My network do not work after suspend :(
Piece of lspci -v :
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8071 PCI-E Gigabit Ethernet Controller (rev 16)
Subsystem: Acer Incorporated [ALI] Device 014e
Flags: bus master, fast devsel, latency 0, IRQ 28, NUMA node 0
Memory at feafc000 (64-bit, non-prefetchable) [size=16K]
I/O ports at e800 [size=256]
Expansion ROM at feac0000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: sky2
Kernel modules: sky2
What can i do that my ethernet works after suspend? Now it says that the wire is not connected. When i reboot the machine all works, but again after suspend not.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
The output the the requested inxi output is:
  Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ad079feb-c216-4568-ac28-f3a2396e38a6 rw quiet splash apparmor=1
  Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop System: Acer product: Extensa E420 v: N/A serial: <filter>
  Chassis: type: 3 serial: <filter>
  Mobo: Acer model: RS780HVF serial: <filter> BIOS: American Megatrends
  v: R01-C0 date: 06/04/2009
  RAM: total: 7.77 GiB used: 2.58 GiB (33.2%)
  Info: Dual Core model: AMD Athlon 5400B bits: 64 type: MCP arch: K8 rev.F+
  family: F (15) model-id: 6B (107) stepping: 2 microcode: 83 cache:
  L2: 1024 KiB bogomips: 11199
  Speed: 1000 MHz min/max: 1000/2800 MHz Core speeds (MHz): 1: 1800 2: 1800
  Flags: 3dnow 3dnowext 3dnowprefetch apic clflush cmov cmp_legacy cpuid
  cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr fxsr_opt ht lahf_lm lbrv
  lm mca mce mmx mmxext msr mtrr nopl nx pae pat pge pni pse pse36 rdtscp
  rep_good sep sse sse2 svm syscall tsc vme vmmcall
  Type: spec_store_bypass status: Not affected
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: AMD RV710 [Radeon HD 4350/4550] vendor: PC Partner Limited
  driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:954f class-ID: 0300
  Device-2: Microdia Camera type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-4:3 chip-ID: 0c45:6340 class-ID: 0102
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
  OpenGL: renderer: AMD RV710 (DRM 2.50.0 / 5.10.56-1-MANJARO LLVM 12.0.1)
  v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
  class-ID: 0403
  Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series]
  vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 1002:aa38 class-ID: 0403
  Device-3: Microdia Camera type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  Device-1: Marvell 88E8071 PCI-E Gigabit Ethernet
  vendor: Acer Incorporated ALI driver: sky2 v: 1.30 port: e800
  bus-ID: 02:00.0 chip-ID: 11ab:436b class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 386.27 GiB used: 103.84 GiB (26.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3250820AS
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: N/A serial: <filter> rev: C scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS722516VLAT80
  size: 153.39 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
  type: N/A serial: <filter> rev: A6MA scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH40F rev: MG01
  dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 15.5 GiB (16.2%)
  fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: ad079feb-c216-4568-ac28-f3a2396e38a6
  ID-2: /home raw-size: 135.23 GiB size: 132.05 GiB (97.65%)
  used: 3.54 GiB (2.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 8e043de3-3674-4fc8-9c0e-e91e4e110f98
  ID-3: /run/media/markku/Omat tiedostot raw-size: 153.38 GiB
  size: 149.97 GiB (97.78%) used: 84.8 GiB (56.5%) fs: ext4 dev: /dev/sdb1
  maj-min: 8:17 label: Omat tiedostot
  uuid: 27ea1ee6-1c10-4f6b-ab80-c21233b7a3a5
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 1-4:3 info: Microdia Camera type: Video,Audio
  power: 500mA chip-ID: 0c45:6340 class-ID: 0102
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
  chip-ID: 1d6b:0001 class-ID: 0900
  Device-1: 3-3:2 info: SiGma Micro USB Keyboard type: Keyboard
  power: 98mA chip-ID: 1c4f:0040 class-ID: 0300
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
  Device-1: 6-2:2 info: Microsoft Nano Transceiver 1.1
  type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 045e:07fd class-ID: 0301
  Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: radeon temp: 66.0 C
  Processes: 233 Uptime: 8h 13m wakeups: 0 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1276
  pacman: 1263 lib: 336 flatpak: 4 snap: 9 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.06```
Nyt minä olen estänyt suspend tilaan pääsyn kokonaan kun ei ole mukavaa käynnistää konetta aina uudelleen.
