My installation hangs forever at creating partition 64 bits filesystem
I reckon I have the same problem. I’m trying to install manjaro kde on a separate hdd. Installation’s stuck on “*creating new ext4 partition on /dev/sdc”. I wait for hours but still nothing happens. How do I open installation’s log to paste it here as DrTechnical had done? As you can assume from my message, I’m a total ignoramus, so I’d appreciate if you spelt it out for me. Thanks in advance
open a terminal
sudo parted -l
sudo journalctl -b0 -p4
Apr 03 02:17:52 manjaro kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Apr 03 02:17:52 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Apr 03 02:17:52 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
Apr 03 02:17:52 manjaro kernel: ata4.01: failed to resume link (SControl 30)
Apr 03 02:17:52 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to index=off,nfs_export=off.
Apr 03 02:17:52 manjaro kernel: spl: loading out-of-tree module taints kernel.
Apr 03 02:17:52 manjaro kernel: znvpair: module license 'CDDL' taints kernel.
Apr 03 02:17:52 manjaro kernel: Disabling lock debugging due to kernel taint
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Apr 03 02:17:53 manjaro kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Apr 03 02:17:53 manjaro systemd-udevd[336]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Apr 03 02:17:53 manjaro kernel: at24 0-0050: supply vcc not found, using dummy regulator
Apr 03 02:17:53 manjaro kernel: at24 0-0051: supply vcc not found, using dummy regulator
Apr 03 02:17:53 manjaro kernel: at24 0-0052: supply vcc not found, using dummy regulator
Apr 03 02:17:53 manjaro kernel: at24 0-0053: supply vcc not found, using dummy regulator
Apr 03 02:17:54 manjaro systemd-udevd[352]: controlC1: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Apr 03 02:17:54 manjaro systemd-udevd[340]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Apr 03 02:18:00 manjaro kernel: kauditd_printk_skb: 3 callbacks suppressed
Apr 03 02:18:06 manjaro kernel: kauditd_printk_skb: 25 callbacks suppressed
Apr 03 02:18:47 manjaro kernel:
Apr 03 02:18:47 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.56  Tue Feb 23 23:31:36 UTC 2021
Apr 03 02:18:47 manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
Apr 03 02:18:47 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0x000e3fff window]
Apr 03 02:18:47 manjaro kernel: caller _nv032974rm+0x2d/0x60 [nvidia] mapping multiple BARs
Apr 03 02:18:47 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
Apr 03 02:18:47 manjaro kernel: caller _nv000708rm+0x1af/0x200 [nvidia] mapping multiple BARs
Apr 03 02:18:49 manjaro systemd-xdg-autostart-generator[3764]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 02:18:49 manjaro systemd-xdg-autostart-generator[3764]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 02:18:49 manjaro systemd-xdg-autostart-generator[3764]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 02:18:49 manjaro systemd-xdg-autostart-generator[3764]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 02:18:49 manjaro systemd-xdg-autostart-generator[3764]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 02:18:49 manjaro systemd[3758]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
Apr 03 02:18:50 manjaro klauncher[3800]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Apr 03 02:18:51 manjaro NetworkManager[627]: <warn>  [1617405531.6325] dhcp6 (enp5s0): request timed out
Apr 03 02:18:53 manjaro kcminit_startup[3806]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object pa>
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5079:46: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5081:48: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5083:48: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5087:47: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:48: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5101:46: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5103:46: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:45: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:53 manjaro kwin_x11[3816]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5110:46: this compose sequence is a duplicate of another; skipping line
Apr 03 02:18:54 manjaro kde4breeze[3862]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: />
Apr 03 02:18:54 manjaro kded5[3812]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
Model: JetFlash Transcend 16GB (scsi)
Disk /dev/sda: 15.7GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 2      2826MB  2831MB  4194kB  primary               esp
Model: ATA ST1000DM003-9YN1 (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
 1      1049kB  106MB   105MB   primary  ntfs         boot
 2      106MB   1000GB  1000GB  primary  ntfs
 3      1000GB  1000GB  556MB   primary  ntfs         msftres
Model: ATA ST9250827AS (scsi)
Disk /dev/sdc: 250GB
Disk Flags:
 1      1049kB  250GB  250GB  primary
before install
launch Gparted and format your disk
then go for install
I’m doing it right now. How long does it take to create a partition on a 250GB hdd? I’ve been waiting for 2+ hours. Don’t want to seem impatient, just want to know the average duration.
The CPU in this ancient machine is i5-2500K if it matters
check in journallog any error
your disk is failing
Apr 03 07:13:57 manjaro kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Apr 03 07:13:57 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'perform>
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD>
Apr 03 07:13:57 manjaro kernel: ata4.01: failed to resume link (SControl 30)
Apr 03 07:13:57 manjaro kernel: overlayfs: null uuid detected in lower fs '/', >
Apr 03 07:13:57 manjaro kernel: spl: loading out-of-tree module taints kernel.
