My monitor is going black randomly, sometimes multiple times a day, just once or not at all. It is not alot overakk, just sometimes. I typed Dmesg & this was in the info I got [ 9469.205501] nouveau 0000:29:00.0: DRM: core notifier timeout. What does that mean? I have the generic driver Manjaro installed with, so I don’t think that is it. It is a recent prob. maybe started a week back.
I had these problems also. What I have done: replaced the PSU and graphics card.
How can I find out the source, I have Wondered if it is my GPU? Just started a few weeks back, I am going to see if it happens in Windows yet, so far no. I have not installed any GPU driver, I am using X11. My card is just a year old though.
if you are using nouveau, thats probably the reason for the screen issues…
post full system info + what drivers are available and installed:
inxi -zav7
mhwd -l -li
I had the problems with monitor going black for some seconds also with Windows 10.
Some monitors need to go black for a few seconds once in a while to not get “burn in”. This may depend on the selected brightness. It is managed by a timer inside the monitor.
I have a ASUS TUF Gaming 32” 1440P Gaming Monitor (VG32AQL1A) - QHD (2560 x 1440), IPS, 170Hz, 1ms, Extreme Low Motion Blur Sync, FreeSync Premium, 99% DCI-P3, DisplayPort, HDMI, USB Hub, DisplayHDR 400, so the burn in isn’t it.
[edward78@nicholas ~]$ inxi -zav7
Kernel: 5.15.91-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=37c124d3-4218-4e44-9637-25b2aa80cc95 rw quiet apparmor=1
security=apparmor resume=UUID=c325ee10-e031-4249-8b4b-fb2e5586abcb
udev.log_priority=3
Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450I GAMING PLUS AC (MS-7A40) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.80
date: 07/22/2019
RAM: total: 15.57 GiB used: 4.08 GiB (26.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1467 high: 2323 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2323 2: 1337
3: 1334 4: 1437 5: 1376 6: 1375 7: 1377 8: 1375 9: 2057 10: 1307 11: 1338
12: 1337 13: 1377 14: 1381 15: 1375 16: 1377 bogomips: 102428
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: eVga.com. driver: nouveau v: kernel non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 29:00.0 chip-ID: 10de:2489
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.6 compositor: marco v: 1.26.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-3 model: VG32AQL1A serial: <filter> built: 2021
res: 2560x1440 dpi: 93 gamma: 1.2 size: 698x393mm (27.48x15.47")
diag: 806mm (31.7") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s bus-ID: 29:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound API: ALSA v: k5.15.91-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 26:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp38s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-8:5 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 1.82 TiB used: 444.87 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech.
model: SHGS31-1000GS-2 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0Q00
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 444.87 GiB (49.1%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 37c124d3-4218-4e44-9637-25b2aa80cc95
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 4413-3EE3
dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: c325ee10-e031-4249-8b4b-fb2e5586abcb
ID-1: /dev/sda1 maj-min: 8:1 size: 117.61 GiB fs: ntfs label: N/A
uuid: FEDE7716DE76C705
ID-2: /dev/sda2 maj-min: 8:2 size: 519 MiB fs: ntfs label: N/A
uuid: A2A8449DA8447239
ID-3: /dev/sda3 maj-min: 8:3 size: 538 MiB fs: ntfs label: N/A
uuid: 407C57BC7C57AC02
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda5 maj-min: 8:5 size: 621.03 GiB fs: ntfs label: Data
uuid: 1CE33ADD03B8E5A9
ID-6: /dev/sda6 maj-min: 8:6 size: 191.83 GiB fs: ntfs label: Download
uuid: 0AB4DCAC3851D241
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Logitech F310 Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
Device-2: 1-2:3 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4b61 class-ID: 0301
Device-3: 1-6:4 info: Microsoft IntelliMouse Optical type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 045e:0039 class-ID: 0301
Device-4: 1-8:5 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-4:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-6: 4-4:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 57.4 C mobo: N/A
Processes: 317 Uptime: 4h 3m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1281 libs: 365 tools: pamac Shell: Bash v: 5.1.16
running-in: mate-terminal inxi: 3.3.25
The other info.
