAT0 charge: 42.3 Wh (100.0%) condition: 42.3/42.1 Wh (100.5%)
    volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 1
  System RAM: available: 15.32 GiB used: 2.79 GiB (18.2%)
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 2154 high: 2800 min/max: 400/4700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2800 2: 950 3: 2800
    4: 1136 5: 2800 6: 2800 7: 1150 8: 2800 bogomips: 44864
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: DP-3,eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:5 chip-ID: 13d3:56a2
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-3 model: Dell E178FP serial: <filter> built: 2009
    res: 1280x1024 dpi: 96 gamma: 1.2 size: 338x270mm (13.31x10.63")
    diag: 433mm (17") ratio: 5:4 modes: max: 1280x1024 min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.3.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
    bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
  IF: eno2 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0026
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 1.15 TiB used: 480.15 GiB (40.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
    SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 21106000 temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion
    size: 698.64 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 9300 scheme: GPT
  ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 16.29 GiB (42.7%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 034cce20-46f0-4762-a989-90f4125f7af9
  ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6D27-E14D
  ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
    used: 767.6 MiB (2.6%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: Home uuid: eefcea03-6127-40e9-935c-c00395787289
  ID-4: /mnt/Ocio raw-size: 192.99 GiB size: 188.9 GiB (97.88%)
    used: 2.44 GiB (1.3%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: Ocio
    uuid: c4fcea3d-9d4c-4c00-af62-9feed8cf3d2d
  ID-5: /mnt/Trabajo raw-size: 205.08 GiB size: 200.8 GiB (97.91%)
    used: 70.91 GiB (35.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: Trabajo uuid: c79f5441-4c29-470e-be18-d9d1166dae00
  ID-6: /run/media/boris/Ocio raw-size: 356.46 GiB size: 349.79 GiB (98.13%)
    used: 183.21 GiB (52.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Ocio
    uuid: 05b90c5e-ace5-4fc9-9fc2-5714472e1c3e
  ID-7: /run/media/boris/Trabajo raw-size: 341.88 GiB
    size: 335.45 GiB (98.12%) used: 206.55 GiB (61.6%) fs: ext4 dev: /dev/sda2
    maj-min: 8:2 label: Trabajo uuid: 40f24dd8-62f9-4525-90a4-4f9984ce15d7
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 35dedb6e-40ca-4832-b4a1-6fa39675484b
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 1.03 GiB fs: ntfs label: RECOVERY
    uuid: 1E7A889E7A8873F5
  ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 200 MiB fs: vfat label: MYASUS
    uuid: 8276-1117
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-4: 3-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
  Device-1: 3-2.1:4 info: Logitech Optical Wheel Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c018 class-ID: 0301
  Device-2: 3-2.4:6 info: Logitech Keyboard K120 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31c class-ID: 0300
  Device-3: 3-4:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-4: 3-5:5 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: fe01 serial: <filter>
  Device-5: 3-7:7 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c6c class-ID: 0000
  Device-6: 3-10:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 4-1:3 info: Seagate RSS LLC SRD0NF1 Expansion Portable (STEA)
    type: mass storage driver: uas interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
    chip-ID: 0bc2:2322 class-ID: 0806 serial: <filter>
  Hub-6: 4-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
  System Temperatures: cpu: 44.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2300
  Processes: 287 Uptime: 14m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1282 libs: 364 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
The laptop is new, with Manjaro fresh install from yesterday…i tried to blacklist intel_lpss_pci module…to add noacpi parameter into grub…and still
Might not be enough space.
Hi @bedna!!! No enough space where??? Thanks
Your swap
There are almost 9 Gb on swap… :thinking: and 0 Kb used before suspend
How much memory do you have?
16 Gb of RAM…
According to the link I posted:
       RAM   No hibernation    With Hibernation  Maximum
       5GB              2GB                 7GB     10GB
       6GB              2GB                 8GB     12GB
       8GB              3GB                11GB     16GB
      12GB              3GB                15GB     24GB
      16GB              4GB                20GB     32GB
I have no used hibernation…then with 4Gb should be enough…instead i have almost 9…
Then you have to clarify what you mean by “suspension”.
Oh, sorry. Suspension: the temporary prevention of something from continuing or being in force or effect. In this context i refers to the act of suspend the system activity, saving it to RAM…by other hand, hibernation save the system status to disk…
Sorry again…
Ok, so you have completely disabled it going into hibernation?
Because by default, in “sleep” (saving in memory) it by default goes into hibernation after a certain time.
system settings > Power management.
If you have already done that, you need to provide way more info than this, logs from when it happens would be a start.
make it “happen” and then
journalctl --boot=0 -p3 could be a start.
This is a bit above where I feel comfortable to guide more.
