For last 2-3 days I’ve noticed weird performance loss on my laptop. It started with weird throttling to half the FPS in Dos2 and now it’s… Well, If before at the start of Unigine Valley my fps was 40+, now it’s 30 and bellow. Depends. But, I’ve also noticed some weird CPU performance loss(30% or so), but it was only when I tried 5.15LTS (but same happened on live cd Linux mint).
Overall I tried playing with CoreCtrl, Ryzenadj, different kernels, different timeshift points, switching between Xorg and Wayland - nothing.
When I was playing with Ryzenadj, before all that happened, I changed --skin-temp-limit, thinking it’s a bit different thing and that I have default value wrote down. About the time first problem occurred, but I think a bit after that. After that I tried setting it to values from 0 to 90000 - doesn’t seem to affect anything. And for what I know - ryzenadj resets all parameters to default ones anyway.
My laptop is already really weak, now it’s just garbage. I don’t know what to do next and I need help.
My specs:
Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=aabcad23-aa76-449c-93dd-e561645d860c rw rootflags=subvol=@
quiet splash resume=UUID=fa0c5767-c220-4b64-a738-2510f7578ede
udev.log_priority=3
Desktop: GNOME v: 44.4 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
serial: <superuser required>
Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required> UEFI: Insyde
v: 1.04 date: 07/28/2021
ID-1: BAT1 charge: 35.9 Wh (79.6%) condition: 45.1/53.2 Wh (84.8%)
volts: 12.2 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: not charging
Device-1: hid-98:b6:ea:79:06:a6-battery model: GuliKit Controller XW
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1398 high: 1527 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1400 2: 1397
3: 1400 4: 1400 5: 1381 6: 1386 7: 1311 8: 1366 9: 1527 10: 1398 11: 1414
12: 1400 bogomips: 50325
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 41.0 C
Device-2: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0408:a094
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x683d built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: AMD Radeon Graphics (renoir
LLVM 15.0.7 DRM 3.49 6.1.49-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.1.49-1-MANJARO status: kernel-api tools: N/A
Server-3: PipeWire v: 0.3.78 status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: tap-easytether state: down mac: <filter>
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04ca:3802
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 476.94 GiB used: 348.47 GiB (73.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 451.93 GiB size: 451.93 GiB (100.00%)
used: 346.9 GiB (76.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 451.93 GiB size: 451.93 GiB (100.00%)
ID-4: /var/log raw-size: 451.93 GiB size: 451.93 GiB (100.00%)
ID-1: swap-1 type: partition size: 24 GiB used: 1.57 GiB (6.6%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Processes: 368 Uptime: 38m wakeups: 2514 Memory: total: 16 GiB note: est.
available: 14.98 GiB used: 4.72 GiB (31.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1572 libs: 492 tools: pamac Shell: Zsh v: 5.9
running-in: gjs inxi: 3.3.29
