I know my Mini PC is able to hibernate ok, because with CachyOS did hibernate.
I’ve read carefully the hibernate guide from the Arch wiki.
My setup:
- One non encryupted BTRFS partition holding root
- One LUKS encryupted BTRFS partition holding home
- A separated non encrypted partition for swap (26 Gb)
- KDE Plasma
- Grub
- AMD Ryzen 7 5800H with Radeon Graphics
- 32 Gb RAM
> uname -a
Linux peque 6.12.20-2-MANJARO #1 SMP PREEMPT_DYNAMIC Mon, 24 Mar 2025 06:33:36 +0000 x86_64 GNU/Linux
Some info about my system:
# swapon -s
Filename Type Size Used Priority
/dev/nvme0n1p1 partition 27339772 2497552 -2
# free -h
total usada livre compart. buff/cache disponível
Mem.: 28Gi 20Gi 1,6Gi 297Mi 6,6Gi 7,5Gi
Swap: 26Gi 2,4Gi 23Gi
# blkid /dev/nvme0n1p1
/dev/nvme0n1p1: UUID="df119baa-39a0-4654-a9ef-51f1e03f05f3" TYPE="swap" PARTUUID="8ded9620-6450-4b46-935a-16fc91c6bce8"
# grep resume /etc/mkinitcpio.conf
HOOKS=(base udev autodetect microcode kms modconf block keyboard keymap consolefont plymouth filesystems resume)
# grep GRUB_CMDLINE_LINUX_DEFAULT /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 resume=UUID=df119baa-39a0-4654-a9ef-51f1e03f05f3"
It seems that it tries to hibernate, because there is a delay while it is storing RAM contents to swap, but it doen’t resume. Instead it performs a clean boot.
An excerpt of dmesg
[ 0.000000] Linux version 6.12.20-2-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20250207, GNU ld (GNU Binutils) 2.44) #1 SMP PREEMPT_DYNAMIC Mon, 24 Mar 2025 06:33:36 +0000
[ 0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64 root=UUID=ccceccff-aa97-4f87-ba36-878c1d08d96a rw rootflags=subvol=@ quiet splash udev.log_priority=3 resume=UUID=df119baa-39a0-4654-a9ef-51f1e03f05f3
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009bfefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009bff000-0x000000000a000fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a001000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20f000-0x00000000cc222fff] usable
❯ head -n 500 dmesg-resume-fallado.txt
[ 0.000000] BIOS-e820: [mem 0x00000000cc223000-0x00000000cc3a3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000cc3a4000-0x00000000cc3f5fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cc3f6000-0x00000000cc5adfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cc5ae000-0x00000000ccdfefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ccdff000-0x00000000cdffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ce000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fdffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedc4000-0x00000000fedc9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedcc000-0x00000000fedcefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedd5000-0x00000000fedd5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000076e2fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000076e300000-0x000000082fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] e820: update [mem 0xc8811018-0xc881e857] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000009bfefff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000009bff000-0x000000000a000fff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000a001000-0x000000000a1fffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000a20f000-0x00000000c8811017] usable
[ 0.000000] reserve setup_data: [mem 0x00000000c8811018-0x00000000c881e857] usable
