It’s been happening for a long time.
I use Manjaro Stable.
It often happens that when I start the system it has problems connecting to the home network. I use an Ethernet connection, via powerline, connected to a TIM router (the TIM HUB+) which would be my provider.
Sometimes it connects after a long time on its own, other times however, the only way to get it to connect is to unplug and plug the cable behind the PC.
On windows I have no problems, everything works fine.
I wanted to know if I could solve it on Linux.
Thank you
this is “inxi -zv8” result:
Kernel: 6.6.119-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=5d1edef8-9fc5-44bc-bb5b-ff0d8389311d rw apparmor=1
Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
Firmware: UEFI vendor: American Megatrends v: 5031 date: 01/13/2025
System RAM: total: 16 GiB available: 15.52 GiB used: 2.88 GiB (18.5%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Crucial Technology
part-no: BL8G36C16U4B.M8FE1 serial: <filter>
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/4851 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 121659
ht hw_pstate ibpb ibpb_exit_to_user ibrs ibs invpcid irperf lahf_lm lbrv
lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 590.48.01 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-2 empty: DP-1,
DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 09:00.0 chip-ID: 10de:2484 class-ID: 0300
compositor: gnome-shell driver: gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-2 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2021 res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.686
y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149 y: 0.055 white: x: 0.314
y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 09:00.1 chip-ID: 10de:228b class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: XMOS ZEN DAC 3 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:6
chip-ID: 20b1:3009 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.119-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
status: discoverable: no pairing: no
Local Storage: total: 3.18 TiB used: 654.39 GiB (20.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3PSSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 35.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 23.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000NC000-1CX162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CE02 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-1: / raw-size: 325.8 GiB size: 319.62 GiB (98.10%)
used: 76.92 GiB (24.1%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: Manjaro uuid: 5d1edef8-9fc5-44bc-bb5b-ff0d8389311d
ID-2: /mnt/393a4e07-e0ad-4ece-8b70-eae063f05e67 raw-size: 158.08 GiB
size: 154.54 GiB (97.76%) used: 56.31 GiB (36.4%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18 label: Backup Linux
uuid: 393a4e07-e0ad-4ece-8b70-eae063f05e67
ID-3: /mnt/52D0C59AD0C584A7 raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 293.96 GiB (31.6%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: HDD Meccanico uuid: 52D0C59AD0C584A7
ID-4: /mnt/8F1C-6689 raw-size: 953 MiB size: 951.1 MiB (99.80%)
used: 8.9 MiB (0.9%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8F1C-6689
ID-5: /mnt/F8268F31268EF044 raw-size: 773.43 GiB
size: 773.43 GiB (100.00%) used: 227.2 GiB (29.4%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: SSD 860 Evo uuid: F8268F31268EF044
ID-1: swap-1 type: partition size: 7.22 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:4 label: N/A
uuid: 27f4d435-5164-4729-8af0-8d564ae63e67
ID-1: /dev/nvme0n1p4 maj-min: 259:3 size: 131.81 GiB fs: ext4 label: Debian
uuid: fc42c819-2ff4-4afc-9721-551179eb9e9e
ID-2: /dev/nvme1n1p1 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: 683D-A5A7
ID-3: /dev/nvme1n1p2 maj-min: 259:7 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p3 maj-min: 259:8 size: 930.69 GiB fs: ntfs
label: Windows 11 uuid: 7E903F28903EE5F5
ID-5: /dev/nvme1n1p4 maj-min: 259:9 size: 721 MiB fs: ntfs label: N/A
uuid: 66DA6AF1DA6ABCC5
Device-1: 1-1:2 info: Keychron K8 Pro type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0281 class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: Xenta G3 Mouse type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1d57:2122 class-ID: 0301
Device-2: 5-4:6 info: XMOS ZEN DAC 3 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 20b1:3009
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 34.8 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1268 pm: pacman pkgs: 1250 libs: 362 tools: gnome-software,pamac
pm: flatpak pkgs: 18
1: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
2: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 370
1: cpu: 6.2% command: gnome-terminal-server pid: 11612
mem: 56.6 MiB (0.3%)
2: cpu: 4.0% command: gnome-shell pid: 2613 mem: 387.0 MiB (2.4%)
3: cpu: 3.5% command: exe pid: 6928 mem: 280.2 MiB (1.7%)
4: cpu: 3.0% command: zsh pid: 11960 mem: 8.77 MiB (0.0%)
5: cpu: 1.9% command: chrome pid: 9025 mem: 342.0 MiB (2.1%)
Memory top: 5 of 370
1: mem: 387.0 MiB (2.4%) command: gnome-shell pid: 2613 cpu: 4.0%
2: mem: 342.0 MiB (2.1%) command: chrome pid: 9025 cpu: 1.9%
3: mem: 280.2 MiB (1.7%) command: exe pid: 6928 cpu: 3.5%
4: mem: 268.1 MiB (1.6%) command: chrome pid: 10485 cpu: 1.4%
5: mem: 265.4 MiB (1.6%) command: chrome pid: 9071 cpu: 1.5%
Processes: 370 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.40
I edit to say: befor i had a static ip setup from the router, and though could be this the problem, so i’ve setup a static ip from network manager, deleting it from the router, but the problem is showed again, however.