  1. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  2. No need to do anything right now as I’m a moderator here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
  3. That’s really old: is there no BIOS update (BIOS errors can cause suspend issues as well)
  4. If you have tlp running, install tlp-gui and prohibit any energy saving on your WiFi card or as you have a desktop anyway, turn of all energy savings in the BIOS and remove tlp
  5. Please read this and adapt as having no swap file can inhibit hybrid suspend.
:+1:
Tänään kokeilin virransäästön päälle ja seuraavaa sain päätteeltä:
-- Journal begins at Mon 2021-08-09 16:33:30 EEST, ends at Thu 2021-08-12 20:27:58 EEST. --
elo 12 10:09:21 markku-extensae420 systemd[1]: Starting Network Manager...
elo 12 10:09:24 markku-extensae420 NetworkManager[671]: <info>  [1628752164.0729] NetworkManager (version 1.32.6-1) is starting... (for the first time)
elo 12 10:09:24 markku-extensae420 NetworkManager[671]: <info>  [1628752164.2967] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
elo 12 10:09:25 markku-extensae420 NetworkManager[671]: <info>  [1628752165.4791] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
elo 12 10:09:25 markku-extensae420 systemd[1]: Started Network Manager.
elo 12 10:09:25 markku-extensae420 NetworkManager[671]: <info>  [1628752165.5286] manager[0x563e89ed3000]: monitoring kernel firmware directory '/lib/firmware'.
elo 12 10:09:25 markku-extensae420 NetworkManager[671]: <info>  [1628752165.9490] hostname: hostname: using hostnamed
elo 12 10:09:25 markku-extensae420 NetworkManager[671]: <info>  [1628752165.9491] hostname: hostname changed from (none) to "markku-extensae420"
elo 12 10:09:25 markku-extensae420 NetworkManager[671]: <info>  [1628752165.9503] dns-mgr[0x563e89e8b250]: init: dns=default,systemd-resolved rc-manager=symlink
elo 12 10:09:26 markku-extensae420 NetworkManager[671]: <info>  [1628752166.1634] manager[0x563e89ed3000]: rfkill: Wi-Fi hardware radio set enabled
elo 12 10:09:26 markku-extensae420 NetworkManager[671]: <info>  [1628752166.1635] manager[0x563e89ed3000]: rfkill: WWAN hardware radio set enabled
elo 12 10:09:27 markku-extensae420 NetworkManager[671]: <info>  [1628752167.3538] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-ovs.so)
elo 12 10:09:27 markku-extensae420 NetworkManager[671]: <info>  [1628752167.4744] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-wifi.so)
elo 12 10:09:27 markku-extensae420 NetworkManager[671]: <info>  [1628752167.9014] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-team.so)
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.3769] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-wwan.so)
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.5378] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-bluetooth.so)
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.5843] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-adsl.so)
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.5859] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.5862] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.5864] manager: Networking is enabled by state file
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.6084] dhcp-init: Using DHCP client 'internal'
elo 12 10:09:28 markku-extensae420 NetworkManager[671]: <info>  [1628752168.9412] settings: Loaded settings plugin: keyfile (internal)
elo 12 10:09:29 markku-extensae420 NetworkManager[671]: <info>  [1628752169.1747] device (lo): carrier: link connected
elo 12 10:09:29 markku-extensae420 NetworkManager[671]: <info>  [1628752169.1758] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
elo 12 10:09:29 markku-extensae420 NetworkManager[671]: <info>  [1628752169.1977] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
elo 12 10:09:29 markku-extensae420 NetworkManager[671]: <info>  [1628752169.2025] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
elo 12 10:09:29 markku-extensae420 NetworkManager[671]: <info>  [1628752169.4696] ovsdb: Yhdistäminen ei onnistunut:Tiedostoa tai hakemistoa ei ole
elo 12 10:09:29 markku-extensae420 NetworkManager[671]: <info>  [1628752169.4701] ovsdb: disconnected from ovsdb
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5463] device (enp2s0): carrier: link connected
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5467] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5479] policy: auto-activating connection 'Wired connection 1' (bb3f0527-cd57-37eb-a27a-e63ac2eed5bc)
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5489] device (enp2s0): Activation: starting connection 'Wired connection 1' (bb3f0527-cd57-37eb-a27a-e63ac2eed5bc)
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5491] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5495] manager: NetworkManager state is now CONNECTING
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5498] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5510] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.5769] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.7240] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.7247] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.7257] manager: NetworkManager state is now CONNECTED_LOCAL
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.7311] manager: NetworkManager state is now CONNECTED_SITE
elo 12 10:09:31 markku-extensae420 NetworkManager[671]: <info>  [1628752171.7321] policy: set 'Wired connection 1' (enp2s0) as default for IPv4 routing and DNS
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.0725] device (enp2s0): Activation: successful, device activated.