[ 5.546333] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 5.546406] systemd[1]: Finished Load Kernel Module drm.
[ 5.547030] systemd[1]: Mounting Kernel Configuration File System...
[ 5.550166] systemd[1]: Mounted Kernel Configuration File System.
[ 5.609299] EXT4-fs (sdb2): re-mounted. Opts: (null). Quota mode: none.
[ 5.610482] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.610569] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 5.634295] fuse: init (API version 7.34)
[ 5.705965] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 5.706576] systemd[1]: Starting Load/Save Random Seed...
[ 5.706624] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 5.707170] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.707420] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 5.707525] systemd[1]: Finished Load Kernel Module fuse.
[ 5.708231] systemd[1]: Mounting FUSE Control File System...
[ 5.709391] systemd[1]: Mounted FUSE Control File System.
[ 5.818794] systemd[1]: Finished Coldplug All udev Devices.
[ 5.931766] systemd[1]: Finished Load Kernel Modules.
[ 5.932557] systemd[1]: Starting Apply Kernel Variables...
[ 6.149904] systemd[1]: Finished Apply Kernel Variables.
[ 6.434092] systemd[1]: Finished Load/Save Random Seed.
[ 6.434186] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 6.718559] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 6.730017] audit: type=1400 audit(1676034310.955:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=423 comm="apparmor_parser"
[ 6.730050] audit: type=1400 audit(1676034310.958:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-anvil" pid=427 comm="apparmor_parser"
[ 6.740368] audit: type=1400 audit(1676034310.968:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=416 comm="apparmor_parser"
[ 6.741211] audit: type=1400 audit(1676034310.968:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=416 comm="apparmor_parser"
[ 6.741525] audit: type=1400 audit(1676034310.968:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=415 comm="apparmor_parser"
[ 6.771418] audit: type=1400 audit(1676034310.998:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-deliver" pid=430 comm="apparmor_parser"
[ 6.784138] audit: type=1400 audit(1676034311.012:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=417 comm="apparmor_parser"
[ 6.784222] audit: type=1400 audit(1676034311.012:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=413 comm="apparmor_parser"
[ 6.786036] audit: type=1400 audit(1676034311.012:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-config" pid=429 comm="apparmor_parser"
[ 6.786483] audit: type=1400 audit(1676034311.012:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="syslogd" pid=425 comm="apparmor_parser"
[ 6.831088] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.831229] systemd[1]: Reached target Preparation for Local File Systems.
[ 6.831274] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 6.831295] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 6.833305] systemd[1]: Starting Journal Service...
[ 6.834567] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 6.985187] systemd[1]: Started Journal Service.
[ 7.057407] systemd-journald[453]: Received client request to flush runtime journal.
[ 14.126283] kauditd_printk_skb: 57 callbacks suppressed
[ 14.126287] audit: type=1130 audit(1676034318.355:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.313001] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 14.367379] acpi_cpufreq: overriding BIOS provided _PSD data
[ 14.395270] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 14.395279] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 14.400775] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 14.472525] cryptd: max_cpu_qlen set to 1000
[ 14.783255] AVX2 version of gcm_enc/dec engaged.
