I am new to Linux and loving it. Everything has been going really well except my laptop microphone barely picks up sound. On windows it works fine. When I plug in my headset the microphone on the headset works fine on. Why do you think this is happening? Thank you for your help.
Check the volume/level of the microphone, click the sound icon in the taskbar at bottom right of screen, and check here if it is properly configured.
Please post system information
inxi -Faxzy
sudo dmesg | grep snd
The audio that is recorded is just static.
[alex@alex-blade ~]$ inxi -Faxzy
Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bb3d873b-90bd-479a-8088-d3f167b2ca6e rw quiet apparmor=1
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Razer product: Blade v: 3.04 serial: <filter>
Chassis: RAZER type: 10 serial: <filter>
Mobo: RAZER model: RAZER v: 1.00 serial: <filter> UEFI: RAZER v: 3
.15
date: 12/22/2014
ID-1: BAT0 charge: 87% condition: N/A volts: 12.0/N/A model: Razer
Betty
type: Unknown serial: <filter> status: Unknown
Info: Quad Core model: Intel Core i7-4720HQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 2
8
L2 cache: 6144 KiB
bogomips: 41519
Speed: 798 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 1208 2:
1085
3: 849 4: 803 5: 1025 6: 811 7: 813 8: 1254
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vul
nerable
mitigation: Speculative Store Bypass disabled via prctl and seccom
p
mitigation: usercopy/swapgs barriers and __user pointer sanitizati
on
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditi
onal,
Device-1: Intel 4th Gen Core Processor Integrated Graphics driver:
i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0416
Device-2: NVIDIA GM204M [GeForce GTX 970M] vendor: Razer USA drive
r: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:13d8
Device-3: Realtek USB Camera type: USB driver: uvcvideo bus ID: 2-
14:8
chip ID: 0bda:579f serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: intel,modesetting,nouveau alternate: fbdev,nv,vesa display
screens: 1
Screen-1: 0 s-res: 6400x1080 s-dpi: 96 s-size: 1692x285mm (66.6x11
.2")
s-diag: 1716mm (67.6")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12
.2x6.7")
diag: 354mm (13.9")
Monitor-2: HDMI1 res: 2560x1080 hz: 60 dpi: 81 size: 800x340mm (31
.5x13.4")
diag: 869mm (34.2")
Monitor-3: DVI-I-2-1 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.2.2 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor:
Razer USA
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-3: DisplayLink Plugable USB3-3900DHE type: USB
driver: cdc_ncm,snd-usb-audio,usbfs bus ID: 4-1:5 chip ID: 17e9:43
24
serial: <filter>
Sound Server: ALSA v: k5.9.8-2-MANJARO
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:08b1
IF-ID-1: enp0s20u1i5 state: down mac: <filter>
Local Storage: total: 2.29 TiB used: 59.62 GiB (2.5%)
ID-1: /dev/sda vendor: Samsung model: MZNTE512HMJH-00000 size: 476
.94 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial:
<filter>
rev: 300Q scheme: GPT
ID-2: /dev/sdb type: USB vendor: Seagate model: Expansion size: 1.
82 TiB
block size: physical: 4096 B logical: 512 B serial: <filter> rev:
9300
scheme: MBR
ID-1: / raw size: 150.43 GiB size: 147.07 GiB (97.77%)
used: 59.59 GiB (40.5%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 61.0 C mobo: 27.8 C gpu: nouveau temp: 4
4.0 C
Processes: 367 Uptime: 1d 20h 07m Memory: 15.56 GiB used: 4.76 GiB
(30.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1270 pacman:
1260
lib: 342 flatpak: 0 snap: 10 Shell: Bash v: 5.0.18 running in: kon
sole
inxi: 3.1.08
[alex@alex-blade ~]$ sudo dmesg | grep snd
[sudo] password for alex:
[105013.556057] Modules linked in: ccm rfcomm fuse cmac algif_hash i
nput_leds algif_skcipher mousedev af_alg hid_rmi joydev rmi_core ser
io hid_multitouch bnep uvcvideo btusb cdc_mbim videobuf2_vmalloc cdc
_wdm videobuf2_memops videobuf2_v4l2 btrtl evdi(OE) btbcm hid_generi
c videobuf2_common btintel snd_usb_audio videodev bluetooth snd_usbm
idi_lib snd_rawmidi cdc_ncm snd_seq_device cdc_ether uas usbhid usbn
et mc mii hid usb_storage ecdh_generic ecc ebtable_filter ebtables i
p6table_filter ip6_tables iptable_filter snd_hda_codec_hdmi intel_ra
pl_msr intel_rapl_common nouveau iwlmvm x86_pkg_temp_thermal intel_p
owerclamp coretemp i915 kvm_intel mac80211 ttm kvm libarc4 ofpart sn
d_hda_codec_realtek i2c_algo_bit cmdlinepart snd_hda_codec_generic s
nd_soc_rt5640 irqbypass nls_iso8859_1 squashfs intel_spi_platform cr
ct10dif_pclmul ledtrig_audio snd_soc_rl6231 nls_cp437 crc32_pclmul i
ntel_spi ghash_clmulni_intel vfat aesni_intel snd_hda_intel iwlwifi
mei_hdcp snd_intel_dspcfg spi_nor fat drm_kms_helper
[105013.556071] snd_soc_core iTCO_wdt crypto_simd snd_hda_codec mtd
intel_pmc_bxt cec cryptd iTCO_vendor_support glue_helper mxm_wmi ra
pl loop cfg80211 rc_core intel_gtt snd_compress snd_hda_core mei_me
syscopyarea ac97_bus sysfillrect intel_cstate snd_pcm_dmaengine snd_
hwdep sysimgblt i2c_i801 mei intel_uncore snd_pcm fb_sys_fops tpm_cr
b rfkill i2c_smbus pcspkr lpc_ich snd_timer snd tpm_tis tpm_tis_core
evdev battery soundcore ac wmi mac_hid tpm rng_core uinput vboxnetf
lt(OE) vboxnetadp(OE) vboxdrv(OE) drm msr sg crypto_user agpgart ip_
tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 xhci_pci crc3
2c_intel xhci_hcd ehci_pci ehci_hcd
[132309.220968] Modules linked in: ccm rfcomm fuse cmac algif_hash i
[132309.220992] snd_soc_core iTCO_wdt crypto_simd snd_hda_codec mtd
[132309.221071] Modules linked in: ccm rfcomm fuse cmac algif_hash i
[132309.221086] snd_soc_core iTCO_wdt crypto_simd snd_hda_codec mtd
[132309.483423] Modules linked in: ccm rfcomm fuse cmac algif_hash i
[132309.483448] snd_soc_core iTCO_wdt crypto_simd snd_hda_codec mtd
