my headphones nor my speaker of my laptop is being recognized my manjaro.There is no sound being outputted and when i go to audio settings it is showing up as “dummy output”.
on console
pacmd list-sinks
1 sink(s) available.
- index: 6
driver: <module-null-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 375 KiB
max rewind: 375 KiB
monitor source: 6
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 … 2000.00 ms
module: 35
properties:
device.description = “Dummy Output”
device.class = “abstract”
device.icon_name = “audio-card”
What says
alsamixer
on console ?
i dont understand?
Can you login as “root” and on console alsamixer
its says 00 and the item is master and nothing else
Can you post the screenshot of alsamixer on console ?
Can you post the system info: inxi -Fza
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=e2fd983e-4cd5-4ec2-add9-ba3b63bbeb6a rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Convertible System: LENOVO product: 82BG v: Yoga 9 14ITL5 serial: <filter> Chassis: type: 31 v: Yoga 9 14ITL5
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN serial: <filter> UEFI: LENOVO v: EHCN40WW date: 01/28/2021
Battery: ID-1: BAT0 charge: 27.3 Wh (62.5%) condition: 43.7/60.0 Wh (72.8%) volts: 7.9 min: 7.7 model: Celxpert BASE-BAT
type: Li-poly serial: <filter> status: Discharging cycles: 252
CPU: Info: Quad Core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP arch: Tiger Lake family: 6
model-id: 8C (140) stepping: 1 microcode: 88 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 47936
Speed: 1164 MHz min/max: 400/4800 MHz Core speeds (MHz): 1: 1164 2: 1200 3: 1192 4: 1200 5: 1186 6: 1200 7: 1200
8: 1200
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:3 chip-ID: 13d3:56b2 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 11.11 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 11170001
temp: 34.9 C scheme: GPT
Partition: ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 11.11 GiB (2.4%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A
Info: Processes: 237 Uptime: 2h 10m wakeups: 2425 Memory: 15.37 GiB used: 1.93 GiB (12.5%) Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1202 lib: 331 flatpak: 0 Shell: Zsh v: 5.8 default: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.08
how do post code like that?
alsamixer
on console puts a image on screen same as above.
aplay -l
on console should play a sound.
aplay -l ✔
aplay: device_list:274: no soundcards found...
Can you update to kernel 5.14 ?
hey man i have found the solution,and i really appreciate the help.Thank you very much