[ 14.783315] AES CTR mode by8 optimization enabled
[ 14.861329] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 14.861338] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 14.861495] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 14.862131] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 14.863046] ccp 0000:2a:00.2: enabling device (0000 -> 0002)
[ 14.863413] ccp 0000:2a:00.2: ccp enabled
[ 14.865573] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.964742] Intel(R) Wireless WiFi driver for Linux
[ 14.964793] iwlwifi 0000:26:00.0: enabling device (0000 -> 0002)
[ 15.035731] iwlwifi 0000:26:00.0: loaded firmware version 29.198743027.0 3168-29.ucode op_mode iwlmvm
[ 15.135405] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 15.135571] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 15.135782] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 15.192691] snd_hda_intel 0000:29:00.1: Disabling MSI
[ 15.192703] snd_hda_intel 0000:29:00.1: Handle vga_switcheroo audio client
[ 15.192807] snd_hda_intel 0000:2b:00.3: enabling device (0000 -> 0002)
[ 15.248509] r8169 0000:25:00.0 eth0: RTL8168h/8111h, 00:d8:61:a6:01:b0, XID 541, IRQ 68
[ 15.248516] r8169 0000:25:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 15.249826] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input3
[ 15.249889] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input4
[ 15.249945] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input5
[ 15.249986] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input6
[ 15.250038] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input7
[ 15.250082] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input8
[ 15.250158] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:29:00.1/sound/card0/input9
[ 15.321113] r8169 0000:25:00.0 enp37s0: renamed from eth0
[ 15.440643] kvm: disabled by bios
[ 15.517672] MCE: In-kernel MCE decoding enabled.
[ 15.518379] iwlwifi 0000:26:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[ 15.524677] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 15.536754] iwlwifi 0000:26:00.0: base HW address: 5c:87:9c:dd:78:72
[ 15.566821] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 15.567305] intel_rapl_common: Found RAPL domain package
[ 15.567309] intel_rapl_common: Found RAPL domain core
[ 15.610735] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 15.610742] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 15.610744] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 15.610747] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 15.610748] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 15.610750] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 15.610751] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 15.610753] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 15.623594] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:2b:00.3/sound/card1/input10
[ 15.623657] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:2b:00.3/sound/card1/input11
[ 15.623743] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:2b:00.3/sound/card1/input12
[ 15.623796] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:2b:00.3/sound/card1/input13
[ 15.623855] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:2b:00.3/sound/card1/input14
[ 15.688195] Console: switching to colour dummy device 80x25
[ 15.688235] nouveau 0000:29:00.0: vgaarb: deactivate vga console
[ 15.688272] nouveau 0000:29:00.0: NVIDIA GA104 (b74000a1)
[ 15.810484] iwlwifi 0000:26:00.0 wlp38s0: renamed from wlan0
[ 15.828324] nouveau 0000:29:00.0: bios: version 94.04.6b.00.83
[ 15.866373] audit: type=1130 audit(1676034320.092:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.011724] nouveau 0000:29:00.0: fb: 8192 MiB GDDR6
[ 16.025247] nouveau 0000:29:00.0: DRM: VRAM: 8192 MiB
[ 16.025252] nouveau 0000:29:00.0: DRM: GART: 536870912 MiB
[ 16.025256] nouveau 0000:29:00.0: DRM: BIT table 'A' not found
[ 16.025259] nouveau 0000:29:00.0: DRM: BIT table 'L' not found
[ 16.025262] nouveau 0000:29:00.0: DRM: TMDS table version 2.0
[ 16.025265] nouveau 0000:29:00.0: DRM: DCB version 4.1
[ 16.025268] nouveau 0000:29:00.0: DRM: DCB outp 00: 04800f86 04600020
[ 16.025272] nouveau 0000:29:00.0: DRM: DCB outp 01: 04000f82 00020020
[ 16.025276] nouveau 0000:29:00.0: DRM: DCB outp 02: 04811f76 04600010