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.1743] manager: startup complete
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.1747] modem-manager: ModemManager not available
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.4882] modem-manager: ModemManager now available
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.9000] dhcp6 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.9047] policy: set 'Wired connection 1' (enp2s0) as default for IPv6 routing and DNS
elo 12 10:09:32 markku-extensae420 NetworkManager[671]: <info>  [1628752172.9052] dhcp6 (enp2s0): state changed unknown -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 10:09:33 markku-extensae420 NetworkManager[671]: <info>  [1628752173.2097] manager: NetworkManager state is now CONNECTED_GLOBAL
elo 12 10:12:03 markku-extensae420 NetworkManager[671]: <info>  [1628752323.1680] agent-manager: agent[6bd346004028272a,:1.65/org.gnome.Shell.NetworkAgent/1000]: agent registered
elo 12 10:39:22 markku-extensae420 NetworkManager[671]: <info>  [1628753962.0193] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 11:08:52 markku-extensae420 NetworkManager[671]: <info>  [1628755732.0196] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 11:37:40 markku-extensae420 NetworkManager[671]: <info>  [1628757460.3804] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 12:06:12 markku-extensae420 NetworkManager[671]: <info>  [1628759172.0194] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 12:34:34 markku-extensae420 NetworkManager[671]: <info>  [1628760874.1847] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 13:02:32 markku-extensae420 NetworkManager[671]: <info>  [1628762552.0192] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 13:31:22 markku-extensae420 NetworkManager[671]: <info>  [1628764282.0196] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 13:58:42 markku-extensae420 NetworkManager[671]: <info>  [1628765922.0196] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 14:27:52 markku-extensae420 NetworkManager[671]: <info>  [1628767672.0195] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 14:55:32 markku-extensae420 NetworkManager[671]: <info>  [1628769332.0196] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 15:25:02 markku-extensae420 NetworkManager[671]: <info>  [1628771102.0195] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 15:53:52 markku-extensae420 NetworkManager[671]: <info>  [1628772832.0195] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 16:22:32 markku-extensae420 NetworkManager[671]: <info>  [1628774552.0195] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 16:51:32 markku-extensae420 NetworkManager[671]: <info>  [1628776292.0198] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 17:20:52 markku-extensae420 NetworkManager[671]: <info>  [1628778052.0195] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 17:49:50 markku-extensae420 NetworkManager[671]: <info>  [1628779790.3754] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 18:16:55 markku-extensae420 NetworkManager[671]: <info>  [1628781415.8871] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 18:46:07 markku-extensae420 NetworkManager[671]: <info>  [1628783167.5075] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 19:13:55 markku-extensae420 NetworkManager[671]: <info>  [1628784835.1303] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 19:41:42 markku-extensae420 NetworkManager[671]: <info>  [1628786502.0195] dhcp6 (enp2s0): state changed bound -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.4791] manager: sleep: sleep requested (sleeping: no  enabled: yes)
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.4793] manager: NetworkManager state is now ASLEEP
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.4797] device (enp2s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.5700] device (enp2s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.5873] dhcp6 (enp2s0): canceled DHCP transaction
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.5873] dhcp6 (enp2s0): state changed bound -> terminated
elo 12 19:58:27 markku-extensae420 NetworkManager[671]: <info>  [1628787507.6936] device (enp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
elo 12 19:59:15 markku-extensae420 NetworkManager[671]: <info>  [1628787555.6942] manager: sleep: wake requested (sleeping: yes  enabled: yes)
elo 12 19:59:15 markku-extensae420 NetworkManager[671]: <info>  [1628787555.6954] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
elo 12 19:59:15 markku-extensae420 NetworkManager[671]: <info>  [1628787555.7150] manager: NetworkManager state is now DISCONNECTED
elo 12 20:07:02 markku-extensae420 NetworkManager[671]: <info>  [1628788022.9351] audit: op="connection-update" uuid="bb3f0527-cd57-37eb-a27a-e63ac2eed5bc" name="Wired connection 1" args="802-3-ethernet.cloned-mac-address,connection.timestamp" pid=24978 uid=1000 result="success"
elo 12 20:07:45 markku-extensae420 NetworkManager[671]: <info>  [1628788065.7858] audit: op="connection-update" uuid="bb3f0527-cd57-37eb-a27a-e63ac2eed5bc" name="Wired connection 1" args="802-3-ethernet.wake-on-lan" pid=24978 uid=1000 result="success"
elo 12 20:14:38 markku-extensae420 NetworkManager[671]: <info>  [1628788478.0429] modem-manager: ModemManager no longer available
elo 12 20:14:39 markku-extensae420 NetworkManager[671]: <info>  [1628788479.3053] caught SIGTERM, shutting down normally.