Apr 03 07:13:57 manjaro kernel: znvpair: module license 'CDDL' taints kernel.
Apr 03 07:13:57 manjaro kernel: Disabling lock debugging due to kernel taint
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500>
Apr 03 07:13:58 manjaro kernel: lpc_ich: Resource conflict(s) found affecting g>
Apr 03 07:13:58 manjaro kernel: at24 0-0050: supply vcc not found, using dummy >
Apr 03 07:13:58 manjaro kernel: at24 0-0051: supply vcc not found, using dummy >
Apr 03 07:13:58 manjaro kernel: at24 0-0052: supply vcc not found, using dummy >
Apr 03 07:13:58 manjaro kernel: at24 0-0053: supply vcc not found, using dummy >
Apr 03 07:13:59 manjaro systemd-udevd[359]: controlC1: Process '/usr/bin/alsact>
Apr 03 07:13:59 manjaro systemd-udevd[344]: controlC0: Process '/usr/bin/alsact>
Apr 03 07:14:02 manjaro kernel: kauditd_printk_skb: 2 callbacks suppressed
lines 1-25...skipping...
-- Journal begins at Sat 2021-04-03 07:13:57 UTC, ends at Sat 2021-04-03 10:19:40 UTC.>
Apr 03 07:13:57 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access>
Apr 03 07:13:57 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x0000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x0000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x0000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x0000>
Apr 03 07:13:58 manjaro kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Apr 03 07:13:58 manjaro kernel: at24 0-0050: supply vcc not found, using dummy regulat>
Apr 03 07:13:58 manjaro kernel: at24 0-0051: supply vcc not found, using dummy regulat>
Apr 03 07:13:58 manjaro kernel: at24 0-0052: supply vcc not found, using dummy regulat>
Apr 03 07:13:58 manjaro kernel: at24 0-0053: supply vcc not found, using dummy regulat>
Apr 03 07:13:59 manjaro systemd-udevd[359]: controlC1: Process '/usr/bin/alsactl resto>
Apr 03 07:13:59 manjaro systemd-udevd[344]: controlC0: Process '/usr/bin/alsactl resto>
Apr 03 07:14:08 manjaro kernel: kauditd_printk_skb: 25 callbacks suppressed
lines 1-26...skipping...
-- Journal begins at Sat 2021-04-03 07:13:57 UTC, ends at Sat 2021-04-03 10:19:40 UTC. --
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't >
Apr 03 07:13:57 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000>
Apr 03 07:13:58 manjaro kernel: at24 0-0050: supply vcc not found, using dummy regulator
Apr 03 07:13:58 manjaro kernel: at24 0-0051: supply vcc not found, using dummy regulator
Apr 03 07:13:58 manjaro kernel: at24 0-0052: supply vcc not found, using dummy regulator
Apr 03 07:13:58 manjaro kernel: at24 0-0053: supply vcc not found, using dummy regulator
Apr 03 07:13:59 manjaro systemd-udevd[359]: controlC1: Process '/usr/bin/alsactl restore 1' fa>
Apr 03 07:13:59 manjaro systemd-udevd[344]: controlC0: Process '/usr/bin/alsactl restore 0' fa>
Apr 03 07:14:49 manjaro kernel:
lines 1-27...skipping...
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't dete>
Apr 03 07:13:57 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to ind>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F>
Apr 03 07:13:59 manjaro systemd-udevd[359]: controlC1: Process '/usr/bin/alsactl restore 1' failed>
Apr 03 07:13:59 manjaro systemd-udevd[344]: controlC0: Process '/usr/bin/alsactl restore 0' failed>
Apr 03 07:14:49 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.56  Tue Feb 23>
lines 1-28...skipping...
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine si>
Apr 03 07:13:57 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to index=off,n>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflic>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflic>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflic>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflic>
Apr 03 07:13:59 manjaro systemd-udevd[359]: controlC1: Process '/usr/bin/alsactl restore 1' failed with ex>
Apr 03 07:13:59 manjaro systemd-udevd[344]: controlC0: Process '/usr/bin/alsactl restore 0' failed with ex>
Apr 03 07:14:49 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.56  Tue Feb 23 23:31:3>
Apr 03 07:14:49 manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
lines 1-29...skipping...
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-sta>
Apr 03 07:13:57 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to index=off,nfs_export=off.
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpReg>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpReg>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpReg>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpReg>
Apr 03 07:13:59 manjaro systemd-udevd[359]: controlC1: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Apr 03 07:13:59 manjaro systemd-udevd[344]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Apr 03 07:14:49 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.56  Tue Feb 23 23:31:36 UTC 2021
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PC>
lines 1-30...skipping...
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0>
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus>
Apr 03 07:14:49 manjaro kernel: caller _nv032974rm+0x2d/0x60 [nvidia] mapping multiple BARs
lines 1-31...skipping...