[ 16.025279] nouveau 0000:29:00.0: DRM: DCB outp 03: 04011f72 00020010
[ 16.025282] nouveau 0000:29:00.0: DRM: DCB outp 04: 02822f66 04600020
[ 16.025284] nouveau 0000:29:00.0: DRM: DCB outp 05: 02022f62 00020020
[ 16.025287] nouveau 0000:29:00.0: DRM: DCB outp 07: 02033f52 00020010
[ 16.025290] nouveau 0000:29:00.0: DRM: DCB conn 00: 02000046
[ 16.025292] nouveau 0000:29:00.0: DRM: DCB conn 01: 01000146
[ 16.025295] nouveau 0000:29:00.0: DRM: DCB conn 02: 00020246
[ 16.025297] nouveau 0000:29:00.0: DRM: DCB conn 03: 00010361
[ 16.025701] nouveau 0000:29:00.0: DRM: MM: using COPY for buffer copies
[ 16.027667] snd_hda_intel 0000:29:00.1: bound 0000:29:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[ 16.047386] audit: type=1130 audit(1676034320.275:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-4413\x2d3EE3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.216617] nouveau 0000:29:00.0: DRM: allocated 2560x1440 fb: 0x200000, bo 000000004a901cf4
[ 16.216684] fbcon: nouveaudrmfb (fb0) is primary device
[ 17.276732] Adding 9227464k swap on /dev/sdb3. Priority:-2 extents:1 across:9227464k FS
[ 18.401021] nouveau 0000:29:00.0: DRM: core notifier timeout
[ 18.548756] Bluetooth: Core ver 2.22
[ 18.548783] NET: Registered PF_BLUETOOTH protocol family
[ 18.548785] Bluetooth: HCI device and connection manager initialized
[ 18.548789] Bluetooth: HCI socket layer initialized
[ 18.548793] Bluetooth: L2CAP socket layer initialized
[ 18.548796] Bluetooth: SCO socket layer initialized
[ 18.581942] Console: switching to colour frame buffer device 160x45
[ 18.597971] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.0/0003:1A2C:4B61.0001/input/input15
[ 18.653510] hid-generic 0003:1A2C:4B61.0001: input,hidraw0: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:03:00.0-2/input0
[ 18.679129] input: SEMICO USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input16
[ 18.733445] input: SEMICO USB Keyboard System Control as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input17
[ 18.733497] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.1/0003:1A2C:4B61.0002/input/input19
[ 18.733599] hid-generic 0003:1A2C:4B61.0002: input,hiddev96,hidraw1: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:03:00.0-2/input1
[ 18.745979] input: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6:1.0/0003:045E:0039.0003/input/input20
[ 18.746024] hid-generic 0003:045E:0039.0003: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)] on usb-0000:03:00.0-6/input0
[ 18.746042] usbcore: registered new interface driver usbhid
[ 18.746043] usbhid: USB HID core driver
[ 18.755551] input: Logitech Gamepad F310 as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-1/1-1:1.0/input/input21
[ 18.756271] usbcore: registered new interface driver xpad
[ 18.773974] nouveau 0000:29:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 18.802986] usbcore: registered new interface driver btusb
[ 18.807305] [drm] Initialized nouveau 1.3.1 20120801 for 0000:29:00.0 on minor 0
[ 18.819801] Bluetooth: hci0: Legacy ROM 2.x revision 5.0 build 25 week 20 2015
[ 18.819812] Bluetooth: hci0: Intel device is already patched. patch num: 39
[ 18.828481] mousedev: PS/2 mouse device common for all mice
[ 20.653415] audit: type=1130 audit(1676034324.882:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.863083] audit: type=1130 audit(1676034325.088:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.864804] audit: type=1334 audit(1676034325.092:74): prog-id=21 op=LOAD
[ 20.917009] audit: type=1127 audit(1676034325.145:75): pid=872 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 20.944057] audit: type=1130 audit(1676034325.172:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.982918] audit: type=1130 audit(1676034325.212:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.026896] audit: type=1130 audit(1676034325.255:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.186402] audit: type=1334 audit(1676034325.412:79): prog-id=22 op=LOAD
[ 21.186697] audit: type=1334 audit(1676034325.415:80): prog-id=23 op=LOAD
[ 21.186877] audit: type=1334 audit(1676034325.415:81): prog-id=24 op=LOAD
[ 22.805230] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.805235] Bluetooth: BNEP filters: protocol multicast
[ 22.805245] Bluetooth: BNEP socket layer initialized