[ 0.000000] reserve setup_data: [mem 0x00000000c881e858-0x00000000cc222fff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000cc223000-0x00000000cc3a3fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000cc3a4000-0x00000000cc3f5fff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x00000000cc3f6000-0x00000000cc5adfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000cc5ae000-0x00000000ccdfefff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ccdff000-0x00000000cdffffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000ce000000-0x00000000cfffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fd000000-0x00000000fdffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fedc4000-0x00000000fedc9fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fedcc000-0x00000000fedcefff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fedd5000-0x00000000fedd5fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000076e2fffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000076e300000-0x000000082fffffff] reserved
[ 0.000000] efi: EFI v2.7 by American Megatrends
[ 0.000000] efi: ACPI=0xcc597000 ACPI 2.0=0xcc597014 TPMFinalLog=0xcc563000 SMBIOS=0xccc27000 SMBIOS 3.0=0xccc26000 MEMATTR=0xc87f4018 INITRD=0xc881fa98 RNG=0xcc3b3018 TPMEventLog=0xcc3b1018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem57: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
[ 0.000000] e820: remove [mem 0xf0000000-0xf7ffffff] reserved
[ 0.000000] efi: Remove mem58: MMIO range=[0xfd000000-0xfdffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xfd000000-0xfdffffff] reserved
[ 0.000000] efi: Remove mem59: MMIO range=[0xfeb80000-0xfec01fff] (0MB) from e820 map
[ 0.000000] e820: remove [mem 0xfeb80000-0xfec01fff] reserved
[ 0.000000] efi: Not removing mem60: MMIO range=[0xfec10000-0xfec10fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem61: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem62: MMIO range=[0xfed40000-0xfed44fff] (20KB) from e820 map
[ 0.000000] efi: Not removing mem63: MMIO range=[0xfed80000-0xfed8ffff] (64KB) from e820 map
[ 0.000000] efi: Not removing mem64: MMIO range=[0xfedc4000-0xfedc9fff] (24KB) from e820 map
[ 0.000000] efi: Not removing mem65: MMIO range=[0xfedcc000-0xfedcefff] (12KB) from e820 map
[ 0.000000] efi: Not removing mem66: MMIO range=[0xfedd5000-0xfedd5fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem67: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[ 0.000000] SMBIOS 3.3.0 present.
[ 0.000000] DMI: Trigkey S5/S5, BIOS 5800H506 03/29/2023
[ 0.000000] DMI: Memory slots populated: 2/2
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3194.137 MHz processor
[ 0.000129] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000130] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000136] last_pfn = 0x76e300 max_arch_pfn = 0x400000000
[ 0.000142] MTRR map: 5 entries (3 fixed + 2 variable; max 20), built from 9 variable MTRRs
[ 0.000143] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000293] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
[ 0.000299] last_pfn = 0xce000 max_arch_pfn = 0x400000000
[ 0.003341] Using GB pages for direct mapping
[ 0.003556] Secure boot disabled
[ 0.003556] RAMDISK: [mem 0xc186b000-0xc45a9fff]
[ 0.003578] ACPI: Early table checksum verification disabled
[ 0.003581] ACPI: RSDP 0x00000000CC597014 000024 (v02 ALASKA)
[ 0.003584] ACPI: XSDT 0x00000000CC596728 0000E4 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003587] ACPI: FACP 0x00000000CC3E8000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003591] ACPI: DSDT 0x00000000CC3DF000 008D01 (v02 ALASKA A M I 01072009 INTL 20200717)
[ 0.003593] ACPI: FACS 0x00000000CC561000 000040
[ 0.003594] ACPI: SSDT 0x00000000CC3EE000 0072B0 (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.003596] ACPI: IVRS 0x00000000CC3ED000 0001A4 (v02 AMD AmdTable 00000001 AMD 00000000)
[ 0.003597] ACPI: SSDT 0x00000000CC3E9000 003A21 (v01 AMD AMD AOD 00000001 INTL 20200717)
[ 0.003599] ACPI: FIDT 0x00000000CC3DE000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003601] ACPI: MCFG 0x00000000CC3DD000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.003602] ACPI: HPET 0x00000000CC3DC000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003604] ACPI: FPDT 0x00000000CC3DB000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003605] ACPI: VFCT 0x00000000CC3CD000 00D884 (v01 ALASKA A M I 00000001 AMD 31504F47)