elo 12 20:14:39 markku-extensae420 systemd[1]: Stopping Network Manager...
elo 12 20:14:39 markku-extensae420 NetworkManager[671]: <info>  [1628788479.7551] exiting (success)
elo 12 20:14:39 markku-extensae420 systemd[1]: NetworkManager.service: Deactivated successfully.
elo 12 20:14:39 markku-extensae420 systemd[1]: Stopped Network Manager.
elo 12 20:14:39 markku-extensae420 systemd[1]: NetworkManager.service: Consumed 2.365s CPU time.
-- Boot 69457fd4915d4ecbb6b105ca09b15d2d --
elo 12 20:16:48 markku-extensae420 systemd[1]: Starting Network Manager...
elo 12 20:16:50 markku-extensae420 NetworkManager[1307]: <info>  [1628788610.8001] NetworkManager (version 1.32.6-1) is starting... (for the first time)
elo 12 20:16:50 markku-extensae420 NetworkManager[1307]: <info>  [1628788610.8574] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
elo 12 20:16:51 markku-extensae420 NetworkManager[1307]: <info>  [1628788611.5986] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
elo 12 20:16:51 markku-extensae420 systemd[1]: Started Network Manager.
elo 12 20:16:51 markku-extensae420 NetworkManager[1307]: <info>  [1628788611.7439] manager[0x5594644c7000]: monitoring kernel firmware directory '/lib/firmware'.
elo 12 20:16:52 markku-extensae420 NetworkManager[1307]: <info>  [1628788612.0793] hostname: hostname: using hostnamed
elo 12 20:16:52 markku-extensae420 NetworkManager[1307]: <info>  [1628788612.0793] hostname: hostname changed from (none) to "markku-extensae420"
elo 12 20:16:52 markku-extensae420 NetworkManager[1307]: <info>  [1628788612.0798] dns-mgr[0x55946447d250]: init: dns=default,systemd-resolved rc-manager=symlink
elo 12 20:16:52 markku-extensae420 NetworkManager[1307]: <info>  [1628788612.3277] manager[0x5594644c7000]: rfkill: Wi-Fi hardware radio set enabled
elo 12 20:16:52 markku-extensae420 NetworkManager[1307]: <info>  [1628788612.3286] manager[0x5594644c7000]: rfkill: WWAN hardware radio set enabled
elo 12 20:16:53 markku-extensae420 NetworkManager[1307]: <info>  [1628788613.2659] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-ovs.so)
elo 12 20:16:53 markku-extensae420 NetworkManager[1307]: <info>  [1628788613.3194] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-wifi.so)
elo 12 20:16:53 markku-extensae420 NetworkManager[1307]: <info>  [1628788613.8036] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-team.so)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.2000] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-wwan.so)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.3704] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-bluetooth.so)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.4189] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.32.6-1/libnm-device-plugin-adsl.so)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.4202] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.4204] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.4206] manager: Networking is enabled by state file
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.4464] dhcp-init: Using DHCP client 'internal'
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.6117] settings: Loaded settings plugin: keyfile (internal)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.7918] device (lo): carrier: link connected
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.7929] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.8120] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
elo 12 20:16:54 markku-extensae420 NetworkManager[1307]: <info>  [1628788614.8134] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
elo 12 20:16:55 markku-extensae420 NetworkManager[1307]: <info>  [1628788615.1552] ovsdb: Yhdistäminen ei onnistunut:Tiedostoa tai hakemistoa ei ole
elo 12 20:16:55 markku-extensae420 NetworkManager[1307]: <info>  [1628788615.1552] ovsdb: disconnected from ovsdb
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1714] device (enp2s0): carrier: link connected
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1718] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1730] policy: auto-activating connection 'Wired connection 1' (bb3f0527-cd57-37eb-a27a-e63ac2eed5bc)
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1740] device (enp2s0): Activation: starting connection 'Wired connection 1' (bb3f0527-cd57-37eb-a27a-e63ac2eed5bc)
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1742] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1751] manager: NetworkManager state is now CONNECTING
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1754] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.1766] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.2073] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.2402] modem-manager: ModemManager not available
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.2919] modem-manager: ModemManager now available
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.3033] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.3036] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.3041] manager: NetworkManager state is now CONNECTED_LOCAL
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.3047] manager: NetworkManager state is now CONNECTED_SITE
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.3048] policy: set 'Wired connection 1' (enp2s0) as default for IPv4 routing and DNS
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.4987] device (enp2s0): Activation: successful, device activated.