[ 22.950728] NET: Registered PF_ALG protocol family
[ 23.557221] loop: module loaded
[ 23.557809] loop0: detected capacity change from 0 to 8
[ 23.627212] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 24.988716] NET: Registered PF_QIPCRTR protocol family
[ 26.831504] kauditd_printk_skb: 35 callbacks suppressed
[ 26.831511] audit: type=1130 audit(1676034331.058:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.921947] audit: type=1130 audit(1676034331.148:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.094177] audit: type=1130 audit(1676034331.322:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.130048] Generic FE-GE Realtek PHY r8169-0-2500:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2500:00, irq=MAC)
[ 27.178109] audit: type=1130 audit(1676034331.405:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.283579] r8169 0000:25:00.0 enp37s0: Link is Down
[ 30.013897] audit: type=1131 audit(1676034334.242:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 30.895512] r8169 0000:25:00.0 enp37s0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 30.895532] IPv6: ADDRCONF(NETDEV_CHANGE): enp37s0: link becomes ready
[ 31.121152] audit: type=1334 audit(1676034335.348:122): prog-id=36 op=LOAD
[ 31.121162] audit: type=1300 audit(1676034335.348:122): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff444a0660 a2=90 a3=61 items=0 ppid=1 pid=924 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj=unconfined key=(null)
[ 31.121167] audit: type=1327 audit(1676034335.348:122): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[ 31.386970] audit: type=1130 audit(1676034335.615:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.388852] audit: type=1334 audit(1676034335.615:124): prog-id=37 op=LOAD
[ 31.958313] kauditd_printk_skb: 2 callbacks suppressed
[ 31.958319] audit: type=1101 audit(1676034336.185:127): pid=1235 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.958336] audit: type=1103 audit(1676034336.185:128): pid=1235 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 31.958428] audit: type=1006 audit(1676034336.185:129): pid=1235 uid=0 subj=unconfined old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=1 res=1
[ 31.958448] audit: type=1300 audit(1676034336.185:129): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fff1a532d70 a2=3 a3=7fff1a532a85 items=0 ppid=1 pid=1235 auid=970 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj=unconfined key=(null)
[ 31.958453] audit: type=1327 audit(1676034336.185:129): proctitle="(systemd)"
[ 31.960146] audit: type=1105 audit(1676034336.188:130): pid=1235 uid=0 auid=970 ses=1 subj=unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.016854] audit: type=1334 audit(1676034336.245:131): prog-id=38 op=LOAD
[ 32.016864] audit: type=1300 audit(1676034336.245:131): arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffc71230040 a2=90 a3=0 items=0 ppid=1 pid=1235 auid=970 uid=970 gid=970 euid=970 suid=970 fsuid=970 egid=970 sgid=970 fsgid=970 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=unconfined key=(null)
[ 32.016869] audit: type=1327 audit(1676034336.245:131): proctitle="(systemd)"
[ 32.016875] audit: type=1334 audit(1676034336.245:132): prog-id=38 op=UNLOAD
[ 40.851393] kauditd_printk_skb: 25 callbacks suppressed
[ 40.851398] audit: type=1130 audit(1676034345.078:148): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.851406] audit: type=1131 audit(1676034345.078:149): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.882660] audit: type=1130 audit(1676034345.108:150): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.903527] audit: type=1334 audit(1676034345.132:151): prog-id=37 op=UNLOAD
[ 54.624827] audit: type=1131 audit(1676034358.857:152): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 54.754591] audit: type=1334 audit(1676034358.987:153): prog-id=31 op=UNLOAD
[ 54.754603] audit: type=1334 audit(1676034358.987:154): prog-id=30 op=UNLOAD
[ 54.754609] audit: type=1334 audit(1676034358.987:155): prog-id=29 op=UNLOAD
[ 54.818963] audit: type=1131 audit(1676034359.051:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 54.847889] audit: type=1334 audit(1676034359.081:157): prog-id=34 op=UNLOAD
[ 54.847901] audit: type=1334 audit(1676034359.081:158): prog-id=33 op=UNLOAD
[ 54.847906] audit: type=1334 audit(1676034359.081:159): prog-id=32 op=UNLOAD