[ 0.003607] ACPI: BGRT 0x00000000CC3CC000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003608] ACPI: TPM2 0x00000000CC3CB000 00004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.003610] ACPI: SSDT 0x00000000CC3C5000 005354 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003611] ACPI: CRAT 0x00000000CC3C4000 000EE8 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.003613] ACPI: CDIT 0x00000000CC3C3000 000029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.003614] ACPI: SSDT 0x00000000CC3C2000 000149 (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003616] ACPI: SSDT 0x00000000CC3C0000 00148E (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003617] ACPI: SSDT 0x00000000CC3BE000 00151E (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003619] ACPI: SSDT 0x00000000CC3BD000 00078E (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003620] ACPI: SSDT 0x00000000CC3BC000 000641 (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003621] ACPI: SSDT 0x00000000CC3B8000 00386E (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003623] ACPI: WSMT 0x00000000CC3B7000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003624] ACPI: APIC 0x00000000CC3B6000 0000DE (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.003626] ACPI: SSDT 0x00000000CC3B5000 00008D (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003627] ACPI: SSDT 0x00000000CC3B4000 0008F0 (v01 AMD AmdTable 00000001 INTL 20200717)
[ 0.003628] ACPI: Reserving FACP table memory at [mem 0xcc3e8000-0xcc3e8113]
[ 0.003629] ACPI: Reserving DSDT table memory at [mem 0xcc3df000-0xcc3e7d00]
[ 0.003630] ACPI: Reserving FACS table memory at [mem 0xcc561000-0xcc56103f]
[ 0.003630] ACPI: Reserving SSDT table memory at [mem 0xcc3ee000-0xcc3f52af]
[ 0.003631] ACPI: Reserving IVRS table memory at [mem 0xcc3ed000-0xcc3ed1a3]
[ 0.003631] ACPI: Reserving SSDT table memory at [mem 0xcc3e9000-0xcc3eca20]
[ 0.003632] ACPI: Reserving FIDT table memory at [mem 0xcc3de000-0xcc3de09b]
[ 0.003632] ACPI: Reserving MCFG table memory at [mem 0xcc3dd000-0xcc3dd03b]
[ 0.003633] ACPI: Reserving HPET table memory at [mem 0xcc3dc000-0xcc3dc037]
[ 0.003633] ACPI: Reserving FPDT table memory at [mem 0xcc3db000-0xcc3db043]
[ 0.003633] ACPI: Reserving VFCT table memory at [mem 0xcc3cd000-0xcc3da883]
[ 0.003634] ACPI: Reserving BGRT table memory at [mem 0xcc3cc000-0xcc3cc037]
[ 0.003634] ACPI: Reserving TPM2 table memory at [mem 0xcc3cb000-0xcc3cb04b]
[ 0.003635] ACPI: Reserving SSDT table memory at [mem 0xcc3c5000-0xcc3ca353]
[ 0.003635] ACPI: Reserving CRAT table memory at [mem 0xcc3c4000-0xcc3c4ee7]
[ 0.003635] ACPI: Reserving CDIT table memory at [mem 0xcc3c3000-0xcc3c3028]
[ 0.003636] ACPI: Reserving SSDT table memory at [mem 0xcc3c2000-0xcc3c2148]
[ 0.003636] ACPI: Reserving SSDT table memory at [mem 0xcc3c0000-0xcc3c148d]
[ 0.003637] ACPI: Reserving SSDT table memory at [mem 0xcc3be000-0xcc3bf51d]
[ 0.003637] ACPI: Reserving SSDT table memory at [mem 0xcc3bd000-0xcc3bd78d]
[ 0.003637] ACPI: Reserving SSDT table memory at [mem 0xcc3bc000-0xcc3bc640]
[ 0.003638] ACPI: Reserving SSDT table memory at [mem 0xcc3b8000-0xcc3bb86d]
[ 0.003638] ACPI: Reserving WSMT table memory at [mem 0xcc3b7000-0xcc3b7027]
[ 0.003639] ACPI: Reserving APIC table memory at [mem 0xcc3b6000-0xcc3b60dd]
[ 0.003639] ACPI: Reserving SSDT table memory at [mem 0xcc3b5000-0xcc3b508c]
[ 0.003640] ACPI: Reserving SSDT table memory at [mem 0xcc3b4000-0xcc3b48ef]
[ 0.003694] No NUMA configuration found
[ 0.003694] Faking a node at [mem 0x0000000000000000-0x000000076e2fffff]
[ 0.003699] NODE_DATA(0) allocated [mem 0x76e2d52c0-0x76e2fffff]
