My pc cannot enter sleep mode
Hi
Every time I try to put my computer to sleep, it immediately wakes up to the login screen. It doesn’t work using the GUI nor the systemctl suspend command.
It works fine on Windows (I have it installed as dual boot) but not on Manjaro.
System info:
  Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=01341831-433a-4cc7-ab38-9221b823d145 rw quiet apparmor=1
  Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: B550 AORUS PRO V2 v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B550 AORUS PRO V2 serial: <superuser required>
    UEFI: American Megatrends LLC. v: F14 date: 01/04/2022
  ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
    model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
    serial: <filter> status: Charging
  RAM: total: 15.59 GiB used: 2.52 GiB (16.2%)
  RAM Report:
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2575 high: 3593 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2194 2: 2570
    3: 2869 4: 3586 5: 2867 6: 2869 7: 2195 8: 2195 9: 2195 10: 2192 11: 2193
    12: 2189 13: 3593 14: 2871 15: 2869 16: 2872 17: 2875 18: 2868 19: 2775
    20: 2194 21: 2194 22: 2191 23: 2194 24: 2194 bogomips: 177357
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
    v: kernel bus-ID: 09:00.0 chip-ID: 1002:73bf class-ID: 0300
  Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
    loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  OpenGL: renderer: AMD Radeon RX 6900 XT (SIENNA_CICHLID DRM 3.42.0
    5.15.19-1-MANJARO LLVM 13.0.0)
    v: 4.6 Mesa 21.3.5 direct render: Yes
  Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
    driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: Logitech Logitech G PRO X Gaming Headset type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:5 chip-ID: 046d:0aaa
    class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
  Local Storage: total: 5.46 TiB used: 246.22 GiB (4.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
    model: WD My Passport 2627 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B type: N/A serial: <filter> rev: 4010 scheme: GPT
  ID-1: / raw-size: 931.15 GiB size: 915.46 GiB (98.31%)
    used: 97.96 GiB (10.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: Manjaro uuid: 01341831-433a-4cc7-ab38-9221b823d145
    used: 27.3 MiB (28.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 54CE-CB5A
  ID-3: /shared raw-size: 247.56 GiB size: 247.56 GiB (100.00%)
    used: 148.23 GiB (59.9%) fs: ntfs dev: /dev/nvme0n1p4 maj-min: 259:4
    label: Shared uuid: 92A816A5A81687BD
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 683.59 GiB fs: ntfs label: N/A
    uuid: 4662CFC262CFB549
  ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 617 MiB fs: ntfs label: N/A
    uuid: 7CCE644FCE64042C
  ID-4: /dev/sda1 maj-min: 8:1 size: 3.64 TiB fs: ntfs label: My Passport
    uuid: 3CD2A402D2A3BF10
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-6.1:4 info: Logitech USB Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c539 class-ID: 0300
  Device-2: 1-7:3 info: Integrated Express ITE Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-3: 1-9:5 info: Logitech Logitech G PRO X Gaming Headset
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 046d:0aaa class-ID: 0300
    serial: <filter>
  Hub-3: 1-10:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-3:2 info: Western Digital My Passport 2627 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
    chip-ID: 1058:2627 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-2:2 info: Cooler Master ARES type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 2516:014d class-ID: 0300
  Hub-6: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-4:2 info: Logitech G213 Prodigy Gaming Keyboard
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 046d:c336 class-ID: 0300
    serial: <filter>
  Hub-8: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 16.8 C mobo: N/A gpu: amdgpu temp: 40.0 C
    mem: 40.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 457 Uptime: 1m wakeups: 3 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1352 pacman: 1346 lib: 395
  flatpak: 6 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.12
How to increase your chances of solving your issue:
Please provide Information:
Switch from Windows - how to use GNU/Linux:
didi you solve it?
No, but to be honest I didn’t make much other research after that
me too
