My sound output and input are not showing
I want this to get fix
here is my in inxi -Fxz output
  Kernel: 6.9.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
  Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: H110M-K v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4401
    date: 12/19/2023
  Info: quad core model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
    rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 800 min/max: 800/3800 cores: 1: 800 2: 800 3: 800 4: 800
    bogomips: 27208
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] driver: nvidia v: 550.90.07
    arch: Pascal bus-ID: 01:00.0
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch resolution: 1600x900~60Hz
  API: EGL v: 1.5 drivers: nvidia,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
    3GB/PCIe/SSE2
  API: Vulkan v: 1.3.279 drivers: nvidia surfaces: xcb,xlib devices: 1
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
  Device-3: Logitech G435 Wireless Gaming Headset
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-8:6
  API: ALSA v: k6.9.5-1-MANJARO status: kernel-api
  Server-1: sndiod v: N/A status: off
  Server-2: PipeWire v: 1.0.7 status: off
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
  Device-2: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
    driver: rtl8821au type: USB bus-ID: 1-5:3
  IF: wlp0s20f0u5 state: up mac: <filter>
  Local Storage: total: 447.13 GiB used: 54.32 GiB (12.1%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
  ID-1: / size: 438.75 GiB used: 54.32 GiB (12.4%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 324 KiB (0.1%) fs: vfat
    dev: /dev/sda1
  ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 39 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 27%
  Memory: total: 16 GiB available: 15.56 GiB used: 2.26 GiB (14.5%)
  Processes: 219 Uptime: 9m Init: systemd
  Packages: 1328 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 inxi: 3.3.35
inxi -Aa output
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a170 class-ID: 0403
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10f1 class-ID: 0403
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-8:6 chip-ID: 046d:0acb class-ID: 0300
    serial: 202105190004
  API: ALSA v: k6.9.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: off with: 1: pipewire-pulse
    status: active 2: wireplumber status: off 3: pipewire-alsa type: plugin
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
I suggest reboot system and check inxi -Aa again. If PipeWire, pipewire-pulse and Wireplumber are not shown as active, check services for errors
systemctl --user status pipewire pipewire-pulse wireplumber
sorry for late reply
here
× pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Tue 2024-07-02 20:00:54 +07; 1min 21s ago
   Duration: 56ms
 Invocation: 22cf41b477cf4965983719f4512cc4d7
TriggeredBy: × pipewire.socket
    Process: 828 ExecStart=/usr/bin/pipewire (code=exited, status=254)
   Main PID: 828 (code=exited, status=254)
Jul 02 20:00:54 Solar-System systemd[648]: pipewire.service: Scheduled restart job, restart counter is at 6.
Jul 02 20:00:54 Solar-System systemd[648]: pipewire.service: Start request repeated too quickly.
Jul 02 20:00:54 Solar-System systemd[648]: pipewire.service: Failed with result 'exit-code'.
Jul 02 20:00:54 Solar-System systemd[648]: Failed to start PipeWire Multimedia Service.
● pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
     Active: active (running) since Tue 2024-07-02 20:00:52 +07; 1min 23s ago
 Invocation: 5f70995b15b34c88899a15699960ea9a
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 661 (pipewire-pulse)
      Tasks: 3 (limit: 19040)
     Memory: 2.3M (peak: 2.8M)
        CPU: 79ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─661 /usr/bin/pipewire-pulse
Jul 02 20:02:11 Solar-System pipewire-pulse[661]: mod.protocol-pulse: 0x60d10cf37d90: failed to connect client: H>
Jul 02 20:02:11 Solar-System pipewire-pulse[661]: mod.protocol-pulse: client 0x60d10cf59e10 [Plasma PA]: ERROR co>
Jul 02 20:02:12 Solar-System pipewire-pulse[661]: mod.protocol-pulse: 0x60d10cf37d90: failed to connect client: H>
Jul 02 20:02:12 Solar-System pipewire-pulse[661]: mod.protocol-pulse: client 0x60d10cf597c0 [Plasma PA]: ERROR co>
Jul 02 20:02:13 Solar-System pipewire-pulse[661]: mod.protocol-pulse: 0x60d10cf37d90: failed to connect client: H>
Jul 02 20:02:13 Solar-System pipewire-pulse[661]: mod.protocol-pulse: client 0x60d10cf59e10 [Plasma PA]: ERROR co>
Jul 02 20:02:14 Solar-System pipewire-pulse[661]: mod.protocol-pulse: 0x60d10cf37d90: failed to connect client: H>
Jul 02 20:02:14 Solar-System pipewire-pulse[661]: mod.protocol-pulse: client 0x60d10cf597c0 [Plasma PA]: ERROR co>
Jul 02 20:02:15 Solar-System pipewire-pulse[661]: mod.protocol-pulse: 0x60d10cf37d90: failed to connect client: H>
Jul 02 20:02:15 Solar-System pipewire-pulse[661]: mod.protocol-pulse: client 0x60d10cf59e10 [Plasma PA]: ERROR co>
○ wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
     Active: inactive (dead) since Tue 2024-07-02 20:00:54 +07; 1min 22s ago
   Duration: 54ms
 Invocation: e6059992309a4a04a47abc9435107dc5
    Process: 829 ExecStart=/usr/bin/wireplumber (code=exited, status=0/SUCCESS)
   Main PID: 829 (code=exited, status=0/SUCCESS)
Jul 02 20:00:54 Solar-System systemd[648]: Started Multimedia Service Session Manager.
Jul 02 20:00:54 Solar-System wireplumber[829]: wireplumber: stopped by signal: Terminated
Jul 02 20:00:54 Solar-System systemd[648]: Stopping Multimedia Service Session Manager...
Jul 02 20:00:54 Solar-System wireplumber[829]: wireplumber: disconnected from pipewire
Jul 02 20:00:54 Solar-System systemd[648]: Stopped Multimedia Service Session Manager.
Jul 02 20:00:54 Solar-System systemd[648]: Dependency failed for Multimedia Service Session Manager.
Jul 02 20:00:54 Solar-System systemd[648]: wireplumber.service: Job wireplumber.service/start failed with result >
I already reboot my PC by the way
I already fix this issue by delete configs from /etc/pipewire and ~/.config/pipewire