elo 12 20:16:57 markku-extensae420 NetworkManager[1307]: <info>  [1628788617.5720] manager: startup complete
elo 12 20:16:58 markku-extensae420 NetworkManager[1307]: <info>  [1628788618.1714] manager: NetworkManager state is now CONNECTED_GLOBAL
elo 12 20:16:58 markku-extensae420 NetworkManager[1307]: <info>  [1628788618.9619] dhcp6 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
elo 12 20:16:58 markku-extensae420 NetworkManager[1307]: <info>  [1628788618.9635] policy: set 'Wired connection 1' (enp2s0) as default for IPv6 routing and DNS
elo 12 20:16:58 markku-extensae420 NetworkManager[1307]: <info>  [1628788618.9637] dhcp6 (enp2s0): state changed unknown -> bound, address=2001:999:63:e51d:5001:d98b:57ee:3
elo 12 20:18:03 markku-extensae420 NetworkManager[1307]: <info>  [1628788683.1565] agent-manager: agent[9159ea83ed7e1ffd,:1.62/org.gnome.Shell.NetworkAgent/1000]: agent registered```
1. Toivottavasti nyt tuli oikein :o
2. ok :)
3. Koneeni on iäkäs, en tiedä tuon biosin päivitysmahdollisuudesta
4. En tiedä tuosta tlp: stä mitään.
5. En ole aikoihin määritellyt erillistä swap osiota kun luin jostain ettei välttämättä tarvitse
Ei
Etsi…
Etsi…
Tiedän: tee se joka tapauksessa…
:man_shrugging:
Nyt ymmärsin miten tuon 1. kohdan pitää näkyä :slight_smile:
Swap-osio luotu :).
Bios vielä työn alla tlp myös :).
Kiitos :slight_smile:
:finland: is only allowed in the #languages section, sp please revert to :uk: when you report back on progress.
:crossed_fingers:
Ok, my previous comment in english :):
Now I figured out how that 1. that needs to show.
Swap partition created :).
Bios still under construction tlp too :).
thank you
Any news???
Nothing new :(. I tried the systemctl “suspend command”, when the machine went into suspend mode and when I moved the mouse the machine woke up but the network had dropped off. The network settings just read that the cable is disconnected :). I think to myself that somehow related to the suspend function … the network card shuts down but does not wake up.
Are you sure it’s not the router/switch that drops the connection?
:thinking:
These problems started when I installed Manjaro, having used Mint Mate, Deepin and Ubuntu studio on the same machine in the past. There was no such effort in anyone, yes, but it’s about it :). The network has not changed in any way during this time. With these experiences, I would believe that something is rotting in Manjaro. I have now coped with this when I changed the settings so that the machine stays on all the time. It would be nice if you could make that suspend state work as well.
If you’ve used those and they work, can you please try and:
  • install kernel 5.4 and see if that resolves your issue?
  • Turn off IPV6
  • turn off any and all power saving features that you set on the network side…
:crossed_fingers:
P.S. Shout out if you don’t know how to do any of the above!
Ok, I will try :).
I added to /etc/default/grub the parameter Sky2.disable_msi = 1
resulting in:
GRUB_CMDLINE_LINUX_DEFAULT = "quiet splash app = 1 security = app udev.log_priority = 3 sky2.disable_msi = 1
The problem seems to be fixed now.
Thanks to the :finland: group!
Problem seems to be in the network driver. And the solution was to add sky2.disable_msi=1 to the kernel parameters. Aparently Ubuntu added this to their kernel some time ago, that’s why it worked there.
@masupa merkkaa yksi vastaus ratkaisuna / Mark one of the answers as the solution