Hi @bedna.!! Thanks again!!! No, i have not hibernation disabled…just that i had no use it , yet. I guess thats not the trouble because, i put the laptop into suspension …then…20 or 30 seconds later, i try to wake up the pc and this doesn´t do anything…anything…even pressing the power button…I let you here the output of journalctl --boot=0 -p3:
jun 07 14:19:43 B-Bunker kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB a>
jun 07 14:19:43 B-Bunker kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - ^SPI1.SPFD.CVFD (20210730/ds>
jun 07 14:19:43 B-Bunker kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - ^XHCI.RHUB.HS04.VI2C (202107>
jun 07 14:19:44 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20210730/psargs-330)
jun 07 14:19:44 B-Bunker kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
jun 07 14:19:44 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (2021073>
jun 07 14:19:44 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20210730/ps>
jun 07 14:19:44 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (2021073>
jun 07 14:19:44 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20210730/ps>
jun 07 14:19:44 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (2021073>
jun 07 14:19:44 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20210730/ps>
jun 07 14:19:44 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (2021073>
jun 07 14:19:44 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20210730/ps>
jun 07 14:19:44 B-Bunker kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
jun 07 14:19:45 B-Bunker bluetoothd[675]: src/plugin.c:plugin_init() Failed to init vcp plugin
jun 07 14:19:45 B-Bunker bluetoothd[675]: src/plugin.c:plugin_init() Failed to init mcp plugin
jun 07 14:19:45 B-Bunker bluetoothd[675]: src/plugin.c:plugin_init() Failed to init bap plugin
jun 07 14:19:55 B-Bunker gdm-password][1250]: gkr-pam: unable to locate daemon control file
jun 07 14:19:56 B-Bunker systemd[1267]: Failed to start Application launched by gnome-session-binary.
jun 07 14:19:58 B-Bunker systemd[1267]: Failed to start Application launched by gnome-session-binary.
jun 07 14:20:58 B-Bunker (metadata)[2633]: gvfs-metadata.service: Failed at step EXEC spawning /usr/lib/gvfsd-metadata: No such file or dir>
jun 07 14:20:58 B-Bunker systemd[1267]: Failed to start Virtual filesystem metadata service.
this is me testing on kernel 5.15…i see a lot of ACPI errors
Here is the output in kernel 6.1.29…
jun 07 15:07:23 B-Bunker kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - ^SPI1.SPFD.CVFD (20220331/ds>
jun 07 15:07:23 B-Bunker kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - ^XHCI.RHUB.HS04.VI2C (202203>
jun 07 15:07:23 B-Bunker kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
jun 07 15:07:23 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20220331/psargs-330)
jun 07 15:07:23 B-Bunker kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
jun 07 15:07:23 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (2022033>
jun 07 15:07:23 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20220331/ps>
jun 07 15:07:23 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (2022033>
jun 07 15:07:23 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20220331/ps>
jun 07 15:07:23 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (2022033>
jun 07 15:07:23 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20220331/ps>
jun 07 15:07:23 B-Bunker kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (2022033>
jun 07 15:07:23 B-Bunker kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20220331/ps>
jun 07 15:07:24 B-Bunker bluetoothd[738]: src/plugin.c:plugin_init() Failed to init vcp plugin
jun 07 15:07:24 B-Bunker bluetoothd[738]: src/plugin.c:plugin_init() Failed to init mcp plugin
jun 07 15:07:24 B-Bunker bluetoothd[738]: src/plugin.c:plugin_init() Failed to init bap plugin
jun 07 15:07:26 B-Bunker kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
jun 07 15:07:32 B-Bunker gdm-password][1237]: gkr-pam: unable to locate daemon control file
jun 07 15:07:32 B-Bunker systemd[1280]: Failed to start Application launched by gnome-session-binary.
jun 07 15:07:34 B-Bunker systemd[1280]: Failed to start Application launched by gnome-session-binary.
You might try installing linux61-acpi_call
(Or the ones for your actual kernel.)
why do you have this parameter?
and you are on RAID, instead of AHCI:
and its possible this is causing the suspend issue… dont switch to ahci if you are using windows, otherwise you will not be able to boot into it…
Hi @brahma … Thanks by your answer!!! I really don´t know the reason of that…this is a fresh install of manjaro on a new laptop Asus Expertbook B1500-CEAE, with 512 Gb SSD, 16 Gb Ram…Intel Core I7-1165G7…the installation process was smooth, like allways…i supose to change that to AHCI i have to reinstall again…or not? Thanks again
that noacpi parameter was added by you, so remove it, save grub, update grub:
sudo update-grub
reboot and in eyour bios/uefi change from RAID to AHCI - dont do this if you have windows, otherwise you will not be able to boot into it - and then test suspending…
Hi @brahma!!! Upgrading system solve it, my system works fine now …but i´ll review the matter of RAID to AHCI…About noapic parameter…i remove it too… Thanks!!!
