I ran lm_sensors and my fans wont show up. Which leads me to think I didnt set something up correctly. I am not sure what I need to offer via information or anything like that so just ask if you want to look at anything.
You might want to mention which fan. The case, cpu, or graphics card fan? Then what hardware you are using.
All of them, I am sorry I should of specified.
to do so post the output of
use the option of preformatted text and place it in there.
Kernel: 5.15.0-53-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15.0-53-generic
root=UUID=593dbb30-69dd-45ad-ad77-74d05c68389e ro quiet splash
Desktop: Cinnamon 5.4.12 tk: GTK 3.24.33 wm: Mutter vt: 7
dm: LightDM 1.30.0 Distro: Linux Mint 21 Vanessa base: Ubuntu 22.04 jammy
Type: Laptop System: Microsoft product: Surface Laptop Go
v: 124I:00057T:000M:0000000D:0B:04F:1C:05P:48S:01E:0Y:0K:0U:02
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Microsoft model: Surface Laptop Go serial: <superuser required>
UEFI: Microsoft v: 9.101.140 date: 04/30/2021
ID-1: BAT1 charge: 22.4 Wh (62.9%) condition: 35.6/39.7 Wh (89.7%)
volts: 7.7 min: 7.6 model: SMP Z91 type: Li-ion serial: <filter>
status: Discharging cycles: 132
RAM: total: 7.36 GiB used: 2.43 GiB (33.0%)
RAM Report:
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB2
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1100 high: 1101 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1101
4: 1100 5: 1101 6: 1101 7: 1101 8: 1100 bogomips: 19046
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Iris Plus Graphics G1 vendor: Microsoft driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1536x1024 s-dpi: 96 s-size: 406x270mm (16.0x10.6")
s-diag: 488mm (19.2")
Monitor-1: eDP-1 model: LG serial: <filter> built: 2020 res: 1536x1024
hz: 60 dpi: 148 gamma: 1.2 size: 263x175mm (10.4x6.9") diag: 316mm (12.4")
ratio: 3:2 modes: 1536x1024
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 22.0.5
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.0-53-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
IP v6: <filter> type: temporary dynamic scope: global
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 237e hci-v: 5.2 rev: 237e
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 119.24 GiB used: 19.9 GiB (16.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM128GDGTNG-87A0A size: 119.24 GiB block-size: physical: 512 B
rev: 80041C00 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 118.74 GiB size: 116.32 GiB (97.96%) used: 9.95 GiB (8.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 593dbb30-69dd-45ad-ad77-74d05c68389e
used: 5.4 MiB (1.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F3E9-E87B
ID-3: /home/grimsongrimelt raw-size: N/A size: 116.32 GiB
used: 9.95 GiB (8.6%) fs: ecryptfs source: ERR-102
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Elan Micro Touchpad and Keyboard
type: Keyboard,Mouse driver: hid-generic,hid-multitouch,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 04f3:0c5b class-ID: 0301
Device-2: 3-5:3 info: Elan Micro ELAN:ARM-M4 type: HID
power: 100mA chip-ID: 04f3:0c5a class-ID: 0300
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 260 Uptime: 8m wakeups: 4 Init: systemd v: 249 runlevel: 5
tool: systemctl Compilers: gcc: 11.3.0 alt: 11 Packages: apt: 2089 lib: 1035
flatpak: 0 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
It just doesnt detect the fan.
please open the packet-manager and install the following package:
“linux-firmware-surface-go”
do a reboot and post any changes.
NOTE: you must enable the aur-packages to install it.
Yes I did
I cant seem to find the package, I found the github page for it thought but it is ment for arch linux, would it still work?
as said, you must enable the option to use the aur-packages in package-manager ! after this install it from the package-manager.
settings-> third-party-supply
If step 3 doesn’t output any sensor data then you might need to reconfigure i guess, or your hardware is not supported at all at worst case
(I can’t give you any advice on which probes to allow that are not probed by default because i dont use that package)
It does not show me the option for that. One second im just gonna install the Aur-package through the terminal then try again to look for it.
Ok so you contradict your self, you didn’t
All AUR packages are meant for Arch, Manjaro is Arch based…
The command lm_sensors just doesnt work. So when I tried to do it, it just didnt work. Probably should of said that, thought I did. My bad.
Thats the name of the package, read that wiki page to see which commands you can/should use
PS: The lm_sensors
package is in the official repos (extra), it is not an AUR package…
omg you’re right
WTH…
your on linux-mint not manjaro as @manyaro01 already stated. sorry, but you should check the linux-mint forum in this case.
@Grimsongrime , sorry but how can you expect people of a different distro to help solve your problem in this case?
We are all helpfull, but there is a limit in abilities to find the cause when we use a different distro as you…
So please be so kind to ask on their forum instead like @Olli said, its not because we don’t like that distro or dont want to help, but more because it’s most likely a distro related thing.
