My Intel Wireless AC 9260 gets detected, but does not scan any wifi networks
#22
So is your adapter initialized and working properly now?
Please clarify.
If it is now working, I guess you can mark your thread as solved.
#23
I would have to see tomorrow because if I turn it on and off again in a short-ish duration, it still works. Thank you so much for helping though!
#24
If it does not work after a long shutdown then you can run those commands as a script or a service at start up.
You are welcome. :smile:
#25
How would I be able to run these scripts at start up? (sorry Iā€™m new to this)
#26
I will walk you through it if you need it.
#27
Okay, thanks.
#28
I just did a cold boot and unfortunately, the commands did not seem to work. It keeps stating cannot find device wlp3s0 when I run sudo ip link set wlp3s0 down and sudo ip link set wlp3s0 up.
