Greetings! Today the browser began to show more slowness (long delay to execute) when clicking on a region of the scroll bar for faster scrolling, when scrolling this bar, to switch between tabs, and when filling in fields to appear the prompt and choose options. I would like to know if this is due to it being a beta version, or due to some system failure?
Try running Chrome from a terminal & see if it displays any error messages when the slowness starts to happen.
I did this…The terminal just returns that it is “opening in a different browser session”.
Wow, nothing else?
I was going to suggest here something like --safe-mode
, but then I checked and recalled there isnt really one.
You will need to try and create a temporary new profile and use that.
But I do suggest checking a clean profile in whatever fashion.
Ex:
mkdir -p ~/tempchrom
chromium --user-data-dir=~/tempchrom/
EDIT.
Oops, used chromium in my example.
Sorry, replace with google-chrome
or whatever variant of chrom* you are using.