Apr 03 07:13:57 manjaro kernel: pci 0000:05:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x000000000000>
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem>
Apr 03 07:14:50 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem>
lines 1-32...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x>
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e>
Apr 03 07:14:50 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d>
Apr 03 07:14:50 manjaro kernel: caller _nv000708rm+0x1af/0x200 [nvidia] mapping multiple BARs
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is mark>
lines 1-34...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000>
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0>
Apr 03 07:14:50 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked exe>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked execu>
lines 1-35...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000>
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0x000e3>
Apr 03 07:14:50 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executabl>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable.>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable.>
lines 1-36...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F >
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 >
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0x000e3fff w>
Apr 03 07:14:50 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff w>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Pl>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Plea>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Plea>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. P>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove>
lines 1-38...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMI>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPI>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPI>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GP>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPI>
Apr 03 07:14:49 manjaro kernel: resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0x000e3fff window]
Apr 03 07:14:50 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please re>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please re>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove exec>
Apr 03 07:14:51 manjaro systemd[3772]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
lines 1-39...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPI>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (2>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remov>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remo>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executabl>
Apr 03 07:14:52 manjaro klauncher[3814]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
lines 1-40...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (202009>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (202009>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (202009>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (202009>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove exe>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove execu>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove execu>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove ex>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable per>
Apr 03 07:14:53 manjaro NetworkManager[640]: <warn>  [1617434093.6293] dhcp6 (enp5s0): request timed out
lines 1-41...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/uta>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX)>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/uta>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX)>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/uta>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX)>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (2020092>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/uta>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executabl>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executab>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permissio>
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kcon>
lines 1-42...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddr>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddr>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddr>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (2>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (20200925/u>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddr>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable p>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable per>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable per>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission b>
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig>
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5079:46: this compose sequence is a duplicate of another; skipping line
lines 1-43...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-20>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (2020092>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-20>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (2020092>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-20>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (2020092>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (20200925/utaddre>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-20>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permiss>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permissio>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permissio>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permis>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. P>
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notif>
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5081:48: this compose sequence is a duplicate of another; skipping line
lines 1-44...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/u>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/u>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/u>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (20200925/utaddress->
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission b>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission b>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permissio>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proc>
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" >
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5083:48: this compose sequence is a duplicate of another; skipping line
lines 1-45...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddr>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddr>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddr>
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000050F (\_GPE.GPIO) (20200925/utaddress-204)
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. >
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bit>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceedin>
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" membe>
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5087:47: this compose sequence is a duplicate of another; skipping line
lines 1-46...skipping...
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddress-204)
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddress-204)
Apr 03 07:13:58 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\_SB.PCI0.LPCB.GPBX) (20200925/utaddress-204)
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proce>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceed>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceed>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proc>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anywa>
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "Conf>
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
lines 1-47...skipping...
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anywa>
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": >
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:48: this compose sequence is a duplicate of another; skipping line
lines 1-48...skipping...
Apr 03 07:14:51 manjaro systemd-xdg-autostart-generator[3778]: Configuration file /home/manjaro/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid ob>
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5101:46: this compose sequence is a duplicate of another; skipping line
lines 1-49...skipping...
Apr 03 07:14:55 manjaro kcminit_startup[3820]: QDBusConnection: error: could not send signal to service "" path "//home/manjaro/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object pa>
Apr 03 07:14:55 manjaro kwin_x11[3830]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5103:46: this compose sequence is a duplicate of another; skipping line
gparted imgur.c om/a/0uoNthT
@team-manjaro
Calamares still failed to format if not 64bits filesystem ( here return of gparted )
can you provide
inxi -Fza
This appears to be a shortcoming of the system hardware - maybe disk is failing?
Are you sure the system supports UEFI at all?
Both disks are msdos disks which suggests a bios system.
I would try with a terminal - su and then use cgdisk to create the partitions and format using command line.
cgdisk fairly easy to navigate and using mkfs.ext4 from commandline.
Info: Quad Core model: Intel Core i5-2500 bits: 64 type: MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
           stepping: 7 microcode: 2F cache: L2: 6 MiB bogomips: 26496
           Speed: 1659 MHz min/max: 1600/3700 MHz Core speeds (MHz): 1: 1659 2: 1625 3: 2015 4: 1635
           Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64
           dtherm dts epb est flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc
           nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep smx ssbd sse
           sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
           Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
I’ve successfully created an ext4 partition in gparted. It took 3,5 hours. Then I started the installation about 1,5 hours ago, however, it’s still 1% creating new ext4 partition on /dev/sdb
stop it : your disk is FAILING
Your disk is in bad shape - very bad - the reason it is taking so long - is mapping out all the bad sectors.
Replace the disk - do not use to install an operating system and do not use it for data storage - pull it from the system - take a big hammer and nail and end it’s life.
Thank you both. I’ve changed the hdd and I was able to finish the installation. But when I boot now I see the only line /dev/sdb1: clean, 266841/29949952 files, 4084962/119788884 blocks
As far as I understand it’s because of nvidia drivers
