I have manjaro 20.1.1 installed alongside ubuntu 20.04. They share the same home partition. There is a Desktop
directory and Ubuntu has no problem recognizing it and showing the files inside it on the desktop.
But Manjaro doesn’t. In Manjaro, there is nothing on the desktop and when I right click the desktop, I can only see three options: Change background; Display settings; Settings
. I expect to see something like ‘Create A New File’ but there isn’t one. The the nautilus
doesn’t show the Desktop
directory on the left side pane either.
I tried setting the XDG_DESKTOP_DIR="$HOME/Desktop"
in ~/.config/user-dirs.dirs
but no luck.
Both ubuntu and manjaro run the gnome desktop environment. I installed manjaro first by the way.
I don’t know what’s going on with my manjaro. What should I do to fix the manjaro desktop folder? What could be the possible cause of this problem?