[ 134.067504] audit: type=1100 audit(1676034438.307:160): pid=1297 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="edward78" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 134.067918] audit: type=1101 audit(1676034438.311:161): pid=1297 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="edward78" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 134.146703] audit: type=1106 audit(1676034438.387:162): pid=1225 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 134.146785] audit: type=1104 audit(1676034438.387:163): pid=1225 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 134.151088] audit: type=1103 audit(1676034438.394:164): pid=1297 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="edward78" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 134.151183] audit: type=1006 audit(1676034438.394:165): pid=1297 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 134.151195] audit: type=1300 audit(1676034438.394:165): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffccb920b30 a2=4 a3=7ffccb920844 items=0 ppid=999 pid=1297 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" subj=unconfined key=(null)
[ 134.151200] audit: type=1327 audit(1676034438.394:165): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003133003230
[ 134.176936] audit: type=1130 audit(1676034438.417:166): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 134.184874] audit: type=1101 audit(1676034438.427:167): pid=1320 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="edward78" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 138.516765] nouveau 0000:29:00.0: DRM: core notifier timeout
[ 139.206870] kauditd_printk_skb: 32 callbacks suppressed
[ 139.206876] audit: type=1334 audit(1676034443.447:186): prog-id=52 op=LOAD
[ 139.207148] audit: type=1334 audit(1676034443.447:187): prog-id=53 op=LOAD
[ 139.207305] audit: type=1334 audit(1676034443.447:188): prog-id=54 op=LOAD
[ 139.242880] audit: type=1130 audit(1676034443.484:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 139.463932] audit: type=1130 audit(1676034443.704:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 143.521846] audit: type=1130 audit(1676034447.764:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 144.336781] audit: type=1131 audit(1676034448.577:192): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 144.348776] audit: type=1131 audit(1676034448.590:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 148.797517] Bluetooth: RFCOMM TTY layer initialized
[ 148.797528] Bluetooth: RFCOMM socket layer initialized
[ 148.797532] Bluetooth: RFCOMM ver 1.11
[ 169.294473] audit: type=1131 audit(1676034473.533:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 169.377447] audit: type=1334 audit(1676034473.616:195): prog-id=54 op=UNLOAD
[ 169.377454] audit: type=1334 audit(1676034473.616:196): prog-id=53 op=UNLOAD
[ 169.377457] audit: type=1334 audit(1676034473.616:197): prog-id=52 op=UNLOAD
[ 914.461458] audit: type=1130 audit(1676035218.709:198): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 914.461470] audit: type=1131 audit(1676035218.709:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3272.562947] nouveau 0000:29:00.0: DRM: core notifier timeout
[ 3408.104505] audit: type=1100 audit(1676037712.357:200): pid=3831 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 3408.104542] audit: type=1101 audit(1676037712.357:201): pid=3831 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 3408.104868] audit: type=1103 audit(1676037712.357:202): pid=3831 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 3408.104944] audit: type=1105 audit(1676037712.357:203): pid=3831 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 4025.141466] audit: type=1334 audit(1676038329.392:204): prog-id=55 op=LOAD
[ 4025.142015] audit: type=1334 audit(1676038329.392:205): prog-id=56 op=LOAD
[ 4025.142151] audit: type=1334 audit(1676038329.395:206): prog-id=57 op=LOAD
[ 4025.182263] audit: type=1130 audit(1676038329.435:207): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4055.235871] audit: type=1131 audit(1676038359.489:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4055.345673] audit: type=1334 audit(1676038359.599:209): prog-id=57 op=UNLOAD
[ 4055.345684] audit: type=1334 audit(1676038359.599:210): prog-id=56 op=UNLOAD
