My pc slows down frequently and I always force restart. And I looked at the log for the crash. Is there a solution? Should I be worried?
I'm afraid it happened again. This time I was launching dark souls remastered in wine. Also the system tells me update because there is new kernel available.
This the output of journalctl -xe -p3 -b-1 this time.
 [nirvash@nirvash-pc ~]$ journalctl -xe -p3 -b-1
                                                    #16 0x000055b7de1712b3 n/a (kdeinit5)
                                                    #17 0x000055b7de1723da n/a (kdeinit5)
                                                    #18 0x000055b7de172d4e n/a (kdeinit5)
                                                    #19 0x000055b7de16db5c n/a (kdeinit5)
                                                    #20 0x00007f053eeefee3 __libc_start_main (libc.so.6)
                                                    #21 0x000055b7de16e83e n/a (kdeinit5)
-- Subject: Process 17000 (file.so) dumped core
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/technical-issues-and-assistance
-- Documentation: man:core(5)
-- Process 17000 (file.so) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
Aug 13 08:54:11 nirvash-pc kernel: ACPI Error: AE_BAD_PARAMETER, Returned by Handler for [EmbeddedControl] (20180810/evregion-264)
Aug 13 08:54:11 nirvash-pc kernel: ACPI Error: Method parse/execution failed \_SB.ADP0._PSR, AE_BAD_PARAMETER (20180810/psparse-514)
Aug 13 08:54:11 nirvash-pc kernel: ACPI Error: AE_BAD_PARAMETER, Error reading AC Adapter state (20180810/ac-128)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: AE_BAD_PARAMETER, Error reading AC Adapter state (20180810/ac-128)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: AE_BAD_PARAMETER, Returned by Handler for [EmbeddedControl] (20180810/evregion-264)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.EC0.BAT0._STA, AE_BAD_PARAMETER (20180810/psparse-514)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: AE_ERROR, Evaluating _STA (20180810/battery-470)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: Method parse/execution failed \_SB.ADP0._PSR, AE_BAD_PARAMETER (20180810/psparse-514)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.EC0.BAT0._BST, AE_BAD_PARAMETER (20180810/psparse-514)
Aug 13 08:54:13 nirvash-pc kernel: ACPI Error: AE_BAD_PARAMETER, Evaluating _BST (20180810/battery-577)
Aug 13 08:54:13 nirvash-pc kernel: ses 4:0:0:1: Wrong diagnostic page; asked for 1 got 8
Aug 13 08:54:13 nirvash-pc kernel: ses 4:0:0:1: Failed to get diagnostic page 0x1
Aug 13 08:54:13 nirvash-pc kernel: ses 4:0:0:1: Failed to bind enclosure -19
Aug 13 08:54:13 nirvash-pc kernel: sd 4:0:0:0: [sda] No Caching mode page found
Aug 13 08:54:13 nirvash-pc kernel: sd 4:0:0:0: [sda] Assuming drive cache: write through
Aug 13 08:54:13 nirvash-pc kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Aug 14 10:15:05 nirvash-pc kernel: xhci_hcd 0000:00:14.0: Canceled URB td not found on endpoint ring
Aug 14 10:15:05 nirvash-pc kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
I should point out it happened again when I restarted. It happened again when I launched Dark souls.
-- Logs begin at Sat 2019-07-06 16:43:28 IST, end at Wed 2019-08-14 13:45:27 IST. --
Aug 14 13:15:42 nirvash-pc kernel: DMAR: Failed to find handle for ACPI object \_SB.PCI0.SDMA
Aug 14 13:15:42 nirvash-pc kernel: DMAR: Failed to find handle for ACPI object \_SB.PCI0.SDHC
Aug 14 13:15:42 nirvash-pc kernel: scsi 4:0:0:1: Wrong diagnostic page; asked for 1 got 8
Aug 14 13:15:42 nirvash-pc kernel: scsi 4:0:0:1: Failed to get diagnostic page 0x1
Aug 14 13:15:42 nirvash-pc kernel: scsi 4:0:0:1: Failed to bind enclosure -19
Aug 14 13:15:42 nirvash-pc kernel: sd 4:0:0:0: [sdb] No Caching mode page found
Aug 14 13:15:42 nirvash-pc kernel: sd 4:0:0:0: [sdb] Assuming drive cache: write through
Aug 14 13:15:48 nirvash-pc kernel: kvm: disabled by bios
Aug 14 13:15:48 nirvash-pc kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Aug 14 13:15:48 nirvash-pc kernel: uvcvideo: Failed to query (GET_INFO) UVC control 8 on unit 1: -32 (exp. 1).
Install the latest kernel and see if it makes any difference...
And you can also try to disable your webcam (you have one right?) I'm out of options now.
Found another article about this problem (or related)
If you can switch this in your bios? -> Do you have BIOS or Uefi enabled in your laptop? If it uses Uefi, switch to "bios & uefi". Or back.
Maybe with one of them, your laptop will not boot, but you can change it to it's default setting when rebooting.
