Im sorry if i leave anything important out im new here. ive recently picked up a raid card and setup my raid 0 on boot. however once im into manjaro i cant find the array using fdisk -l.
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3f2a659a-3671-4df1-9834-f0cf564f7369 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F60h
date: 02/04/2021
RAM: total: 31.36 GiB used: 8.93 GiB (28.5%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3637 high: 4128 min/max: N/A cores: 1: 3593 2: 3593
3: 3593 4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 4128
12: 3593 bogomips: 86258
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 08:00.0
chip-ID: 1002:7340 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 5280x1080 s-dpi: 96 s-size: 1397x285mm (55.0x11.2")
s-diag: 1426mm (56.1")
Monitor-1: DP-1 res: 1440x900 hz: 60 dpi: 89 size: 410x256mm (16.1x10.1")
diag: 483mm (19")
Monitor-2: DP-2 res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-3 res: 1920x1080 hz: 60 dpi: 90 size: 544x303mm (21.4x11.9")
diag: 623mm (24.5")
OpenGL: renderer: AMD Radeon RX 5500 XT (NAVI14 DRM 3.42.0
5.15.7-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 08:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:2 chip-ID: 08bb:2902
class-ID: 0300
Device-4: Tenx USB AUDIO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:3 chip-ID: 1130:1620
class-ID: 0300
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI modules: r8169 port: e000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Hardware-1: Broadcom / LSI MegaRAID SAS 2008 [Falcon] driver: N/A v: N/A
port: d000 bus-ID: 05:00.0 chip-ID: 1000:0073 rev: N/A class-ID: 0104
Local Storage: total: 3.87 TiB used: 96.51 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUA723030ALA640
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: NS00 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Silicon Power model: SPCC M.2 SSD
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.5 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 96.51 GiB (41.4%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 3f2a659a-3671-4df1-9834-f0cf564f7369
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
uuid: B405-66A4
ID-1: /dev/sda1 maj-min: 8:1 size: 1.78 TiB fs: ntfs label: mass storage
uuid: 78B6B03DB6AFF9B0
ID-2: /dev/sda2 maj-min: 8:2 size: 976.56 GiB fs: ext4 label: linux space
uuid: 717f1286-144a-4f30-807d-1c5fc22f54e1
ID-3: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: video drive
uuid: B83E774D3E7703A2
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Samsung Galaxy A5 (MTP) type: Still Imaging
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 04e8:6860 class-ID: 0601 serial: <filter>
Device-2: 1-2:3 info: Corsair Vengeance K70R keyboard type: Keyboard,HID
driver: corsair,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1b1c:1b09 class-ID: 0300
Device-3: 1-5:4 info: Microsoft XBOX ACC type: <vendor specific>
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-4: 1-6:5 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Texas Instruments PCM2902 Audio Codec
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 08bb:2902 class-ID: 0300
Device-2: 3-4:3 info: Tenx USB AUDIO type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 1130:1620 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 63.0 C mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1350
Processes: 345 Uptime: 3h 19m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1383 pacman: 1367 lib: 381
flatpak: 7 snap: 9 Shell: Zsh v: 5.8 default: Bash v: 5.1.12
running-in: konsole inxi: 3.3.11