[ 4055.345689] audit: type=1334 audit(1676038359.599:211): prog-id=55 op=UNLOAD
[ 4118.268106] audit: type=1334 audit(1676038422.519:212): prog-id=58 op=LOAD
[ 4118.268416] audit: type=1334 audit(1676038422.523:213): prog-id=59 op=LOAD
[ 4118.268561] audit: type=1334 audit(1676038422.523:214): prog-id=60 op=LOAD
[ 4118.327324] audit: type=1130 audit(1676038422.579:215): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4148.380135] audit: type=1131 audit(1676038452.633:216): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4148.504792] audit: type=1334 audit(1676038452.760:217): prog-id=60 op=UNLOAD
[ 4148.504803] audit: type=1334 audit(1676038452.760:218): prog-id=59 op=UNLOAD
[ 4148.504808] audit: type=1334 audit(1676038452.760:219): prog-id=58 op=UNLOAD
[ 7996.001690] audit: type=1334 audit(1676042300.280:220): prog-id=61 op=LOAD
[ 7996.002018] audit: type=1334 audit(1676042300.280:221): prog-id=62 op=LOAD
[ 7996.002173] audit: type=1334 audit(1676042300.280:222): prog-id=63 op=LOAD
[ 7996.047127] audit: type=1130 audit(1676042300.327:223): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8054.502641] audit: type=1131 audit(1676042358.780:224): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8054.639851] audit: type=1334 audit(1676042358.920:225): prog-id=63 op=UNLOAD
[ 8054.639861] audit: type=1334 audit(1676042358.920:226): prog-id=62 op=UNLOAD
[ 8054.639865] audit: type=1334 audit(1676042358.920:227): prog-id=61 op=UNLOAD
[ 9528.445520] audit: type=1100 audit(1676043832.739:228): pid=11453 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 9528.445603] audit: type=1101 audit(1676043832.739:229): pid=11453 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 9528.446129] audit: type=1103 audit(1676043832.739:230): pid=11453 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 9528.446269] audit: type=1105 audit(1676043832.739:231): pid=11453 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success
[nicholas edward78]# mhwd -l -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
> 0000:25:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:29:00.0 (0300:10de:2489) Display controller nVidia Corporation:
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Sorry for this, they need a way to attach files.
use formatting, click this icon in editor: </>
and copy the output there…
so install nvidia drivers, but first uninstall this:
sudo mhwd -r pci video-linux
install nvidia:
sudo mhwd -i pci video-nvidia
reboot and test
It has only been doing this for maybe 2 weeks, it was fine before that, odd. Will I have issues with it not booting to GUI sometimes or will Mate always boot up fine?
using nouveau is not good… so install nvidia as outlined above and test… but you should have no issues…
and if you have, we can install the open source drivers back…
Ok, thanks. When I typed the command to installed nvidie It said error: target not found: linux513-nvidia
Error: pacman failed!
Error: script failed!
you have dead kernels, post output from:
mhwd-kernel -li
Currently running: 5.15.91-1-MANJARO (linux515)
- linux513
- linux515
remove the 513:
sudo mhwd-kernel -r linux513
and continue with the nvidia installation…
Ok got it, hope that fixes it.
Nope still does it, hmmm. It is like my sys is going to sleep, but I have everything set to never in Power man. & the screensaver is off (it isn’t that anyway a week back I chose something besides blank screen & it is still blank screen when it happens). Is there a way to see just video errors? Maybe my card is going out, seems odd a button press would bring it back though. Could it be the kernel?
what you describing sounds like your monitor powers off after some time … looks like some system setting may trigger it…
does it happen also when you are doing something?
when it happens again, you can post logs here from:
journalctl -b0 -p4 --no-pager
It happens randomly, rarely sometimes not the whole day & at times a few times. I just has been doing it for a few weeks No screensaver & no power man. It has happened watching a youtube vid., once 2 times a few secs appart. It is losing signal I think, the msg always goes away before I can read it. It is not powering of, just a key press on the KB brings it back.
so when it happens again provide logs with the command above, maybe there will be something…
